Dear forum readers,
I have a question about Dericam camera (H502W) support in Domoticz.
Is the Dericam supported by Domoticz or are there workarounds available? I did'nt see Dericam in the hardware compatibility list.
Thanks for any feedback!!
Best regards,
Hans Smulders
Dericam camera support (H502W)
- 1bigwink
Re: Dericam camera support (H502W)
Hi Hans,
I would say almost certainly yes. I've now got several cams, most of which are different models of cheap Chinese versions and they all work fine. This Dericam looks similar to one of mine (albeit better quality) and the firmware appears identical, so I have no doubt it will be ok. The settings described in my post here should work; http://www.domoticz.com/forum/viewtopic.php?f=4&t=6994
The only issue with ptz cams is that Domoticz does not yet support the ptz controls, just the video feed, although you can add it as a custom tab or create virtual switches to the send http commands (far from ideal though). You can still simultaneously access it via the camera interface though. For mine I just leave them in 'tour' mode. still playing with mine but given a couple of weeks I'm pretty sure I'll have something made that allows the ptz controls to be used in domoticz.
1x RasPi, RFXtrx433e, v5 Aeon ZWave, MD210R Door Contacts, MC335R PIRs, MD326 Siren, 25 x MiLight RGBW Bulb (4 x WiFi Contoller), 12 IP Cam, Fibaro FGS221, 5x433mhz venetian blind, 433mhz TV ceiling lift.
Next: Touchscreen + frontpage.html
Try:
http://IPADDRESS/snap.jpg?JpegSize=XL or http://IPADDRESS/tmpfs/auto.jpg in Domoticz.
Got the URL's from: http://www.ispyconnect.com/man.aspx?n=dericam
- sincze
- Domoticz version: 2024.4
Try:
http://IPADDRESS/tmpfs/auto.jpg gives me low-res image
http://IPADDRESS/tmpfs/snap.jpg gives me hi-res image
, a well is on 201C Dericam 1080P cam.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Great!!
It works, thank you very much!
Best regards,
Hans
Best regards,
Hans
- sincze
Lo res and Hi res Hans??
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hi Sincze,
Unfortunately my camera broke down yesterday evening. So it's hard to say what exactly the results were.
Now I have to buy a new camera. I was so close....
Damn!
Damn!
- sincze
Oh no
What did you do?? Flash the firmware??
Maybe I can help you save the device
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
