You were right - Thank youEduard wrote:I think you have to use the room idx...simon_rb wrote:For some reason it is only importing my scenes and none off the switches from the room. I called the room 123 just like in the code above. I have since removed the " from the 123 and that hasn't made any difference. Am I right in thinking its the room name and not some other ID like the IDX for the switches. Sorry I've taken some much of every bodies time up on here. I do sincerely appreciate it.
Siri / HomeKit support for Domoticz
- Target OS: -
Re: Siri / HomeKit support for Domoticz
I get 'command not found' if i follow your advicegizmocuz wrote:is 'forever' not a better way to auto start nodejs applications?
(almost done with a new stable release, and installed forever on the sdcard image)
(homebridge is installed, but not active when you burn the sdcard image)
npm install forever
cd homebridge
forever start app.js
pi@domoticzpi ~ $ npm install forever
[email protected] node_modules/forever
├── [email protected]
├── [email protected] ([email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected])
pi@domoticzpi ~ $ cd homebridge
pi@domoticzpi ~/homebridge $ forever start app.js
-bash: forever: command not found
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
- Target OS: -
Try sudo npm install forever -g
Thnx for the quick reply. It seems to installed correctly now, but what does this message means: "Your script will exit if it does not stay up for at least 1000ms"?simon_rb wrote:Try sudo npm install forever -g
pi@domoticzpi ~/homebridge $ sudo npm install forever -g
/usr/local/bin/forever -> /usr/local/lib/node_modules/forever/bin/forever
[email protected] /usr/local/lib/node_modules/forever
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: app.js
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
- Target OS: -
No probs, glad I can help others like they have me.
I think that means if it crashes within that time it won't restart it. However if it doesn't crash it will restart it if it lasts longer than that.
- Target OS: -
Is anybody else getting a lot of devices that fail to sync and then disappear never to be seen again. This has happened after entering the correct pin. How do we get them back other then restarting the whole process again?
Cheers
Cheers
- Domoticz version: 4.10538
Simon, i had the same issue with a scene. Do not know how to resolve this. Deleting persistent data does not help?
I have the same, missing about 15 devices and haven't find out how to get them back... If someone have a solution? Please share with us!
I do have a additional thing the cpu of my pi go's after some time to 99,99%. Think idly has to do with this server..
Does someone noticed the same?
I noticed that Eve does not updates the status of the switches after a switch is turned on or off using Siri. Also when using another app (like Pilot) or Domoticz website Eve I have the same issue.
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
As an addition to the roomid-config, i made a new domoticz.js with a parameter to disable the scenes...
"description": "Configuration file for Domoticz platform.",
"platforms": [
"platform": "Domoticz",
"name": "Domoticz",
"server": "127.0.0.1",
"port": "8080",
"roomid": 123 (0=no roomplan),
"usescenes": 0 (0=off, 1=on)
"accessories": [
- Domoticz.js.zip
- (3.09 KiB) Downloaded 122 times
- Target OS: -
I also had to reset the HomeKit data on my phone. Means you have to start again. Problem is when you start again the same thing happens and you lose more devices. It's a big circle and until we find a fix I think I'm going to abandon this project - just too buggy at the mo...pvm wrote:Simon, i had the same issue with a scene. Do not know how to resolve this. Deleting persistent data does not help?
- Target OS: -
I think this is the way the home bridge server is setup. I don't think it gets feedback at the mo. However I think it's being worked on..Heisenberg wrote:I noticed that Eve does not updates the status of the switches after a switch is turned on or off using Siri. Also when using another app (like Pilot) or Domoticz website Eve I have the same issue.
- Target OS: -
Great work. I may use the no scene file. I tend to use switches that activate scenes rather than use scenes directly.Eduard wrote:As an addition to the roomid-config, i made a new domoticz.js with a parameter to disable the scenes...
{ "description": "Configuration file for Domoticz platform.", "platforms": [ { "platform": "Domoticz", "name": "Domoticz", "server": "127.0.0.1", "port": "8080", "roomid": 123 (0=no roomplan), "usescenes": 0 (0=off, 1=on) } ], "accessories": [ ] }
Also made HomeBridge start at reboot with a startup-script:Code: Select all
#!/bin/sh #/etc/init.d/homebridge.sh export PATH=$PATH:/usr/local/bin export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules case "$1" in start) exec forever start /home/pi/homebridge/app.js -p /home/pi/.forever ;; stop) exec forever stop /home/pi/homebridge/app.js ;; *) echo "Usage: homebridge.sh {start|stop}" exit 1 ;; esac exit 0
To remove from startup at reboot:Code: Select all
sudo chmod 755 /etc/init.d/homebridge.sh update-rc.d homebridge.sh defaults
update-rc.d -f homebridge.sh remove
I noticed that the devices that are being used by 1 HomeKit user, can not be used by another user. For example:
I have a roomplan with 3 devices, D1, D2 & D3.
1 iPhone with iCloud-user A, added D1 & D2
1 iPad with iCloud-user B, added D3 but cannot add D1 & D2, because they are already used by user A...
Another thing i noticed is that the devices stored in HomeKit are not synced between my devices; i have to make a new home in Eve, but cannot add the devices already added on my other device
- Target OS: -
I haven't noticed that. I added everything using eve on my iPhone and Siri on my iPad can control all devices. I also added my wife as a user and her iphone can control the devices using Siri also. To be honest once a device has been registered it works well, it's just when you try and register and it fails the device disappears forever and that's the reason I'm not gonna spend anymore time on it.Eduard wrote:I noticed that the devices that are being used by 1 HomeKit user, can not be used by another user. For example:
Do you both use the same iCloud-account?simon_rb wrote:I also added my wife as a user and her iphone can control the devices using Siri also.
This is what I get:Code: Select all
pi@domoticzpi /etc/init.d $ update-rc.d homebridge.sh defaults
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'homebridge.sh' missing LSB tags and overrides
insserv: There is a loop between service monit and homebridge.sh if stopped
insserv: loop involving service homebridge.sh at depth 2
insserv: loop involving service monit at depth 1
insserv: Stopping homebridge.sh depends on monit and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
- Target OS: -
No, we have our own. Saying that I just tested it and it hasn't worked lol. I'm sure it did yesterday - maybe I used her iPad which is uses my iCloud account.Eduard wrote:Do you both use the same iCloud-coount?simon_rb wrote:I also added my wife as a user and her iphone can control the devices using Siri also.
I also still have problems running 'Forever' after reboot. Also tried to add it to my crontab, but this won't work either.Heisenberg wrote:This is what I get:Code: Select all
pi@domoticzpi /etc/init.d $ update-rc.d homebridge.sh defaults update-rc.d: using dependency based boot sequencing insserv: warning: script 'homebridge.sh' missing LSB tags and overrides insserv: There is a loop between service monit and homebridge.sh if stopped insserv: loop involving service homebridge.sh at depth 2 insserv: loop involving service monit at depth 1 insserv: Stopping homebridge.sh depends on monit and therefore on system facility `$all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header pi@domoticzpi /etc/init.d $
It has something to do with userrights because the persist directory in homebridge will not be created when starting it via startupscript or crontab.
Now is am starting it manually via ssh...
sudo forever start /home/pi/homebridge/app.js
Hi All,
Giving this a go as it looks great. I have followed the Wiki but get the following error when doing the last steps:
OK so I have restarted the the pi and I get the following error now...
and this is the log...
Have now run:
instead of
no joy
pi@domoticzpi ~/homebridge $ npm run start
Illegal instruction
> [email protected] start /home/pi/homebridge
> node app.js
module.js:338
throw err;
Error: Cannot find module 'node-persist'
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object.<anonymous> (/home/pi/homebridge/app.js:3:15)
at Module._compile (module.js:460:26)
at Object.Module._extensions..js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:501:10)
npm ERR! Linux 3.18.11+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.1
npm ERR! npm v2.5.1
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node app.js
npm ERR! You can get their info via:
npm ERR! npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/homebridge/npm-debug.log
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'run', 'start' ]
2 info using [email protected]
3 info using [email protected]
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info prestart [email protected]
6 info start [email protected]
7 verbose unsafe-perm in lifecycle true
8 info [email protected] Failed to exec start script
9 verbose stack Error: [email protected] start: `node app.js`
9 verbose stack Exit status 1
9 verbose stack at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:213:16)
9 verbose stack at EventEmitter.emit (events.js:110:17)
9 verbose stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:14:12)
9 verbose stack at ChildProcess.emit (events.js:110:17)
9 verbose stack at maybeClose (child_process.js:1008:16)
9 verbose stack at Process.ChildProcess._handle.onexit (child_process.js:1080:5)
10 verbose pkgid [email protected]
11 verbose cwd /home/pi/homebridge
12 error Linux 3.18.11+
13 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
14 error node v0.12.1
15 error npm v2.5.1
16 error code ELIFECYCLE
17 error [email protected] start: `node app.js`
17 error Exit status 1
18 error Failed at the [email protected] start script 'node app.js'.
18 error This is most likely a problem with the homebridge package,
18 error not with npm itself.
18 error Tell the author that this fails on your system:
18 error node app.js
18 error You can get their info via:
18 error npm owner ls homebridge
18 error There is likely additional logging output above.
19 verbose exit [ 1, true ]
sudo npm install -g node-persist
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
