I bought several Home Easy HE876 dimmers and paired their with RFX Com and Domoticz.
It's working to send On command but when I trying to set some level of light - it's not working properly. Light level is going up and down unconstant without even touching.
Unfortunately for now dimmers are not usable at all ;(
Anybody has this king of problems? I'm looking for some solutions.
Thank you in advance.
Home Easy (HE876) Dimmer
b_weijenberg
- Target OS: -
Re: Home Easy (HE876) Dimmer
The HE878 shows the same problem. It is not possible to set these modules to a dim level.
The module will switch to a certain dim level but not the correct one and after this command the module becomes frozen for a number of commands following the set dim level.
The HomeEasy EU ON/Off and ARC On/Off operates correct. But the module becomes in a dim cycle on a 2nd On command.
RFX-433, RFX-433EMC, RFX-868
s3rgi
I have another problem with one Home Easy HE876. The pairing with Domoticz and RFlink seems to be correct. When I do the automatic search and I press the button of the remote control corresponding the HE876, domoticz creates a switch and see the status of the dimmer when I press the remote control, but when I try to send On/Off command from domoticz the dimmer do not do anything...
DomoB
- Domoticz version: 3.4834
Same problem here, is use scene's to set all my wall lighting to the same dim level but this is not possible with this dimmer....
Is there a solution or nice work around for this ?
I use the dimmer with rfxcom as: Lighting 2 HomeEasy EU device.
Hesmink
Any update on this?
Apparently, the method of dimming for this switch is: 1. Turn lamp on. 2. Turn lamp on again, lamp starts cycling dim levels. 3. Press 'lamp on' again.
Although I'm sending dim levels, the dimmer doesn't respond to it.
reindje
Same problem here, no one has get this work with setting dimlevel?
edezwaan82
- Target OS: -
Hi All,
What is the ID for HE878. Unfortunately I lost my remote so I need to configure it manually.
Can anyone help?
Can anyone help?
