Pushbullet-notification to multiple receivers
thorbj
Post by thorbj »
Hi, does anyone know if and how it is possible to send pushbullet-notifications to multiple receivers? I.e. if the washing-machine is done I want Domoticz to notify both me and my wife.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Justintime
Re: Pushbullet-notification to multiple receivers
Post by Justintime »
Yes I would like to know too... But when the washing machine is ready you should only notify your wife. :)
Mooseknuckle
Post by Mooseknuckle »
I use the bash script described here for that:
http://www.domoticz.com/forum/viewtopic.php?f=31&t=3188
#!/bin/bash
api=<Put_Your_API_KEY_HERE>
title=$1
body=$2
curl -u $api: https://api.pushbullet.com/v2/pushes -d type=note -d title=$title -d body=$body
You can make 2 scripts, one for you and one for your wife. You can even send it to a specific device if you have more devices with pushbullet configured.
If you add "-d device_iden='pushbullet id of your device'" to the last line you can target a specific device.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
thorbj
Post by thorbj »
Mooseknuckle wrote:I use the bash script described here for that:
#!/bin/bash
title=$1
body=$2
And then I call the batch-script from a switch? Or a Lua script?
Edit: I get
Error: Error executing script command (/home/pi/domoticz/scripts/bash/pb_washingmachine.sh). returned: 1536
when executing it from the switch.
This is my code:
#!/bin/bash
api=myApIkeY
title='Washing machine finished'
body='Hi, the washing machine is finished :)'
Mooseknuckle
You don't change anything in the script (except your key).
From a lua script:
os.execute('/home/pi/domoticz/scripts/pushbullet.sh "Alert" "The dishwasher is ready"')
From a switch (On or Off action):
script://home/pi/domoticz/scripts/pushbullet.sh "Alert" "The dishwasher is ready"
This way the script never changes for different alerts, only the arguments.
Last edited by Mooseknuckle on Wednesday 30 September 2015 16:27, edited 1 time in total.
thorbj
Post by thorbj »
Ah, now I see, thank you! :)
But I only get the first word in the message; The
And i see this in the log:
What does that mean?
Mooseknuckle
I don't really know. I use the script from a lua script and it works. Also if I run it from the commandline with:
./pushbullet.sh "test" "this is a test"
This also works. Can you try that?
PS. Try adjusting the script to:
#!/bin/bash
title="$1"
body="$2"
curl -u $api: https://api.pushbullet.com/v2/pushes -d type=note -d title="$title" -d body="$body"
thorbj
Post by thorbj »
That worked great! Thank you :)
commodore white
Post by commodore white »
OK! I give in..... Who sits by the washing machine waiting for it to finish then invoke these scripts? Oh! Perhaps you do it by electrickery. Exactly do you do that?
Peter
Whatsek
Domoticz version: Latest B
Post by Whatsek »
If we could push notifications to a pushbullet channel, (you create one on the website, and the both of you subscribe to that channel) then you will receive both the notification.
thorbj
Post by thorbj »
commodore white wrote:OK! I give in..... Who sits by the washing machine waiting for it to finish then invoke these scripts? Oh! Perhaps you do it by electrickery. Exactly do you do that?
Peter
I'm not sure if I understood your question. I have a fibaro wall-plug that measures power-consumption, and when it drops below a given value, Domoticz invokes a script to notify me.
Although I haven't got it to work right yet. As of now I'm beeing flooded with notifications every time the machine has a pause in the program...
zoltar
Post by zoltar »
Actually you don't need a script for this. If you have created a channel in Pushbullet via https://www.pushbullet.com/my-channel you can push messages to it via custom HTTP notification (Custom HTTP/Action) type in settings and there can be any number of channel subscribers.
URL/Action:
POST Data:
type=note&title=#SUBJECT&body=#MESSAGE&channel_tag=your_channel
POST Content-Type:
application/x-www-form-urlencoded
POST Headers:
Authorization: Basic <API Key hash>
You can get <API Key hash> calling https://api.pushbullet.com/v2/pushes via curl like this:
curl -u"<API key>:" "https://api.pushbullet.com/v2/pushes" -d type=note -d title="Alert test" -d body="Body msg" -d channel_tag=your_channel -vvv
You will see Authorization header in verbose messages. Note the ":" after API key - there is no password.
Get your access token using https://www.pushbullet.com/#settings/account and pressing on "Create access token".
