Connect Nefit Easy to Domoticz?
pepijn
Today my new Nefit Easy thermostat has been installed. It would be great to read the data from my central heating unit and display this in Domoticz. I started running Wireshark right away. The app and thermostat seems to communicate with a central server from Bosch using XMPP. On the thermostat port 80 is available.
Does anyone have some experience already?
cwavontuur
- Target OS: -
Re: Nefit Easy
Sorry to say, no experience yet
but my Vallaint Hr Solide plus / valiant Calormatic are on my short list for trying to get the burnhours into Domoticz.
I will try to go the Raspberry PI GPIO route.
Goodluck with your Nefit setup,
cwavontuur
cwavontuur
Holland
- Domoticz version: Beta Ch
Re: Nefit Easy
Ordered the Nefit Easy yesterday. Hopefully I can start with testing by the end of the week
- gizmocuz
Re: Nefit Easy
Are you sure port 80 is open on the thermostat ? I can not seem to connect
Do you had any luck yet implementing it?
drogert
Re: Nefit Easy
Does anyone has any luck with this? I also have a nefit easy and I am very happy with it. But I would love to have this information into domoticz.
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
pepijn
Re: Nefit Easy
I'am still working on this but had a little lack of time. The Nefit Easy uses encrypted XMPP to communicate with the app. As expected Nefit is not willing to release any documentation. I posted a feature request at Nefit to release some API, if others can do the same this might encourage Nefit to do so.
drogert
Re: Nefit Easy
I filled out a form on the nefit website asking for the release of the API. Maybe they will listen
I learned that the webapplication will come out in the second quarter of 2014. http://www.nefit.nl/consument/service/e ... ikbaarheid
Maybe there lies the answer?
drogert
Re: Nefit Easy
Like I said, I sent an email with the question if nefit could release an API or something like that.
I've got an answer an it was like a machine/robot filled it in, but this is what they said:
I cannot understand this attitude
! I mean, what will they loose and what will/can the competition do with this information.
Maybe we can scrape the website in some way when it goes live and put that into domoticz?
To translate: NO!Geachte heer,
Nefit kan de gevraagde gegevens niet prijsgeven, dit om zo haar producten te beschermen tegen concurrenten.
Wij vertrouwen er op u voldoende te hebben geïnformeerd.
Met vriendelijke groet,
Niek Roufs
Consumentenservice
drogert
Re: Nefit Easy
I got a update for IOS today for the Nefit Easy app and it will now show my gas consumption(hot water and heating) in a graph. It also shows the total consumption for the past month/year. I can only see from end may till now so my guess is that they updated the firmware of the thermostat just recently. I understand that the nefit easy uses encryption, but you have to fill in a code and a password in the app, so could you decrypt the data with this, right? Or am I mistaken. Furthermore, there is a Android app which could be easier to " hack" and get the data this way? Just throwing it out there ..
- mvveelen
Re: Nefit Easy
Any progress? I'm willing to buy a Nefit Easy, but only if I can use it with Domoticz. So I will keep following this thread to see if there is any progress
I just got a reply from Nefit:
I'll translate it for you guys:Geachte heer .....,
Wij zijn niet aangesloten bij Domoticz. Uiteraard geven wij uw verzoek door aan onze ontwikkelaars. Momenteel is onze Easy thermostaat via iOS en Android te regelen. Er zal op korte termijn een webbrowserregeling aan worden toegevoegd.
Consumentenservice
In my request I mentioned Domoticz, that's it. And also I mentioned that they could have more buyers of the Easy if this device could work together with Domoticz. So maybe.... But I think the wepapplication could be the first step, don't you think?Dear sir,
we don't have any connections with Domoticz. Ofcourse we will send your request to our developers. At this moment the Easy thermostat can be controlled by iOS and Android. In a short while there will be added a webapplication.
Kind regards,
etc
jannl
- Domoticz version: 2025.5.x
Re: Nefit Easy
I have an Easy as well. I only want to show the room temp with Domoticz (if possible). Main reason for the Easy is that we are now able to switch on the heating when going home, because the time we go home vary a lot. Together with the clock-program this works fine for us.
I can not imagine Domoticz could add something the Easy can not do by itself already.
Re: Nefit Easy
It is possible to decompile the app. from nefit so you can check out the code by yourself
- mvveelen
Re: Nefit Easy
Well, I have the Nefit Easy now, but I'm sure I can't decompile the app myself ....
ThinkPad
Re: Nefit Easy
What about sniffing the traffic from the Nefit with something like Wireshark? Hook up a spare router so that all traffic is sent trough your PC, and then capture everything that passes by.
They probably have the traffic running via HTTPS/SSL, so i don't think you will see something like:
That would be too easy
But you could always try and see if you can discover something.
I don't have personal experience sniffing traffic like that, but i know 'Wireshark' is used a lot for such activities.
Edit: Doh, i didn't read the first post good enough. I see you already tried Wireshark...
http://www.nefit.com/?thermostat=abc123&roomtemp=19.2I don't have personal experience sniffing traffic like that, but i know 'Wireshark' is used a lot for such activities.
Re: Nefit Easy
I am also highly interested in a community app for the Nefit/Easy.
Funny thing is; when I go to the ip-address of my Easy Thermostat in plain http (= port 80)
I get : "The operation couldnt be completed. Invalid argument."
"Invalid argument" seems to be not much, but at least the bugger seems to give a response,
saying: try again with a valid argument...
drogert
Re: Nefit Easy
So, I see this topic is solved?! Is it working?
ThinkPad
Re: Nefit Easy
As far as i know there is still no API for the Nefit Easy. I will remove the '[SOLVED]' part from the title
- kraades
- Domoticz version: Stable
Re: Connect Nefit Easy to Domoticz?
Can this tool be used to find out more about the xmpp encryption?
http://tanguy.ortolo.eu/blog/article69/ ... -explained
Goals
XMPPloit is designed to serve as a transparent man-in-the-middle between an XMPP client and its XMPP server, in order to force the client not to encrypt its communications, so that it is possible to read them and modify them on-the-fly.
That allows to force the client to use a clear text authentication mechanism, to display its login and password, and to modify any message it sends or receives.
Goals
dorenberg
- Domoticz version: 4.10982
is there any new news regarding the Nefit Easy?
