new devices in Mysensors 1.5
tbowmo
- Domoticz version: 2.2480
Could we get support for the new sensor / variable types, that has been added in Mysensors 1.5?
In particular I'm interested in getting V_RGB, V_RGBW, and V_HVAC_SETPOINT_COLD / V_HVAC_SETPOINT_HEAT to work in domoticz
The two first for LED strips for lightning in my Home theater, and the later for floor heating system, that I'm planing to use mysensors for.
Mysensors HW developer / hacker.
Creator of Sensebender Micro temperature / humidity sensor
- gizmocuz
Re: new devices in Mysensors 1.5
I think the V_RGB and V_RGBW should already work....
i think there is a typo in the 1.5 library, V_HVAC_SETPOINT_COLD does not exists, but V_HVAC_SETPOINT_COOL does
is there a sketch that is using them ?
tbowmo
There isn't a sketch for hvac yet, as I'm just preparing it. It's almost a chicken and egg situation
- gizmocuz
Well... if you can create the chicken, i might be able to support the egg
plz send me a PM when your chicken is cooked
betonishard
Tested it with 1.5.
Device gets recognized. You can add it as well to your switches section (automatically when you add it)... The lightbulb icon appears...
Receive the error message in the log:
Error: MySensors: Light command received for unknown node_id: 0
Receive an error message when i press the on /off switch (lightbulb icon).
Error sending switch command, check device/hardware
Here is my arduino code:
// Example sketch showing how to control an RGB Led Strip.
// This example will not remember the last rgb color set after power failure.
#include <MySensor.h>
#include <SPI.h>
#include <TimerOne.h>
#include "Adafruit_WS2801.h"
#ifdef __AVR_ATtiny85__
#include <avr/power.h>
#endif
#define node 14 //
#define strip2 0 // sensor number needed in the custom devices set up
int dataPin = 4; // 'yellow' wire
int clockPin = 3; // 'green' wire
Adafruit_WS2801 strip = Adafruit_WS2801(74, dataPin, clockPin);
long RGB_values[3] = {0,0,0};
const float mt = 0.247;
MySensor gw;
void setup()
Serial.begin(115200); // Not sure why this was included
// Initialize library and add callback for incoming messages
gw.begin(incomingMessage, node, true);
// Send the sketch version information to the gateway and Controller
gw.sendSketchInfo("RGB Node", "1.0");
// Register the sensor to gw
gw.present(strip2, S_RGB_LIGHT);
// start with 50% CPU usage. up this if the strand flickers or is slow
// Start up the LED counter
strip.begin();
// Update the strip, to start they are all 'off'
strip.show();
void loop()
// Alway process incoming messages whenever possible
gw.process();
void incomingMessage(const MyMessage &message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.type==V_RGB) {
// starting to process the hex code
String hexstring = message.getString(); //here goes the hex color code coming from through MySensors (like FF9A00)
long number = (long) strtol( &hexstring[0], NULL, 16);
RGB_values[0] = number >> 16;
RGB_values[1] = number >> 8 & 0xFF;
RGB_values[2] = number & 0xFF;
colorWipe(Color(RGB_values[0],RGB_values[1],RGB_values[2]), 30);
void colorWipe(uint32_t c, uint8_t wait) {
int i;
for (i=0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
/* Helper functions */
// Create a 15 bit color value from R,G,B
uint32_t Color(byte r, byte g, byte b)
uint32_t c;
c = r;
c <<= 8;
c |= g;
c <<= 8;
c |= b;
return c;
- gizmocuz
I'm trying to migrate to the 1.5 libraries, but am having an issue compiling (will reinstall)
But, how do you turn on/off this strip ? maybe you also need S_LIGHT ?
Hope to post some positive news here soon, the RGB(W) should create another type of switch in domoticz (like a zwave color device/applamp)
- gizmocuz
Getting closer:
The Zipato/Fibaro RGBW/Limitedless/Applamp, have additional commands:
- On
- Off
- Set Level
Is/Will this be supported for S_RGB/S_RGBW too ?
For instance, the sketch can remember the last set RGB/W color
when an V_LIGHT=0 "Off" command is received, it will send #000000 (or cut the power somehow)
when an V_LIGHT=1 "On" command is received, it will use the last set color
when an "V_DIMMER" command is received, it will take the last set color, and dim this (0-100%)
current state in domoticz:
- you will have to add the switch, and press edit to set the color, it will for now always set the level to 100%, for instance, when picking green, it will send #00FF00
This is my test sketch:
Changes are in beta version #2689
send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
sensor started, id=2, parent=0, distance=1
send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:RGB Test Node
send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
send: 2-2-0-0 s=0,c=0,t=26,pt=0,l=0,sg=0,st=ok:
Sketch started...
read: 0-0-2 s=0,c=1,t=40,pt=0,l=6,sg=0:7200FF
RGB command: 7200FF
read: 0-0-2 s=0,c=1,t=3,pt=0,l=3,sg=0:100
Dim command: 100
RGB command: 7200FF
read: 0-0-2 s=0,c=1,t=3,pt=0,l=2,sg=0:53
Dim command: 53
read: 0-0-2 s=0,c=1,t=2,pt=0,l=1,sg=0:0
Light command: 0
Light command: 0
read: 0-0-2 s=0,c=1,t=3,pt=0,l=2,sg=0:86
Dim command: 86
- On
- Off
- Set Level
#include <SPI.h>
#define CHILD_ID_STRIP 0 // sensor number needed in the custom devices set up
MySensor gw;
void setup()
gw.begin(incomingMessage);
gw.sendSketchInfo("RGB Test Node", "1.0");
gw.present(CHILD_ID_STRIP, S_RGB_LIGHT);
Serial.println("Sketch started...");
void loop()
gw.process();
Serial.print("RGB command: ");
Serial.println(hexstring);
else if (message.type==V_DIMMER) {
String dimlevel = message.getString(); //0-100%
Serial.print("Dim command: ");
Serial.println(dimlevel);
else if (message.type==V_LIGHT) {
String lstatus = message.getString(); //1=On, 0=Off
Serial.print("Light command: ");
Serial.println(lstatus);
- gizmocuz
how do you mean deprecated ? V_LIGHT/V_DIMMER are basic sets?vil1driver wrote:Hi,
Thanks for your hard work..
Could we continue using v_light and v_dimmer ?Ps: serial.begin is included in mysensors, it's useless to put this in sketchV_STATUS 2 Binary status. 0=off 1=on
V_LIGHT 2 Deprecated. Alias for V_STATUS.
V_PERCENTAGE 3 Percentage value. 0-100 (%)
V_DIMMER 3 Deprecated. Alias for V_PERCENTAGE. Dimmer value. 0-100 (%)
- gizmocuz
I know what it means, but where did you read that V_LIGHT/V_DIMMER are deprecated?
- gizmocuz
Okey, so its just a rename
I changed it in the domoticz code
but to your original question, is it working now ?
- gizmocuz
Okey, you have to upgrade to the latest beta
I also had compile errors, and I figured out I now have to use the latest Arduino IDE
I uninstalled the previous IDE, and removed the folder
then I installed the latest IDE
then I downloaded the 1.5 library, and copied this to the libraries folder of the ardiono ide, and skipped all existing files
then I could build everything again
Plz let me know if all is working well now
- gizmocuz
sweat, did you implement the on/off, level and write/read the last state in the eprom ?
Maybe you could propose an update to the original mysensors sketch
- gizmocuz
its because I miss-use the light type AC, which has 16 level (0-15)
would have been better if I miss-used the zwave dimmer type that supports 0-100
but as most kaku devices has 16 levels, would this not be OK?
- gizmocuz
Correct, see some posts up regarding the level
- gizmocuz
it does, just tested with the below sketch (you will get a node 254 (FE), make sure accept new hardware is enabled in the settings
* FakeMySensors
* This skecth is intended to crate fake sensors which register and respond to the controller
* Barduino, GizMoCuz 2015
#include <SPI.h>
// SPI Pins
#define CE_PIN 9
#define CS_PIN 10
// Wait times
#define LONG_WAIT 500
#define SHORT_WAIT 50
#define SKETCH_NAME "Test Light"
#define SKETCH_VERSION "v0.3"
//#define ID_S_LIGHT 4
// Global Vars
unsigned long SLEEP_TIME = 12000; // Sleep time between reads (in milliseconds)
boolean metric = true;
long randNumber;
// Instanciate MySersors Gateway
MySensor gw;
//Instanciate Messages objects
MyMessage msg_S_LIGHT(1,V_LIGHT);
void setup()
// Random SEED
randomSeed(analogRead(0));
// Start the gateway
gw.begin(incomingMessage,254);
gw.wait(LONG_WAIT);
Serial.println("GW Started");
// Send the Sketch Version Information to the Gateway
Serial.print("Send Sketch Info: ");
gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
Serial.print(SKETCH_NAME);
Serial.println(SKETCH_VERSION);
gw.wait(LONG_WAIT);
// Get controller configuration
Serial.print("Get Config: ");
metric = gw.getConfig().isMetric;
Serial.println(metric ? "Metric":"Imperial");
gw.wait(LONG_WAIT);
// Register all sensors to gw (they will be created as child devices)
Serial.println("Presenting Nodes");
Serial.println("________________");
Serial.println(" S_LIGHT");
gw.present(1,S_LIGHT);
gw.wait(SHORT_WAIT);
void loop()
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("#########################");
randNumber=random(0,101);
Serial.print("RandomNumber:");
Serial.println(randNumber);
// Send fake battery level
Serial.println("Send Battery Level");
gw.sendBatteryLevel(randNumber);
gw.wait(LONG_WAIT);
light();
gw.process();
gw.wait(SLEEP_TIME); //sleep a bit
void light(){
bool isLightOn = gw.loadState(1);
Serial.print("Light is: " );
if (isLightOn) {
Serial.println("On");
gw.send(msg_S_LIGHT.set(1));
} else {
Serial.println("Off");
gw.send(msg_S_LIGHT.set(0));
switch (message.type) {
case V_LIGHT:
gw.saveState(1, message.getBool());
Serial.print("Incoming change for ID_S_LIGHT:");
Serial.print(message.sensor);
Serial.print(", New status: ");
Serial.println(message.getBool());
break;
default:
Serial.print("Unknown/UnImplemented message type:");
Serial.println(message.type);
- gizmocuz
the present should already create a device, you do not have to force a send
- gizmocuz
Thanks for reporting, will be fixed in the next update (very soon)
LastSamurai
I tried to use a RGBW mysensor with domoticz. It correclty shows up and I can send off/on commands. What I can't do at the moment is change the color. No event seems to reach the sensor (or in this case actor) node when change the color and I can't pick an RGBW value in the web frontend (only RGB). I am using the newest update from the beta channel (2.2826). Any ideas?
LastSamurai
Has anyone already used this?
