A huge thank you for your response.
Hi Jan,jan_nl wrote:If you install/activate a vpn on your router or nas, you don't need to worry about https.
Oke looks great for sure I will set up a VPN connection!jan_nl wrote:That's how I connect over 3g/3.5g (no 4g yet)
Anyway, I have a Synology NAS on which I played with VPN, which worked. Now my VPN runs on my FRITZbox, since that is directly connected to the internet.
According to Google: https://www.qnap.com/i/nl/trade_teach/c ... wone&cid=3, VPN can be configured on a QNAP NAS.
Whenever I need access to my Domoticz, I set up a VPN connection to my Fritzbox (router), either via wifi or 3g/4g and connect directly to Domoticz (or every other home network appliance).
I once switched my lights from somewhere in Spain, when my son was at home, worked like a charm.
Thanks for your info, I will try!jan_nl wrote:In principle there are no downsides at having your VPN always on, on your phone.
But remember, all network traffic from your phone will be redirected (normally) via the VPN, so if your upload bandwith at home is not very high, internet etc on your phone will be slow(er).
Advantage is, you also can use this VPN when using a less trusted WIFI connection somewhere.
I do not know pilot, so I do not know if pilot can set up a VPN connection. But I guess not.
unfortunately I have an Iphone6 and there is no tasker for this right?ThinkPad wrote:I use 'Tasker' on my Android phone to automatically connect to my home VPN when it notices that my phone has connected to the WiFi-network of the company i work at. Have a look on Google "tasker automatically connect vpn wifi".
So thats a tasker setting, looks great but again, I have no android.ThinkPad wrote: You could use it also the other way round: Connect to VPN when on wifi, unless <networkname> is in list of trusted networks (your home network for example).
Maybe I still will do this also, but it looks diffucult to me ad described in the wiki.ThinkPad wrote: For control over 3G i have made portforward (on a not so common port like '2834') and made a user with a strong(!!) password ('JJs0783xgx06' for example).
