Siri / HomeKit support for Domoticz
nigels0
- Domoticz version: 3.8153
Re: Siri / HomeKit support for Domoticz
Thanks. That brought some back (the ones I removed) but not all.
- G3rard
- Target OS: -
- Domoticz version: No
I would suggest to delete the persist directory and reset the Homekit config once more.
Not using Domoticz anymore
h143
is there a way to show in homekit my gas usage en temperature of my sensors i can see in domoticz?
ivom74
Autostart
I got homekit also running. Only a little problem with auto starting. I only get it to work with manually:
cd homebridge
npm start run
the process is running and everything is working. I tried the scripts below but the devices are not recognized then.
Any idea?
thanks'
cd homebridge
npm start run
Any idea?
thanks'
Eduard wrote:As an addition to the roomid-config, i made a new domoticz.js with a parameter to disable the scenes...
{ "description": "Configuration file for Domoticz platform.", "platforms": [ { "platform": "Domoticz", "name": "Domoticz", "server": "127.0.0.1", "port": "8080", "roomid": 123 (0=no roomplan), "usescenes": 0 (0=off, 1=on) } ], "accessories": [ ] }
Also made HomeBridge start at reboot with a startup-script:Code: Select all
#!/bin/sh #/etc/init.d/homebridge.sh export PATH=$PATH:/usr/local/bin export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules case "$1" in start) exec forever start /home/pi/homebridge/app.js -p /home/pi/.forever ;; stop) exec forever stop /home/pi/homebridge/app.js ;; *) echo "Usage: homebridge.sh {start|stop}" exit 1 ;; esac exit 0To remove from startup at reboot:Code: Select all
sudo chmod 755 /etc/init.d/homebridge.sh update-rc.d homebridge.sh defaultsCode: Select all
update-rc.d -f homebridge.sh remove
ivom74
Domoticz is starting now automatically.
I use Eve app to add devices to switch by using SIRi.
How does it work? The devices I add with a alias name, where is the database stored? If i use a other iphone or ipad the commands are not recognized?
For each IOS hardware you have to programm the commands?
drogert
Re: Autostart
When using the "update-rc.d homebridge.sh defaults" Command I get this:ivom74 wrote:I got homekit also running. Only a little problem with auto starting. I only get it to work with manually:
cd homebridge
npm start run
Any idea?
thanks'
root@domoticzpi:~# update-rc.d -f homebridge.sh defaults
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'homebridge.sh' missing LSB tags and overrides
insserv: There is a loop between service watchdog and homebridge.sh if stopped
insserv: loop involving service homebridge.sh at depth 2
insserv: loop involving service watchdog at depth 1
insserv: Stopping homebridge.sh depends on watchdog and therefore on system facility `$all' which can not be true!
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
i got my HomeBridge running with autostart @reboot (rpi)
I used PM2 instead of forever. If you follow the instructions below, it will autostart HomeBridge after a reboot of you pi...
Edit /etc/init.d/pm2-init.sh so that
export PM2_HOME="/home/pi/.pm2"
(was export PM2_HOME="/root/.pm2" but this causes errors)
Reboot and check proceslist...
Should something look like...
Enjoy!
sudo npm install pm2 -g
cd ~/homebridge/
pm2 start app.js --name HomeBridge
pm2 save
pm2 startup raspberry
sudo su -c "env PATH=$PATH:/usr/local/bin pm2 startup raspberry -u pi"
sudo chmod +x /etc/init.d/pm2-init.sh
sudo update-rc.d pm2-init.sh defaultsCode: Select all
sudo reboot
pm2 list
│ App name │ id │ mode │ pid │ status │ restart │ uptime │ memory │ watching │
│ HomeBridge │ 0 │ fork │ 9092 │ online │ 0 │ 0s │ 9.113 MB │ disabled │
abplus
Every time I do npm run start I get the following. Can someone give me a hand please ?
If I add "roomid": "<2>" to the config.json I get a syntax error, roomid is undefined.
Thanks very much.
- Starting HomeBridge server...
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdn ... ceRegister>
Loading 1 platforms...
[Domoticz] Initializing Domoticz platform...
[Domoticz] Fetching Domoticz lights and switches...
Loading 0 accessories...
[Domoticz] There was a problem connecting to Domoticz.
Thanks very much.
- G3rard
- Target OS: -
You have to define room id as follows:
So without <> around it.
"roomid": "2"Not using Domoticz anymore
abplus
Thanks, but now I get:
undefined:9
"roomid": "2"
- G3rard
- Target OS: -
Share your complete config so we can have a look at it.
abplus
Thanks very much for your help:
If I take the roomid line out of the config I get this error:
Any ideas ?
"platforms": [
"name": "Domoticz",
"port": "8080"
"roomid": "2"
"accessories": [
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
A comma is missing after "8080"abplus wrote:Thanks very much for your help:
{ "description": "Configuration file for Domoticz platform.", "platforms": [ { "platform": "Domoticz", "name": "Domoticz", "server": "127.0.0.1", "port": "8080" "roomid": "2" } ], "accessories": [ ] }
Should be
"platforms": [
"name": "Domoticz",
"port": "8080",
"roomid": "2"
accessories": [
abplus
Thanks Eduard, its working now. Good learning experience for me !
ivom74
It was working but now I got some errors. I deleted the configs on my iphone and Ipad.
Try to change the room but it looks like it's ignoring the configs.
How can I see on what device it's hanging? Is it hanging on a device?
Can I delete the configs/database from homebridge on the raspberry device?
This question was asked before in this thread but I couldn't find the answer.
I hope someone can help.
pi@raspberrypi ~/homebridge $ npm run start
> [email protected] start /home/pi/homebridge
> node app.js
[Domoticz] Initializing device with name Eettafel lamp...
[Domoticz] Loaded services for Eettafel lamp
Cannot find secret key, creating One...
TCP server accepting connection on port: 51826
HAP Server is listening
[Domoticz] Initializing device with name Kast spotjes...
[Domoticz] Loaded services for Kast spotjes
TCP server accepting connection on port: 51828
[Domoticz] Initializing device with name RGB Kast...
[Domoticz] Loaded services for RGB Kast
TCP server accepting connection on port: 51832
[Domoticz] Initializing device with name Schemerlamp links...
[Domoticz] Loaded services for Schemerlamp links
TCP server accepting connection on port: 51838
[Domoticz] Initializing device with name Schemerlamp rechts...
[Domoticz] Loaded services for Schemerlamp rechts
TCP server accepting connection on port: 51846
[Domoticz] Initializing device with name Voork Plafond...
[Domoticz] Loaded services for Voork Plafond
TCP server accepting connection on port: 51856
events.js:85
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE
at exports._errnoException (util.js:746:11)
at Server._listen2 (net.js:1156:14)
at listen (net.js:1182:10)
at Server.listen (net.js:1267:5)
at Object.startServer (/home/pi/homebridge/node_modules/HAP-NodeJS/TCPServer.js:31:15)
at Object.publishAccessory (/home/pi/homebridge/node_modules/HAP-NodeJS/Accessory.js:13:28)
at createHAPServer (/home/pi/homebridge/app.js:169:15)
at /home/pi/homebridge/app.js:92:17
at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:109:6)
at Request.self.callback (/home/pi/homebridge/node_modules/request/request.js:373:22)
npm ERR! Linux 4.1.4-v7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.6
npm ERR! npm v2.11.2
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node app.js
npm ERR! You can get their info via:
npm ERR! npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/homebridge/npm-debug.log
- G3rard
- Target OS: -
Stop Homekit, delete the files in the persist folder and clear settings on iOS, see http://www.domoticz.com/forum/viewtopic ... 864#p49201. Then start Homekit again.
If that does not work, also delete the app you are using and reboot the phone.
ivom74
Thank you for your fast reply, i'll try that.G3rard wrote:Stop Homekit, delete the files in the persist folder and clear settings on iOS, see http://www.domoticz.com/forum/viewtopic ... 864#p49201. Then start Homekit again.
ivom74
Errors still there, how can I know what device it hangs on?G3rard wrote:Stop Homekit, delete the files in the persist folder and clear settings on iOS, see http://www.domoticz.com/forum/viewtopic ... 864#p49201. Then start Homekit again.
What can be the reason why it is loading many devices and then stops with an unknown error?
- G3rard
- Target OS: -
I don't know how many devices you have, but you can add them one at a time in the room in Domoticz and restart Homekit until you know which one gives the error.
