Domoticz to control my coffee machine
- Domoticz version: 2.2563
Hello all,
I added WiFi to my coffee machine and connected it to Domoticz so I can prepare myself a coffee while I'm sitting at my desk or setup a timer to have a fresh coffee ready when I wake up
Adding WiFi to the machine
Using an esp8266 for the WiFi connection, I connected a transistor to each button of the machine, and connected the screen back light signal to my circuit in order to get the current status of the machine (back light color changes from green to red to yellow depending on what's going on).
The circuit is completely embedded in the machine and is totally invisible, it is connected to the machine power so it doesn't need any external buttons or anything. of course the machine works exactly as before, each button is still fully functional.
Programming
I use LUA (with a NodeMCU formware) on the esp8266, with a TCP client (to get commands from Domoticz) and a TCP server (to send out status at regular intervals).
On Domoticz I have four defined devices, three outputs and one input:
- Machine power
- Machine status
- Small coffee
- Large coffee
I'm using Dashticz as an alternative dashboard, and I made a custom bloc that gather information from these 4 devices into one, resulting in a nice looking and easy to use interface for my WiFi coffee machine:
Some links
Source code is here https://github.com/Bntdumas/DomoticzCoffeeMachine
My Dashticz fork is here: https://github.com/Bntdumas/Dashticz (I made some bug fixing in the original code and started adding a French translation for it, will do a pull request once it's a bit more polished)
Detailled project log is here: http://www.bntdumas.com/2015/07/15/how- ... e-part-1//
Imgur album: https://imgur.com/a/NZQ1L
It was a very fun project to work on, I'd love to hear your thoughts on it!
Benoit
Programming
- Machine power
- Machine status
- Small coffee
- Large coffee
Some links
Benoit
Re: Domoticz to control my coffee machine
great project! hanks for sharing!
Awesome, will try to work it out soon! Thank you very much for sharing
- kivster
You Sir, are my hero!
Great job! I'm going to have to try and replicate this!
Raspberry Pi + Domoticz + Aeon Labs Z-Wave USB
1x Aeon multi-sensor, 1x Popp dimmer, 1x Fibaro dimmer, HRT4-ZW thermostat/ASR-ZW receiver, home-made oil tank monitor - http://www.domoticz.com/forum/viewtopic.php?f=38&t=7275
- Domoticz version: 2022.2
A question. When I start my coffee machine it starts first cleaning. After that i have to put an empty cup. How did you deal with this?
I had the same issue, the machine rinses both when turned on and off.
However, the process can be stopped, during the rinsing cycle a stop button appears, which prevents any water from dripping.
Because there's no way for me to read the screen and look for the "stop" being displayed, I (programmatically) click on the button until the screen turns green. It worked great so far.
Because the rinse function is still useful, I turn on the machine during the night and let it turn itself off automatically (that's two rinse cycles).
But then you can't wake up with fresh coffee.
But still a very neath idea.
Oh but I canjan_nl wrote:But then you can't wake up with fresh coffee.
Check the function "tryStopRinse" in my lua code: https://github.com/Bntdumas/DomoticzCof ... achine.lua
-- Try to interrupt the rinsing cycle
function coffeeMachine.tryStopRinse()
print("tryStopRinse")
-- after one minute, stop clicking, there's something wrong...
tmr.alarm(1, 40000, 0, function()
tmr.stop(2)
end)
tmr.alarm(2, 1500, 1, function()
-- every 1.5s, try pushing the button stop if the screen
-- color is still yellow
if coffeeMachine.colorStr() == "yellow" then
coffeeMachine.pushButton(pinTopLeftButton)
elseif coffeeMachine.colorStr() == "green" or
coffeeMachine.colorStr() == "red" then
tmr.stop(2)
end)
Just want to say this is very awesome!!!
Wow nice video its simply great for preparing coffee.
- bewo
- Domoticz version: 2021.1
Simple Electronic Question
Great project bntdumas!
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
- Domoticz version: 2.3295
This is so COOL, great job!
