One wire (brown or white) on a S0PCM port and the other one to ground?
Pulsemeter:
http://www.homewizard.nl/pulse-sensor-v ... meter.html
S0PCM:
https://sites.google.com/site/nta8130p1 ... er/webshop
The water meter used is an Itron Aquadis+:
Meter:ThinkPad wrote:By the way, could you make a picture of the bottom of the device (the side that sits on top of the meter)? I am interested in how this commercial sensor works (optical sensor/magnetic field sensor).
Yes, but it is not guaranteed to work on a Synology NAS, because it may lack the needed drivers (the S0PCM is a Arduino internally). 'kraades' also had that issue, but is now using the S0PCM without issues on a Raspberry Pi (where it is easier to get & install the required drivers, because the system is more open than a Synology NAS).Martinvdm wrote:Is this s0pcm instantly supported bu Domoticz?
Yes I'm using a S0PCM. Not sure what you mean by 'adding parts'. Shielding?ThinkPad wrote:Do you use it with a S0PCM? The inaccuracy may come from there, i have seen complaints before on this forum about the inaccuracy of the S0PCM.
Maybe some parts can be added between the sensor & S0PCM to prevent 'noise' or something on the cables.
