Log Files location
GL29
Log Files location
We can find file logs in /var/log/
But can someone tell me where to find log files for sqlite3, openZwave, RFXCOM ...
Thanks in advance.
Thanks in advance.
meesje
Re: Log Files location
I have the same question. Where can I find the logs of the switches, groups, temperature etc.?
- gizmocuz
#1, it's all in the database
#2, in the startup script you can specify the log
Lassiv
Can someone tell more how this Domoticz logging temperatures. Example if i want now what is my room temperature 20days ago wednesday clock 11:05 is that possible or is domoticz log only 1-5days or something like that?
I want log files hole time when domoticz is running. Example if that run 1year.. i want to see temperatures every day if i want and every clock. I know that takes little bit hard drive space, but i think that is not problem. That files not needed see normal view on Domoticz, but i want that all temps are somewhere were i can download them or something like that.
Hope someone can help
bassmint
Can someone provide the specific location of the open z-wave log file? I am not well versed in this and am having a hard times.
I have been searching for a while on many sources but only find cryptic answers.
I am having some issues and would like to use their log file analyzer.
thanks.
thanks.
- gizmocuz
If you enable the debug option for the controller, the log can be found in the 'Config' folder (OZW_Log.txt)
nizaga
is there a way to change the location of the /home/pi/domoticz/Config/OZW_Log.txt, for instance to /var/log/ so it can be written to a RAM drive on Raspberry?
thanks
thanks
nizaga
hi, question for the experts...
i tried to move the OZW_Log.txt to memory by creating a softlink from /home/pi/Config/OZW_Log.txt to /var/tmp/OZW_Log.txt
could this create an issue??
thanks
thanks
Flopp
- Target OS: -
How do you enable DEBUG for OpenZWave?gizmocuz wrote: Tuesday 15 March 2016 18:39 If you enable the debug option for the controller, the log can be found in the 'Config' folder (OZW_Log.txt)
Flopp
- Target OS: -
Found it.
Setup-Hardware select OpenZWave click on Setup OpenZwave. Select Controller and scroll down, there you find Debug enable/disable
