[DIY] Garden irrigation and learning project
Siewert308SW
Domoticz version: Stable
Re: [DIY] Garden irrigation and learning project
Post by Siewert308SW »
krizzz wrote:Cool project and Thanks for sharing! What were the costs for this whole project?
Thx... I think it's cool and functional.
Seems some of my neighbors think it's overkill :lol:
Total costs are €161
Keep in mind that i also used stuff i already got like garden hoses, hose coupling, wood, paint, stainless screws, sillicon kit and wiring.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
StanHD
Post by StanHD »
Of course some of your neighbours think it's overkill. That's just because they haven't done it or can't do it :mrgreen:
Nice project, well done :)
Python:- Broadlink RM2, Sonos
Siewert308SW
StanHD wrote:Of course some of your neighbours think it's overkill. That's just because they haven't done it or can't do it :mrgreen:
Thx for the heads up ;-)
Hardest part has begun now.
Writing a script which has to take account of different weather conditions over a longer period of time.
Hell, i want to automate and not manually switching it. :mrgreen:
The script i now temporally use (found in this forum) is great for one day.
But one perfect irrigation day doesn't mean you have to irrigate.
As i'm just a novice and will have do a lot of trial & error, copy/paste ect. ;-)
Setup:
- rootfs @ USB HDD
Siewert308SW
Just got noticed by my neighbor.
The moist sensors have arrived.
Unfortunately not at home, at the campside.
So I have to have some patience until I get home tomorrow night.
Setup:
- rootfs @ USB HDD
blackdog65
Post by blackdog65 »
*Update* on my project
The relay I have like yours is no good for me :( the range is too far from my house so it only gets the signal 50% of the time.
I need to use the MUCH more expensive Fibaro FGS222 Double Relay. But these do work 100%
The drippler hoses work well for me but my rainwater pump only supplies enough pressure for 1 hose at a time and I need 4. So I need to get another washing machine valve ( and another FGS222 ) :x
The good news is that the relays can be switched manually which frees up some of the hardware ( and space ) I was using. :D
The bad news is... if the 433mhz relay is out of range... those soil moisture sensors have no chance of working for me, unless I buy another FRXTRX.... growing tomatoes can be an expensive hobby :lol:
I'll try and post some pictures :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Siewert308SW
Just got home and put some aaa batteries in the two devices.
First experience is bad.
Enabled Imagetronix/Opus support on in settings.
And nothing happend then i hooked up the rfxcom to my laptop and fired up RFXCom manager.
The rfxcom does see the devices but aren't recognized.
I thuight the Imagintronox/Opus was supported.
Raspberyy b 2 with a RFXtrx433e
Domoticz version 2.2579 beta
243 firmware
RFXcom manager says the following:
Packettype        = UNDECODED RF Message
UNDECODED LACROSSE:1BA7BFF2C0
UNDECODED OREGON3:37FCFFFFFFFFFF7F
Setup:
- rootfs @ USB HDD
Siewert308SW
p.s
after 20min on of the devices appeared in domoticz after hooking up the rfxcom again and restarting domoticz
Setup:
- rootfs @ USB HDD
Siewert308SW
Have to go to a birthday party.
For now one device is recognized but last seen 14:15 while the time is now 15:30
Will let them both run for a while and see if domoticz picked them up when i come back.
One of the devices i gave a different ID by replacing the jumper inside the device.
Both are with 1.5mtr from my rfxcom.
So will report later.
Setup:
- rootfs @ USB HDD
Siewert308SW
Just got back and 4hr ago i could add one device but it hasn't updated since then.
The other device isn't detected by domoticz.
While Imagintronix is enabled in hardware settings.
Just hooked it up to the RFXCOM manager to see if both devices will appear again there.
After 15min still nothing in the rfxcom manager 16.0.0.5.
Then i enabled all possible settings and after 15min i saw one device...
Packettype    = TEMP_HUM
subtype       = TH12 - Imagintronix
                channel 2
Sequence nbr  = 14
ID            = 2
Temperature   = 25 °C
Humidity      = 5
Status        = Dry
Signal level  = 8
Battery       = OK
Only the reading is a bit offset.
25 degrees wil it's 20 degrees in my house and 5% humidity is right also.
Who got this device running under the same hardware and software as i wrote earlier?
And what did you do to get it working?
edit:
now i only recieve the following when the moist sensor is transmitting.
UNDECODED LACROSSE:12BFE740
For now i must say i'm done with this sensor.
everyone has it working out of the box and i don't seem to get them working.
Setup:
- rootfs @ USB HDD
blackdog65
Here's how my project is progressing ;)
4 switches for manual over-ride on the solenoid valves. Aeon labs sensor for temp/humidity/lux.
Inside box "A" **Temporary wiring!!** Power for light. Power for the 2 fibaro double relays. USB power for the Aeon labs sensor.
Inside box "B" Even messier as I waiting for my second valve to arrive. :(
Drippler hose No. 1 starting to sweat around the base of one of Mrs. Blackdog's beloved tomato plants :roll:
One of my 12v moisture sensors. Unlike most, they have a relay with NC NO contacts and a sensitivity trimmer. I've not figured out yet how to get a signal from these back to Domoticz. The range + walls is too much for 433mhz. I don't want another RasPi in there. Maybe a fibaro universal sensor? Any suggestions?
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Siewert308SW
Looks great...
Seem you have a lot more wiring and hardware involved ;-)
The manual override is good, i have virtual switch for on my Tablet to override the irrigation process.
I can't give any suggestions for any available or usable Moist sensors.
No experience with any other then the one i own now.
As for the 2 Opus xt300 moist sensors i own.
Which report moist humidity, and soil temp.
Which i modified the antenna and extended the existing antenna with a 17cm copper wire.
Before the mod the range was below 2mtr outside the house :-(
It had to get true a double brick wall and HR++ glass.
Some other 433mhz devices have the same issue.
With the mod the range increased to 20mtr and have no problems with receiving data.
Downside is that i couldn't use them.
Seems Opus changed protocols in their new batch and the RFXcom had troubles seeing the devices.
Reported this and new firmware for RFXcom is out.
Other downside is that it's raining all week now so i couldn't test the irrigation or the scripts i'm trying the write... ;-)
Need a bit more patience over here, hope to have those ready before the holidays start (in two weeks)
Over here i use some scripts which reports and calculates/override the irrigation process.
1x if upcoming showers for 1hr/12hr and 24hr.
1x WeatherUnderground script to predict UV/Humidity/Temp ect to enable some override switches.
WeatherUnderground is pretty accurate as one of the stations reporting is close to me.
Setup:
- rootfs @ USB HDD
Siewert308SW
For those who are interested and curious about what i'm upto regarding the script.
It's far from done but the first part is almost ready.
It's a copy and past from several scripts like, scrapping the weather data from weatherundeground, Flipstorm script (still need to implant) and some other snippets found on the internet.
I'm not a coder so it's a lot of trial and error ;)
First preview is ready.
This part of the script scraps the weather data and moist sensor data with a lot of user variables inorder to give the irrigation program a Go or NoGo
Now it's time to write some time triggers ect...
	script_time_irrigation.lua
	@author: Siewert Lameijer
	@since: 2015-06-24
	@version: 1.0
Garden Irrigation script
Variable to create:
- VarMayFollowProgram (type=integer, value=0)
time = os.date("*t")
    week       = tonumber(os.date("%V"));
	week       = tonumber(os.date("%m"));
    dayno       = tonumber(os.date("%d"));
    dayofweekno = tonumber(os.date("%w"));
    day       = tostring(os.date("%a"));
    hour       = tonumber(os.date("%H"));
    min       = tonumber(os.date("%M"));
-- Settings Begin
-- Lua script interval check, change the number 1 to every desired number in minutes
if((time.min % 1)==0)then
-- Logging: 0 = Off, 1 = On
local logging = 1
-- Weatherstation
-- Name of your Weatherstation widget which contains humidity,uv,temp and pressure
local weatherstation = 'Barometer'
-- Name of your Weatherstation Wind widget
local wind = 'Wind'
local rain = 'Regenmeter'
local uv = 'UV'
-- Moist Sensors
-- Name of your Moist Sensor device 1
local moistsensor1 = 'Vocht Sensor (border 1)'
-- Name of your Moist Sensor device 2
local moistsensor2 = 'Vocht Sensor (border 1)'
-- Switches and Virtual Switches
-- Name of your manual override virtual switch
local manoverride = 'Irrigatie Manual Override'
-- User Variables
-- Maximum amount of cycles your irrigation can be on
local VarMaxRun = '12'
-- Your target soil humidity percentage
local VarTarHum = '85'
-- Your Minumum soil temperature
local VarTarTempMin = '14'
-- Your Maximum soil temperature
local VarTarTempMax = '30'
-- Name of your User Variable for counting clear days: (type integer, Input 0)
local VarDays = 'Dagen'
-- Set your desired irrigation day, leave blank for no irrigation, set Mo, Tue, Wed, Thu, Fri, Sat or Sun
local VarDay1 = 'Mo'
local VarDay2 = 'Tue'
local VarDay3 = 'Wed'
local VarDay4 = 'Thu'
local VarDay5 = 'Fri'
local VarDay6 = 'Sat'
local VarDay7 = 'Sun'
-- Set your desired irrigation month, leave blank for no irrigation, set a number like 1 for January or 5 for May
local VarMonth1 = '1'
local VarMonth2 = '2'
local VarMonth3 = '3'
local VarMonth4 = '4'
local VarMonth5 = '5'
local VarMonth6 = '6'
local VarMonth7 = '7'
local VarMonth8 = '8'
local VarMonth9 = '9'
local VarMonth10 = '10'
local VarMonth11 = '11'
local VarMonth12 = '12'
-- Weather Variables
-- Set your prefered max rain fall
local RainCurrent = '0'
-- Set your prefered maximum temperature for irrigation (Higher doesn't trigger irrigation)
local WeatherTempMin = '15'
local WeatherTempMax = '27'
-- Set your prefered maximum UV for irrigation (Higher doesn't trigger irrigation)
local UV = '6'
-- Set your prefered max windspeed km/h (higher doesn't trigger irrigation)
local WindSpeed = '50'
-- Set your prefered max windgust km/h (higher doesn't trigger irrigation)
local WindGust = '150'
-- Settings END
--> Don't edit anything below this line or you could break the script!
-- Scrapping Weather Data from WeatherUnderground
-- Weatherstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[weatherstation]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherUV = tonumber(sWeatherUV);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV2 = tonumber(sWeatherUV2);
	if logging >= 1 then
		print("Irrigation [INFO]");
		print("Irrigation [Weather station] ==> Temperature is " .. sWeatherTemp .. " ");
		print("Irrigation [Weather station] ==> Humidity is " .. sWeatherHumidity .. " ");
		print("Irrigation [Weather station] ==> UV is " .. sWeatherUV .. " ");
		print("Irrigation [Weather station] ==> Pressure is " .. sWeatherPressure .. " ");
		print("Irrigation [Weather station] ==> UV2 is " .. sWeatherUV2 .. " ");
-- Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[wind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
		print("Irrigation [Windmeter] ==> Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
		print("Irrigation [Windmeter] ==> Winddirection is: " .. sWindDirection .. " ");
		print("Irrigation [Windmeter] ==> Windspeed is: " .. sWindSpeed .. " ");
		print("Irrigation [Windmeter] ==> Windgust is: " .. sWindGust .. " ");
		print("Irrigation [Windmeter] ==> Windtemperature is: " .. sWindTemperature .. " ");
		print("Irrigation [Windmeter] ==> Windfeel is: " .. sWindFeel .. " ");
-- Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[rain]:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
		print("Irrigation [Rainmeter] ==> Actual rain is: " .. sRainmeterCurrent .. " ");
		print("Irrigation [Rainmeter] ==> Total rain is: " .. sRainmeterTotal .. " ");
-- UV data:
sUV, sSolar = otherdevices_svalues[uv]:match("([^;]+);([^;]+)")
sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
		print("Irrigation [UV] ==> UV Strength is: " .. sUV .." ");
		print("Irrigation [UV] ==> Solar radiation is: " .. sSolar .." ");
-- Scrapping Temparature and moist humidity from moist sensor
-- Moist Sensor 1 data:
    smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[moistsensor1]:match("([^;]+);([^;]+);([^;]+)")
    smoistsensorTemp = tonumber(smoistsensorTemp);
    smoistsensorHumidity = tonumber(smoistsensorHumidity);
		print("Irrigation [MoistSensor 1] ==> Moist Temperature: " .. smoistsensorTemp .. " ");
		print("Irrigation [MoistSensor 1] ==> Moist Humidity: " .. smoistsensorHumidity .. " ");
-- Moist Sensor 2 data:
    smoistsensor2Temp, smoistsensor2Humidity = otherdevices_svalues[moistsensor2]:match("([^;]+);([^;]+);([^;]+)")
    smoistsensor2Temp = tonumber(smoistsensor2Temp);
    smoistsensor2Humidity = tonumber(smoistsensor2Humidity);
		print("Irrigation [MoistSensor 2] ==> Moist Temperature: " .. smoistsensor2Temp .. " ");
		print("Irrigation [MoistSensor 2] ==> Moist Humidity: " .. smoistsensor2Humidity .. " ");
-- Moist Sensor online check
-- Moist Sensor 1:
-- check if the moist sensor 1 is online
if (smoistsensorTemp == 0 or smoistsensorTemp == nil) then
    print('Moist Sensor 1 reports Temp is 0 or nil. Skipping Irrigation')
	commandArray[manoverride]='On'
if (smoistsensorHumidity == 0 or smoistsensorHumidity == nil) then
    print('Moist Sensor 1 reports Humidity is 0 or nil. Skipping Irrigation')
-- Moist Sensor 2:
-- check if the moist sensor 2 is online
if (smoistsensor2Temp == 0 or smoistsensor2Temp == nil) then
    print('Moist Sensor 2 reports Temp is 0 or nil. Skipping Irrigation')
if (smoistsensor2Humidity == 0 or smoistsensor2Humidity == nil) then
    print('Moist Sensor 2 reports Humidity is 0 or nil. Skipping Irrigation')
-- checking weather conditions so irrigation may proceed
if day == VarDay1 or day == VarDay2 or day == VarDay3 or day == VarDay4 or day == VarDay5 or day == VarDay6 or day == VarDay7 or
   month == VarMonth1 or month == VarMonth2	or month == VarMonth3 or month == VarMonth4 or month == VarMonth5 or month == VarMonth6 or month == VarMonth7 or month == VarMonth8 or month == VarMonth9 or month == VarMonth10 or month == VarMonth11 or month == VarMonth12
	and smoistsensorTemp >= tonumber (VarTarTempMin)
	--and smoistsensorTemp <= tonumber (VarTarTempMax)
	--and smoistsensorHumidity <= tonumber (VarTarHum)
	--and sRainmeterCurrent == tonumber (RainCurrent)
	--and sWeatherTemp >= tonumber (WeatherTempMin)
	--and sWeatherTemp <= tonumber (WeatherTempMax)
	--and sUV <= tonumber (UV)
	--and sWindSpeed <= tonumber (WindSpeed)
	--and sWindGust <= tonumber (WindGust)
then
		print("Irrigation [Program] ==> May continue");
	if(uservariables['VarMayFollowProgram'] == 0) then
	--if ( uservariables["VarMayFollowProgram"] == "0" ) then
	print("Irrigation [Program Value] ==> Updated");
	commandArray['Variable:VarMayFollowProgram']= '1'
		print("Irrigation [Program] ==> May NOT continue");
	if(uservariables['VarMayFollowProgram'] == 1) then
	commandArray['Variable:VarMayFollowProgram']= '0'
Setup:
- rootfs @ USB HDD
Siewert308SW
Second preview...
Got i bit closer to the end result.
Build in a manual override, improved value checks and improved the Go or No Go and added a desired time of day.
Now i have to build in a desired max run cycle with checks and overrides.
Fun stuff that lua... Never worked with it.
	@since: 2015-06-24
	@version: 1.0
User Variable to create:
- VarManOverride (type=integer, value=0)
- VarTimeCon (type=integer, value=0)
- VarWeatherCon (type=integer, value=0)
- VarTimeOfDayCurrent (type=integer, value=0)
- VarFollowsProgram (type=integer, value=0)
- VarMaxRun (type=integer, value=0)
- VarMoistCon (type=integer, value=0)
-- Settings Begin
local logging = 1
-- Weatherstation
local wind = 'Wind'
local uv = 'UV'
-- Moist Sensors
-- User Variables
-- Your Minumum soil temperature, Lower won't trigger irrigation
-- Your Maximum soil temperature, Higher won't trigger irrigation
-- Set your desired TimeOfDay for irrigation (Morning=0, Afternoon=1, Evening=2 or Night=3)
local VarTimeOfDay = '2'
-- Set your desired irrigation day, leave blank for no irrigation, set Mon, Tue, Wed, Thu, Fri, Sat or Sun
local VarDay1 = 'Mon'
local VarDay2 = ''
local VarDay6 = ''
local VarMonth1 = ''
local VarMonth2 = ''
local VarMonth3 = ''
local VarMonth10 = ''
local VarMonth11 = ''
local VarMonth12 = ''
-- Set your prefered max rain fall, higher won't trigger irrigation
-- Set your prefered minimum outside temperature for irrigation, Lower won't trigger irrigation
-- Set your prefered maximum outside temperature for irrigation, Higher won't trigger irrigation
-- Set your prefered maximum UV for irrigation, Higher won't trigger irrigation
local UV = '6'
-- Set your prefered max windspeed km/h, higher won't trigger irrigation
-- Set your prefered max windgust km/h, higher won't trigger irrigation
-- Settings END
		print("--------------------------------------------------------------------------------------")
		print("-- [Weather station] ==> Temperature is " .. sWeatherTemp .. " ");
		print("-- [Weather station] ==> Humidity is " .. sWeatherHumidity .. " ");
		print("-- [Weather station] ==> UV is " .. sWeatherUV .. " ");
		print("-- [Weather station] ==> Pressure is " .. sWeatherPressure .. " ");
		print("-- [Weather station] ==> UV2 is " .. sWeatherUV2 .. " ");
-- Windmeter data:
		print("-- [Windmeter] ==> Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
		print("-- [Windmeter] ==> Winddirection is: " .. sWindDirection .. " ");
		print("-- [Windmeter] ==> Windspeed is: " .. sWindSpeed .. " ");
		print("-- [Windmeter] ==> Windgust is: " .. sWindGust .. " ");
		print("-- [Windmeter] ==> Windtemperature is: " .. sWindTemperature .. " ");
		print("-- [Windmeter] ==> Windfeel is: " .. sWindFeel .. " ");
-- Rainmeter data:
		print("-- [Rainmeter] ==> Actual rain is: " .. sRainmeterCurrent .. " ");
		print("-- [Rainmeter] ==> Total rain is: " .. sRainmeterTotal .. " ");
-- UV data:
		print("-- [UV] ==> UV Strength is: " .. sUV .." ");
		print("-- [UV] ==> Solar radiation is: " .. sSolar .." ");
		print("-- [MoistSensor 1] ==> Moist Temperature: " .. smoistsensorTemp .. " ");
		print("-- [MoistSensor 1] ==> Moist Humidity: " .. smoistsensorHumidity .. " ");
		print("-- [MoistSensor 2] ==> Moist Temperature: " .. smoistsensor2Temp .. " ");
		print("-- [MoistSensor 2] ==> Moist Humidity: " .. smoistsensor2Humidity .. " ");
-- Moist Sensor 1:
    print('Irrigation [MoistSensor 1 ERROR] ==> Moist Sensor 1 reports Temp is 0 or nil. Skipping Irrigation')
	if(uservariables['VarMoistCon'] == 1) then
	commandArray['Variable:VarMoistCon']= '0'
		print("-- Irrigation [Program] ==> Moist temperature sensor (1) is Online");
	if(uservariables['VarMoistCon'] == 0) then
	commandArray['Variable:VarMoistCon']= '1'
    print('Irrigation [MoistSensor 1 ERROR] ==> Moist Sensor 1 reports Humidity is 0 or nil. Skipping Irrigation')
		print("-- Irrigation [Program] ==> Moist humidity sensor (1) is Online");
-- Moist Sensor 2:
    print('Irrigation [MoistSensor 2 ERROR] ==> Moist Sensor 2 reports Temp is 0 or nil. Skipping Irrigation')
		print("-- Irrigation [Program] ==> Moist temperature sensor (2) is Online");
    print('Irrigation [MoistSensor 2 ERROR] ==> Moist Sensor 2 reports Humidity is 0 or nil. Skipping Irrigation')
		print("-- Irrigation [Program] ==> Moist humidity sensor (2) is Online");
then
		print("-- Irrigation [Program] ==> Weather condition are looking good");
	if(uservariables['VarWeatherCon'] == 0) then
	print("-- Irrigation [Program] ==> Weather condition set Okay");
	commandArray['Variable:VarWeatherCon']= '1'
		print("-- Irrigation [Program] ==> Weather condition aren't looking good");
	if(uservariables['VarWeatherCon'] == 1) then
	print("-- Irrigation [Program] ==> Weather condition set False");
	commandArray['Variable:VarWeatherCon']= '0'
-- checking time of the day so irrigation may proceed
if (timeofday['Sunrise']) and (uservariables['VarTimeOfDayCurrent'] ~= 0) then
commandArray['Variable:VarTimeOfDayCurrent']= '0'
print("-- Irrigation [Program] ==> Time set to Morning")
if (time.hour >= 12) and (time.hour <= 17) and (uservariables['VarTimeOfDayCurrent'] ~= 1) then
commandArray['Variable:VarTimeOfDayCurrent']= '1'
print("-- Irrigation [Program] ==>  Time set to Afternoon")
if (time.hour >= 17) and (time.hour <= 20) and (uservariables['VarTimeOfDayCurrent'] ~= 2) then
commandArray['Variable:VarTimeOfDayCurrent']= '2'
print("-- Irrigation [Program] ==>  Time set to Evening")
if (time.hour >= 20) and (uservariables['VarTimeOfDayCurrent'] ~= 3) then
commandArray['Variable:VarTimeOfDayCurrent']= '3'
print("-- Irrigation [Program] ==>  Time set to Night")
if (uservariables['VarTimeOfDayCurrent']) == tonumber (VarTimeOfDay) then
print("-- Irrigation [Program] ==> Timeframe okay")
if (uservariables['VarTimeCon']) == 0 then
commandArray['Variable:VarTimeCon']= '1'
print("-- Irrigation [Program] ==> Awaiting for the right Timeframe")
if (uservariables['VarTimeCon']) == 1 then
commandArray['Variable:VarTimeCon']= '0'
-- Processing data into a usable yes or nogo for irrigation
		and (uservariables['VarWeatherCon']) == 1
		and (uservariables['VarMoistCon']) == 1
		--and (uservariables['VarMayFollowProgram']) == 0
		and (uservariables['VarFollowsProgram']) == 0
		and (uservariables['VarManOverride']) == 0
	then
		print("-- Irrigation [Program] ==> All okay, Irrigation may follow program")
		if (uservariables['VarMayFollowProgram']) == 0 then
		print("-- Irrigation [Program] ==> All ain't okay, Irrigation may not follow program")
	if (uservariables['VarMayFollowProgram']) == 1 then
	if (uservariables['VarManOverride']) == 1
	then
		print("-- Irrigation [Program] ==> Irrigation set to manual, programm stopped")
		if (uservariables['VarFollowsProgram']) == 1 then
		commandArray['Variable:VarFollowsProgram']= '0'
Setup:
- rootfs @ USB HDD
maluko
Post by maluko »
good project
it can be done with esp8266 and a relay board to control the valves, only if you have wifi there.
and than control on domoticz with virtual switch.
https://drive.google.com/file/d/0B9yx2L ... sp=sharing
ThinkPad
Post by ThinkPad »
Nice project :)
How long does the water keeps flowing if activated by the script? I don't know if those washing machine valves can handle being turned on for an hour or so. I think they will get quite warm.
Normally in a washing machine they are only operated for 2 minutes or so.
Siewert308SW
ThinkPad wrote:Nice project :)
Script aint ready yet so i can not test it yet.
For i only have a small script which looks at the the moist humidity and triggers when water is required.
Holiday time so i'm at the camping for 4 weeks.
Won't be writing all day, just enjoying the weather and beer :D
I don't know how long such a valve can be on as it was raining last week and this weekend so no irrigation required.
Only had it ON two times to see how long it took to get to a certain humidity level.
Which took 50min to get from 45% to 85%.
But i guess it gets a bit of cooling when the water flows by the membrane.
Lucky it's just a 6euro part so easily replaced when it dies ;)
The script version i got here is different from the one i posted earlier.
It's far from ready but hope to finish it soon.
A Preview of the current script you will find below.
- The scripts scraps the weather conditions from WeatherUnderground.
- For Dutch users i also inserted buienradar rain forecast for 6/12/24hr
- Also the scripts checks if the Moist sensors are online and sending the right values.
- It also checks if the right TimeOfTheDay is correct which you have to set in the script.
- Same counts for which days of week and months you want to be able to irrigate.
- You also can set your desired DayTime like morning, evening or night
- The script has a manual override to stop irrigation when needed
- When a irrigation cycle has completed it will trigger a override which will reset when your TimeFrame is correct again.
So for example you set irrigation ON on Monday and Thursday and the irrigation has completed on Monday then it won't trigger again on Monday until your on Thursday even if the all the targeted conditions say you must irrigate.
Further more the irrigation will be stopped when your desired humidity is reached within your desired Maximum Irrigation RunTime.
The RunTime when the pump is ON can be set manually i have it set to 60min.
So if the humidity target is reached with in the hour then the irrigation will stop.
But when the hour expires and the humidity target hasn't been reached then the irrigation will also stop.
Only the script won't stop when the weather conditions are going from a OKAY to a FALSE.
When the irrigation program has been started while the weather target conditions are good and suddenly the weather condition changes the irrigation will finish it cycle.
So it only stops when the humidity target or MaxRunTime has been exceeded.
I'm not a programmer so the script aint the cleanest but for me it will work and does the job... :D
As mentioned earlier, it's not finished yet.
	@since: 2015-06-24
	@version: 1.0
- VarMaxRunTime (type=integer, value=0)
- VarMoistOnline (type=integer, value=0)
- VarMoistOnlineHum (type=integer, value=0)
- VarMoistConTemp (type=integer, value=0)
- VarMoistConHum (type=integer, value=0)
- VarProgramOverride (type=integer, value=0)
- VarProgramRun (type=integer, value=0)
- VarTimeFrame (type=integer, value=0)
- VarManOverrideCon (type=integer, value=0)
Virtual Switches
- Manual Override
Hardware:
1x Moist Sensor which measures Temperature and Humdity
1x Switch for wireless controled WaterPump for irrigation
-- Settings Begin
--if((time.min % 1)==0)then
local logging = 1
-- WeatherUnderGround Variables
local wind = 'Wind'
-- Name of your Weatherstation Rain widget
-- Name of your Weatherstation UV widget
local uv = 'UV'
-- Switches and Virtual Switches Variables
local VitManOverride = 'Irrigatie Manual Override'
-- Name of your irrigation switch for water valve 1
local VarPump = 'Irrigatie 1 Check'
-- Moist Sensor Variables
local MoistSensor = 'Vocht Sensor (border 1)'
local VarTarTempMin = '12'
-- Amount of minuten/times we want to switch OFF irrigation after the program has started.
local VarMaxRunTime_off = 5
-- Day, Month and Time Variables
local VarTimeOfDay = '0'
local VarDay2 = ''
local VarDay4 = ''
local VarDay6 = ''
local WeatherTempMin = '13'
local WeatherTempMax = '25'
local UVMax = '6'
-- Settings END
	month       = tonumber(os.date("%m"));
		print("Irrigation [PROGRAM - Weather Conditions]");
		print("-- Irrigation ==> [WeatherStation] - Temperature is " .. sWeatherTemp .. " ");
		print("-- Irrigation ==> [WeatherStation] - Humidity is " .. sWeatherHumidity .. " ");
		print("-- Irrigation ==> [WeatherStation] - UV is " .. sWeatherUV .. " ");
		print("-- Irrigation ==> [WeatherStation] - Pressure is " .. sWeatherPressure .. " ");
		print("-- Irrigation ==> [WeatherStation] - UV2 is " .. sWeatherUV2 .. " ");
-- Windmeter data:
		print("-- Irrigation ==> [Windmeter] - Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection is: " .. sWindDirection .. " ");
		print("-- Irrigation ==> [Windmeter] - Windspeed is: " .. sWindSpeed .. " ");
		print("-- Irrigation ==> [Windmeter] - Windgust is: " .. sWindGust .. " ");
		print("-- Irrigation ==> [Windmeter] - Windtemperature is: " .. sWindTemperature .. " ");
		print("-- Irrigation ==> [Windmeter] - Windfeel is: " .. sWindFeel .. " ");
-- Rainmeter data:
		print("-- Irrigation ==> [Rainmeter] - Actual rain is: " .. sRainmeterCurrent .. " ");
		print("-- Irrigation ==> [Rainmeter] - Total rain is: " .. sRainmeterTotal .. " ");
-- UV data:
		print("-- Irrigation ==> [UV] - UV Strength is: " .. sUV .." ");
		print("-- Irrigation ==> [UV] - Solar radiation is: " .. sSolar .." ");
if  sRainmeterCurrent >= tonumber (RainCurrent)
	and sUV <= tonumber (UVMax)
then
		print("-- Irrigation ==> [Weather] - Weather conditions are looking good and ready for irrigation");
		print("-- Irrigation [Info] ==> Weather conditions aren't looking good");
-- Moist Sensor data:
    smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[MoistSensor]:match("([^;]+);([^;]+);([^;]+)")
		print("Irrigation [PROGRAM - Moist Sensor and Moist Conditions]");
		print("-- Irrigation ==> [MoistSensor] - Moist Temperature: " .. smoistsensorTemp .. " ");
		print("-- Irrigation ==> [MoistSensor] - Moist Humidity: " .. smoistsensorHumidity .. " ");
    print('-- Irrigation ==> [MoistSensor] - [ERROR] Moist Sensor reports Temp is 0 or nil. Skipping Irrigation')
	if(uservariables['VarMoistOnline'] == 1) then
	commandArray['Variable:VarMoistOnline']= '0'
	if(uservariables['VarMoistOnline'] == 0) then
	commandArray['Variable:VarMoistOnline']= '1'
if (smoistsensorHumidity <= 6 or smoistsensorHumidity >= 99 or smoistsensorHumidity == nil) then
    print('-- Irrigation ==> [MoistSensor] - [Error] ==> Moist Sensor reports wrong Humidity values. Skipping Irrigation')
	if(uservariables['VarMoistOnlineHum'] == 1) then
	commandArray['Variable:VarMoistOnlineHum']= '0'
	if(uservariables['VarMoistOnlineHum'] == 0) then
	commandArray['Variable:VarMoistOnlineHum']= '1'
-- checking moist conditions
if 	smoistsensorTemp >= tonumber (VarTarTempMin)
then
		print("-- Irrigation ==> [MoistSensor] - Moist Temp conditions are fine for irrigation");
	if(uservariables['VarMoistConTemp'] == 0) then
	commandArray['Variable:VarMoistConTemp']= '1'
	print("-- Irrigation ==> [MoistSensor] - Moist Temp conditions aren't good enough for irrigation");
	if(uservariables['VarMoistConTemp'] == 1) then
	commandArray['Variable:VarMoistConTemp']= '0'
if smoistsensorHumidity <= tonumber (VarTarHum)
then
		print("-- Irrigation ==> [MoistSensor] - Moist humidity conditions are fine for irrigation");
	if(uservariables['VarMoistConHum'] == 0) then
	commandArray['Variable:VarMoistConHum']= '1'
	print("-- Irrigation ==> [MoistSensor] - Moist humidity conditions aren to high, no irrigation required");
	if(uservariables['VarMoistConHum'] == 1) then
	commandArray['Variable:VarMoistConHum']= '0'
-- Checking Time Frame
		print("Irrigation [PROGRAM - TimeFrame]");
then
		print("-- Irrigation ==> [TimeFrame] - TimeFrame does match your desired TimeFrame");
	if(uservariables['VarTimeFrame'] == 0) then
	commandArray['Variable:VarTimeFrame']= '1'
		print("-- Irrigation ==> [TimeFrame] - TimeFrame doesn't match your desired TimeFrame");
	if(uservariables['VarTimeFrame'] == 1) then
	commandArray['Variable:VarTimeFrame']= '0'
	if (time.hour >= 7) and (time.hour <= 11) then
		if  (uservariables['VarTimeOfDayCurrent'] ~= 0) then
	if (time.hour >= 12) and (time.hour <= 18) then
		if (uservariables['VarTimeOfDayCurrent'] ~= 1) then
	if (time.hour >= 19) and (time.hour <= 22) then
		if (uservariables['VarTimeOfDayCurrent'] ~= 2) then
	if (time.hour >= 23) then
		if (uservariables['VarTimeOfDayCurrent'] ~= 3) then
		print("-- Irrigation ==> [TimeOfTheDay] - Time of the Day matches your desired irrigation value")
if (uservariables['VarTimeOfDayCurrent']) ~= tonumber (VarTimeOfDay) then
		print("-- Irrigation ==> [TimeOfTheDay] - Time of the Day doesnt match your criteria, Awaiting for the right Time of the Day")
		print("Irrigation [Program]");
-- Giving the irrigation program a Go or NoGo
		and (uservariables['VarTimeFrame']) == 1
		and (uservariables['VarMoistOnline']) == 1
		and (uservariables['VarMoistOnlineHum']) == 1
		and (uservariables['VarMoistConTemp']) == 1
	then
		print("-- Irrigation [Conditions] ==> All conditions seems to be okay, Irrigation may continue program")
    then
		print("-- Irrigation [Conditions] ==> Not all conditions seems to be okay, Irrigation may NOT continue program")
    then
-- New irrigation reactivated
	and (uservariables['VarProgramRun']) == 0
	and (uservariables['VarProgramOverride']) == 0
	and (uservariables['VarManOverrideCon']) == 0
	then
if (uservariables['VarFollowsProgram']) == 0 then
	commandArray['Variable:VarFollowsProgram']= '1'
		print("-- Irrigation [Program] ==> Irrigation Program Activated...")
-- Irrigation stopped after a full run cycle
if (uservariables['VarProgramRun']) == 1
	and (uservariables['VarProgramOverride']) == 1
then
		print("-- Irrigation [Program] ==> Irrigation Stopped, Maximum RunTime Exceeded...")
		print("-- Irrigation [Program] ==> Awaiting new TimeFrame...")
-- New timeframe so irrigation reactivated
	and (uservariables['VarProgramRun']) == 1
	then
if (uservariables['VarProgramOverride']) == 1 then
	commandArray['Variable:VarProgramOverride']= '0'
		commandArray['Variable:VarProgramRun']= '0'
		print("-- Irrigation [Program] ==> Irrigation Program Reactivated...")
-- Irrigation stoppen as the moist humidity exceed your desired value
if smoistsensorHumidity >= tonumber (VarTarHum)
	then
if (uservariables['VarProgramOverride']) == 0 then
	commandArray['Variable:VarProgramOverride']= '1'
	commandArray['Variable:VarMaxRunTime']= '-1000'
	commandArray[VarPump]='Off'
		print("-- Irrigation [Program] ==> Irrigation Program Stopped, Moist Humidity exceeded your desired value...")
-- Irrigation stoppen, Manual Override
if otherdevices[VitManOverride] == 'On'
	then
	commandArray['Variable:VarManOverrideCon']= '1'
	and (uservariables['VarManOverrideCon']) == 1
	then
		print("-- Irrigation [Program] ==> Irrigation Program Stopped, Manual Override")
if otherdevices[VitManOverride] == 'Off'
	then
	commandArray['Variable:VarManOverrideCon']= '0'
			print("-- Irrigation [Program] ==> Irrigation Program Reactivated, Manual Override OFF")
-- Irrigation Counter MaxRunTime and validate check
-- Debug logging.
function debug(msg)
		print('-- Irrigation [DEBUG] ==> ' .. msg)
-- Info logging.
function info(msg)
		print('-- Irrigation [Program] ==> ' .. msg)
-- Error logging.
function error(msg)
	print('-- Irrigation [ERROR] ==> ' .. msg)
-- Validates the configuration
function validate()
	result = true
	if not (uservariables['VarMaxRunTime']) then
		error('User Variable [' .. VarMaxRunTime .. '] doesnt exist.')
		result = false
	if not otherdevices[VarPump] then
		error('Device [' .. VarPump .. '] doesnt exist.')
		result = false
	if not (uservariables['VarFollowsProgram']) then
		error('User Variable [' .. VarFollowsProgram .. '] doesnt exist.')
		result = false
	return result
-- Tests if irrigation may start.
function may_update(VarIsPump)
	counter = (uservariables['VarMaxRunTime'])
	current_counter = counter
	-- set the counter.
	if VarIsPump and counter >= 0 then
		counter = math.min(1, counter + 1)
	elseif not VarIsPump and counter <= 0 then
		counter = math.max(VarMaxRunTime_off * -1, counter - 1)
		counter = 0
	if counter ~= current_counter then
		commandArray['Variable:VarMaxRunTime']= tostring(counter)
	result = false
	if VarIsPump and counter >= 1 then
		result = true
	elseif not VarIsPump and math.abs(counter) >= VarMaxRunTime_off then
		result = true
	return result
-- Start irrigation
function on_off(VarIsPump)
	update_allowed = may_update(VarIsPump)
	info('Irrigation Pump = [' .. otherdevices[VarPump] .. ']')
	if update_allowed then
		if otherdevices[VarPump] == 'Off' and VarIsPump then
 			commandArray[VarPump]='On'
			commandArray['Variable:VarProgramRun']= '1'
		elseif (otherdevices[VarPump] == 'On' and not VarIsPump) then
-- Is Irrigation  On.
function is_VarFollowsProgram_aan()
	result = false
	result = (uservariables['VarFollowsProgram'] == 1)
    return result
-- Starting Irrigation
if validate() then
	on_off(is_VarFollowsProgram_aan())
Setup:
- rootfs @ USB HDD
Siewert308SW
Here a updated version for dutch users.
Now i integrated the IsItGonnaRain script by Hans van der Heijden into mine.
So when there is rain expected within 24hr and more then you set in the settings then the Irrigation program is set to standby.
Also when the irrigation is running and there is more rain expected then you set in the settings then the irrigation will be stopped.
I also changed the Soil Moist Humidity trigger.
Irrigation will now be activated when a minimum humidity target is reached and irrigation will stop when the maximum is reached.
	@since: 2015-06-24
	@version: 1.0
- VarBuienRadarCon (type=integer, value=0)
Virtual Switches
- Manual Override
Hardware:
-- Settings Begin
local logging = 1
-- Location and minimum Rain Fall Variables For BuienRadar
-- Set your location by adding Lat/Lon
local lat = '53.338023'
local lon = '6.303114'
-- Set your minimum rain fall for in a periode of 24hr
local  VarMaxRainFall = '10'
local wind = 'Wind'
local uv = 'UV'
local VarTarHum = '80'
-- Your minumim moist humidity percentage from which the irrigation will start
local VarMinHum = '55'
local VarTarTempMax = '25'
local VarMaxRunTime_off = 60
local VarDay2 = ''
local VarDay4 = ''
local VarDay6 = ''
local UVMax = '6'
-- Settings END
-- Windmeter data:
-- Rainmeter data:
-- UV data:
then
then
if smoistsensorHumidity <= tonumber (VarMinHum) or smoistsensorHumidity == tonumber (VarMinHum)
then
		print("-- Irrigation ==> [MoistSensor] - Your Soil is dry and needs irrigation");
	print("-- Irrigation ==> [MoistSensor] - Soil humidity is fine, no irrigation required");
-- Checking Buienradar
		print("Irrigation [PROGRAM - Buienradar]");
    tempfilename = '/var/tmp/rain.tmp'
    totalrain = 0
    rainlines = 0
   function IsItGonnaRain( minutesinfuture )
       url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
       read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
       file = io.open(tempfilename, "r")
       while true do
          line = file:read("*line")
          if not line then break end
          linetime=string.sub(tostring(line), 5, 9)
          linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
          difference = os.difftime (linetime2,os.time())
          if ((difference > 0) and (difference<=minutesinfuture*60)) then
             rain=tonumber(string.sub(tostring(line), 0, 3))
             totalrain = totalrain+rain
             rainlines=rainlines+1
       file:close()
       averagerain=totalrain/rainlines
       return(averagerain)
    function round(num, idp)
       local mult = 10^(idp or 0)
       return math.floor(num * mult + 0.5) / mult
-- Is it gonna rain for the upcoming 24hr YES/NO
       minutes=1440
       RainPrediction = IsItGonnaRain(minutes)
       RainmmHour=10^((RainPrediction-109)/32)
       if RainPrediction >= tonumber (VarMaxRainFall) then
          verw = 3
		  if (uservariables['VarBuienRadarCon']) == 1  then
		  commandArray['Variable:VarBuienRadarCon']= '0'
			print('-- Irrigation ==> [RAIN] - Expected '..RainPrediction..' within 24 hours.')
          verw = 2
		  if (uservariables['VarBuienRadarCon']) == 0  then
		  commandArray['Variable:VarBuienRadarCon']= '1'
			print('-- Irrigation ==> [RAIN] - No rain or little rain expected within 24 hours.')
then
		print("-- Irrigation ==> [TimeFrame] - Time of the Day matches your desired irrigation value")
		print("-- Irrigation ==> [TimeFrame] - Time of the Day doesnt match your criteria, Awaiting for the right Time of the Day")
		and (uservariables['VarBuienRadarCon']) == 1
	then
    then
    then
	then
then
	then
-- Irrigation stopped as the moist humidity exceed your desired value
	then
	then
-- Irrigation stoppen, Rain Expected
if (uservariables['VarBuienRadarCon']) == 0 and (uservariables['VarProgramRun']) == 1
	then
		print("-- Irrigation [Program] ==> Irrigation Program Stopped, Rain Expected...")
	then
		print("-- Irrigation [Program] ==> Irrigation Program Reactivated, No More Rain Expected...")
	then
	then
-- Debug logging.
function debug(msg)
-- Info logging.
function info(msg)
-- Error logging.
function error(msg)
function validate()
	result = true
		result = false
		result = false
		result = false
	return result
	-- set the counter.
		counter = 0
	result = false
		result = true
		result = true
	return result
-- Start irrigation
	result = false
    return result
if validate() then
	if logging >= 1 and (uservariables['VarMayFollowProgram']) == 0
	then
		print("-- Irrigation [Standby] ==> Irrigation Program on Standby")
	if logging >= 1 and (uservariables['VarMayFollowProgram']) == 1
	then
		print("-- Irrigation [Standby] ==> Already Irrigated, Irrigation Program on Standby and awaiting new cycle")
Setup:
- rootfs @ USB HDD
Siewert308SW
@blackdog65
Your water valve, is it a f-11 or f14?
I can't find any reverence but i have a f-11 earlier this week i tried to fine tune the little sprinkler.
But i couldn't get the right. something block the pressure.
So i removed the regulator and that didn't help.
Then i connected the water supply directly to irrigation and all work with enough water pressure.
So i think the valve is decreasing the water pressure.
Setup:
- rootfs @ USB HDD
blackdog65
Do you mean this? :?
http://www.ebay.co.uk/itm/360771645775? ... EBIDX%3AIT
I'm not sure which type it is but I have problems with low pressure as I use rain water + pump. The drippler hose was pretty poor with low pressure so I tried this today
http://www.amazon.co.uk/Green-Porous-So ... ation+hose
and it works brilliantly! :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Siewert308SW
blackdog65 wrote:Do you mean this? :?
Yep, thats what i ment.
Looks like the valve decreases the pressure and over the entire 15mtr the water pressure is to low.
When i hook up the water supply directly to the irrigation then all is fine and i have enough water pressure.
Setup:
- rootfs @ USB HDD
