Has someone tested Domoticz running on a system using OSMC already?
Any issues experienced or perfomance issues ?
OSMC and Domoticz on Raspberry 2
- tommit01
- Domoticz version: multiple
1 x RPi3
4 x RPI
3 x RPi2
1 x RPI2 + Win 10 IoT (experimental device)
2 x RPI2 Raspbian "Jessie" + Domoticz (for tenants)
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam NOIR
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
RFXtrx 433 E FW 1020
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
Re: OSMC and Domoticz on Raspberry 2
I run this setup using a B+ and have face no issues.
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
Accenta Gen4 Security System Integration
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Blog: http://www.shyambhundia.com
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Can you explain how to do it?
I just installed following this steps:
- installed OSMC from image on a new SD card
- do the first setup, for language and network
- followed the instruction here, https://www.domoticz.com/wiki/Installin ... spberry_PI (some steps does not work, since it's a customized distribution of Raspbian Jessie)
- changed in domoticz.sh the port from 8080 to 808x since Kodi uses 8080
but when I try to reach Domoticz, I can't see anything on the selected port.
Is it possible to install OSMC on a SD card where Domoticz is laready installed? I have't found such info...
What does the kodi log say?
All done.
after two times, I've got it working.
Don't know what was the error, but now is working, repeated exactly what's on the installation Wiki.
Also installed pi-hole as adblocking/dns.
On a RPi B+, waiting for RPi 3...
