dtgbot - Domoticz TeleGram BOT
Slayer007
Re: dtgbot - Domoticz TeleGram BOT
Post by Slayer007 »
I've read that there's no security in the bot. So anyone that knows the name of my bot, can turn my lights on, for example.
I read in this forum that you can make a user variabele in domoticz. But i can't get it to work. I don't know exactly what to do. Can anyone help me or is there another security that can be implemented.
I don't want to use groups. Just two phones who can talk with the bot seperately.
At first i worked with one of the first telegrams, but somehow that didn't work anymore. This looks a lot more stable, with lost of possibilities. Thanks for the wiki Simon. Works perfect!
simonrg
Domoticz version: 3.8807
Post by simonrg »
Slayer007 wrote:I've read that there's no security in the bot. So anyone that knows the name of my bot, can turn my lights on, for example.
There wasn't security in the bot, there is now.
In dtgbot.cfg the name of the Domoticz variable is defined
WLName = 'TelegramBotWhiteListedIDs'
Then in Domoticz just create a string uservaraible called TelegramBotWhiteListedIDs and put in the chat ids of the clients:
1234343423|0982384343
Basically separate the chat ids by |
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Slayer007
Post by Slayer007 »
Yeah,
That's exactly what I did. I put in some dummy id's, to check wether I can still send messages. It's still working alttough my id wasn't in the list.
This is what I put in domoticz.
Am I forgetting something to do?
Edit: Forgot to restart the bot. Now it's working just fine
Last edited by Slayer007 on Wednesday 19 August 2015 19:09, edited 1 time in total.
MacJL
Target OS: OS X
Post by MacJL »
I have this error when trying to obtain temperature :
/usr/bin/lua5.2: /home/pi/dtgbot/lua//temperature.lua:31: attempt to concatenate global 'Humidity' (a nil value)
stack traceback:
        /home/pi/dtgbot/lua//temperature.lua:31: in function 'temperature'
        /home/pi/dtgbot/lua//temperature.lua:44: in function 'handler'
        /home/pi/dtgbot/dtgbot.lua:293: in function 'HandleCommand'
        /home/pi/dtgbot/dtgbot.lua:400: in function 'on_msg_receive'
        /home/pi/dtgbot/dtgbot.lua:490: in main chunk
        [C]: in ?
MacJL
Target OS: OS X
Post by MacJL »
And another one with specials caracters in Devices names :
Succesfully handled incoming request
TelegramBotOffset 726956497
JSON request <http://127.0.0.1:8080/json.htm?type=command&param=updateuservariable&idx=2&vname=TelegramBotOffset&vtype=integer&vvalue=726956497>
.{"ok":true,"result":[]}
.{"ok":true,"result":[{"update_id":726956497,
"message":{"message_id":198,"from":{"id":xxxxxx,"first_name":"xxxxxxx","last_name":"xxxxxx","username":"xxxxxx"},"chat":{"id":xxxxxx,"first_name":"xxxxxx","last_name":"xxxxxx","username":"xxxxxx"},"date":1439995113,"text":"\/temperature \"V\u00e9randa\""}}]}
Message: 1
update_id       726956497
/temperature "Véranda"
No on WhiteList: 2
WhiteList: xxxxxx
WhiteList: xxxxxx
Handle command function started with /temperature "Véranda" and xxxxxx
JSON request <http://127.0.0.1:8080/json.htm?type=devices&order=name>
V randa does not exist
https://api.telegram.org/botxxxxxx:xxxxxx/sendMessage?timeout=60&chat_id=xxxxxx&reply_to_message_id=198&text=V+randa+does+not+exist
200
MacJL
Target OS: OS X
Post by MacJL »
I have created a simple script that add the chat ids to telegram TelegramBotWhiteListedIDs user variable.
The steps :
# Stop dtgbot
sudo service dtgbot stop
sleep 60
# Send a telegram message to the bot
# Execute the script
chmod +x authorize.bash
./authorize.bash
# Restart dtgbot
sudo service dtgbot start
If you want to add the script to the git repository and the wiki page, you can do it.
The content of authorize.bash
#!/bin/bash
# Getting Domoticz user variables
JMESSAGES=$( curl -sS "https://api.telegram.org/bot$TelegramBotToken/getUpdates" )
# Getting Telegram Bot last messages
DOMOVAR=$( curl -sS "http://$DomoticzIP:$DomoticzPort/json.htm?type=command&param=getuservariables")
# Parsing User variable "TelegramBotWhiteListedIDs" Value and IDX
DOMOVAR_VAL=$( echo $DOMOVAR | jq -c '.result[]|select(.Name == "TelegramBotWhiteListedIDs").Value' | sed "s/\"//g" )
DOMOVAR_IDX=$( echo $DOMOVAR | jq -c '.result[]|select(.Name == "TelegramBotWhiteListedIDs").idx'   | sed "s/\"//g" )
# For each user or group chat
echo $JMESSAGES | jq -c .result[].message.chat | sort -u | while read line
do
        FIRSTNAME=$(  echo $line | jq -c .first_name | sed "s/\"//g" )
        LASTNAME=$(   echo $line | jq -c .last_name  | sed "s/\"//g" )
        USERNAME=$(   echo $line | jq -c .username   | sed "s/\"//g" )
        GROUPTITLE=$( echo $line | jq -c .title      | sed "s/\"//g" )
        CHATID=$(     echo $line | jq -c .id         | sed "s/\"//g" )
        # Gessing if it's a user or a group chat
        if [[ $GROUPTITLE == "null" ]]
        then
                DESTNAME="user $FIRSTNAME $LASTNAME, $USERNAME with chat id : \"$CHATID\""
                DESTNAME="group $GROUPTITLE with chat id : \"$CHATID\""
        fi
        # Is the CHATID already authorized?
        if [ $( echo "|$DOMOVAR_VAL|" | sed "s/\"/\|/g" | grep "|$CHATID|" | wc -l ) -eq 1 ]
        then
                echo "The $DESTNAME is already authorized"
                echo "Adding $DESTNAME to $DOMOVAR_VAL"
                DOMOVAR_VAL="$DOMOVAR_VAL|$CHATID"
                curl -sS "http://$DomoticzIP:$DomoticzPort/json.htm?type=command&param=updateuservariable&idx=$DOMOVAR_IDX&vname=TelegramBotWhiteListedIDs&vtype=2&vvalue=$DOMOVAR_VAL" | jq -c .status
        fi
done
simonrg
Post by simonrg »
MacJL wrote:Hello,
stack traceback:
        [C]: in ?
All my temperature sensors return Humidity as well, so it always works for me, ;) , obviously not all temperature sensors do, the code needs to check the type of the sensor and then only return humidity from ones that do. If you replace these routines in temperature.lua with the code below, then it should work ok:
function get_temperature(DeviceName)
  idx = idx_from_name(DeviceName,'devices')
  if idx == nil then
    return DeviceName, -999, -999, 0
-- Determine temperature
  t = server_url.."/json.htm?type=devices&rid=" .. idx
  print ("JSON request <"..t..">");
  jresponse, status = http.request(t)
  decoded_response = JSON:decode(jresponse)
  result = decoded_response["result"]
  record = result[1]
  Temperature = record["Temp"]
  if record["Type"] == "Temp + Humidity" then
    Humidity = record["Humidity"]
    Humidity = -999
  LastUpdate = record["LastUpdate"]
  DeviceName = record["Name"]
  return DeviceName, Temperature, Humidity, LastUpdate;
function temperature(DeviceName)
  local response = ""
  DeviceName, Temperature, Humidity, LastUpdate = get_temperature(DeviceName)
  if Temperature == -999 then
    print(DeviceName..' does not exist')
    return 1, DeviceName..' does not exist'
  if Humidity ~= -999 then
    print(DeviceName .. ' temperature is ' .. Temperature .. '°C and relative humidity is ' .. Humidity .. '%')
    response = DeviceName.. ' ' .. Temperature .. '°C & ' .. Humidity .. '%'
    print(DeviceName .. ' temperature is ' .. Temperature .. '°C')
    response = DeviceName.. ' ' .. Temperature .. '°C'
  return status, response;
I have updated the master branch in github with these corrections, thanks.
simonrg
Post by simonrg »
MacJL wrote:I have created a simple script that add the chat ids to telegram TelegramBotWhiteListedIDs user variable.
The steps :
# Stop dtgbot
sleep 60
./authorize.bash
# Restart dtgbot
#!/bin/bash
do
        then
        fi
        then
        fi
done
:shock: Great piece of bashing, :D my only hesitation is that it adds another dependency to jq that I am sort of keen to remove just because it is not immediately available in Raspberry Pi repository, I am tempted to translate your code into Lua and include it as new command for the bot, i.e. if either you have no whitelisted ids or your id is already whitelisted, then command /whitelist 10 would whitelist any ids that have been recieved in the last 10 minutes.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Is dtgbot Raspberry only? I followed your steps but get :
//usr/bin/lua5.2: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
        /usr/local/lib/lua/5.2/socket/core.so: cannot open shared object file: No such file or directory
stack traceback:
        [C]: in ?
        [C]: in function 'require'
        /usr/local/share/lua/5.2/socket.lua:12: in main chunk
        /usr/local/share/lua/5.2/socket/http.lua:10: in main chunk
        /home/pi/dtgbot/dtgbot.lua:65: in main chunk
        [C]: in ?
Edit: Nevermind, I see I have to find them myself and compile. Maybe next time ;)
simonrg
Post by simonrg »
bizziebis wrote:Is dtgbot Raspberry only? I followed your steps but get :
stack traceback:
        [C]: in ?
        [C]: in ?
What system are you on? You may find they are available to install from the system repository or compilation shouldn't be too difficult.
MacJL
Target OS: OS X
Post by MacJL »
simonrg wrote: All my temperature sensors return Humidity as well, so it always works for me, ;) , obviously not all temperature sensors do, the code needs to check the type of the sensor and then only return humidity from ones that do. If you replace these routines in temperature.lua with the code below, then it should work ok:
if idx == nil then
record = result[1]
Humidity = -999
local response = ""
Still the same issue with this update. In fact, this sensor is a not a temperature only sensor, but a temperature + Humidity + barometer sensor. If you need more logs, I can provides them.
simonrg
Post by simonrg »
MacJL wrote:Still the same issue with this update. In fact, this sensor is a not a temperature only sensor, but a temperature + Humidity + barometer sensor. If you need more logs, I can provides them.
There is a new version on github now.
  if idx == nil then
    return DeviceName, -999, -999, -999, 0
  Temperature = -999
  Humidity = -999
  Pressure = -999
  record = result[1]
  DeviceType = record["Type"]
  if DeviceType == "Temp" then
    if DeviceType == "Humidity" then
      if DeviceType == "Temp + Humidity" then
        if DeviceType == "Temp + Humidity + Baro" then
          Pressure = record["Barometer"]
  return DeviceName, Temperature, Humidity, Pressure, LastUpdate;
  local response = ""
  DeviceName, Temperature, Humidity, Pressure, LastUpdate = get_temperature(DeviceName)
  if Temperature == -999 and Humidity == -999 and Pressure == -999 then
    if Temperature == -999 and Pressure == -999 then
      print(DeviceName .. ' relative humidity is ' .. Humidity .. '%')
      response = DeviceName.. ' ' .. Humidity .. '%'
      if Pressure ~= -999 then
        print(DeviceName .. ' temperature is ' .. Temperature .. '°C, relative humidity is ' .. Humidity .. '% and pressure is '.. Pressure..'hPa')
        response = DeviceName.. ' ' .. Temperature .. '°C & ' .. Humidity .. '% & '.. Pressure .. 'hPa'
MacJL
Target OS: OS X
Post by MacJL »
Ther is no mare crashes, but it reply 'Salon does not exist', even If ther is a Temp Sensor that is called 'Salon'.It seems to be the fact that I have two devices which are called Salon : A temperature Sensor, and a switch :
.{"ok":true,"result":[{"update_id":726956523,
"message":{"message_id":249,"from":{"id":34862038,"first_name":"Jean-Laurent","last_name":"Girod","username":"macjl"},"chat":{"id":34862038,"first_name":"Jean-Laurent","last_name":"Girod","username":"macjl"},"date":1440071800,"text":"\/temperature Salon"}}]}
Message: 1
update_id       726956523
/temperature Salon
No on WhiteList: 2
WhiteList: xxxxxxxxxx
Handle command function started with /temperature Salon and xxxxxxxxxx
25
58
JSON request <http://127.0.0.1:8080/json.htm?type=devices&rid=58>
https://api.telegram.org/botxxxxxx:xxxxxx/sendMessage?timeout=60&chat_id=xxxxxx&reply_to_message_id=249&text=Salon+does+not+exist
200
TelegramBotOffset 726956524
JSON request <http://127.0.0.1:8080/json.htm?type=command&param=updateuservariable&idx=2&vname=TelegramBotOffset&vtype=integer&vvalue=726956524>
Maybe you should send a reply for each device with the same name, instead of just the last one?
simonrg
Post by simonrg »
MacJL wrote:Thanks!
Message: 1
update_id       726956523
/temperature Salon
No on WhiteList: 2
25
58
200
For time being if you change the name of the temperature sensor would be easiest.
In the long term I should really make the logic deal with multiple names, but it has implications for other parts of the code, so needs a little bit of thought.
Slayer007
Post by Slayer007 »
Can anyone help with this. A couple of days ago I installed the new TelegramBot from simonrg. Everything went very well and works fine now.
Now I tried to do the same for my parents, but the dtgbot doesn't start up. With the command: sudo service dtgbot start, it says: Starting Telegram....
But nothing happens. When I try: sudo service dtgbot status it says: dtgbot is not running.
This is my log fil:
/usr/bin/lua5.2: /home/pi/dtgbot/dtgbot.lua:291: bad argument #1 to 'lower' (string expected, got nil)
stack traceback:
	[C]: in function 'lower'
	/home/pi/dtgbot/dtgbot.lua:291: in function 'HandleCommand'
	[C]: in ?
What went wrong? I can send messages to the id's with http, so my bot is working, only the dtgbot isn't.
Thnx!
G3rard
Domoticz version: No
Post by G3rard »
Did you try the chmod as described in this post http://www.domoticz.com/forum/viewtopic ... 279#p49972
Not using Domoticz anymore
Slayer007
Post by Slayer007 »
Yes, everything has it's rights
G3rard
Post by G3rard »
Did you try a reboot?
Slayer007
Post by Slayer007 »
Yep! And tried to remove everything and start over, but that also doesn't work. :-(
Edit1:
I think it does have something to do with authorization. Check both images. One of them is mine and one of them are my parents. I don't know in which authorization I have to look.
Edit2: I think it works now. The uservariable in domoticz was set on 1. When I changed it to 2 it started. After that I've got a lot of messages till it crashed again. I requested the latest integer uservariable and changed it 1 higher. After that it's still working. Hope for a long time!
Thnx for thinking. Maybe it was helpful to other people.
simonrg
Post by simonrg »
Slayer007 wrote:Yep! And tried to remove everything and start over, but that also doesn't work. :-(
Edit1:
The message shows unauthorized response from Domoticz, it looks like your Domoticz needs authentication, so not really a Telegram issue.
Which uservariable did you change?
