How to use temperature adjustment option?
ThinkPad
Post by ThinkPad »
I am using a temperature + humidity sensor based on ESP8266 + DHT22: http://domoticz.com/forum/viewtopic.php ... 741#p40343
However, i have the idea that the temperature reported is too high. I tried to adjust the sensor (click 'Edit' underneath virtual temp sensor and then fill in adjustment). However, it doesn't seem to affect the indicated temperature?
How do i use this? I tried:
'-0.8'
'0.8'
'-0,8'
But none of these values seem to do anything. I also tried '-10' to see if it is because of the decimal, but that didn't do anything either.....
As a last resort i could do the calculation in my script, but Domoticz has the option already built in, so why not use that ;)
dannybloe
Re: How to use temperature adjustment option?
Post by dannybloe »
Not that I can answer your question but why don't you adjust the value in the esp8266 itself?
/me is heavily playing with the esp himself
ThinkPad
Post by ThinkPad »
Yeah i will probably do that in my script, but i am curious why Domoticz ignores the adjustment setting.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
It should work. But maybe not for all types of temperature sensors. I use -1.5 correction and it indeed is adjusted by 1.5 degrees.
ThinkPad
Post by ThinkPad »
I think it doesn't work for a virtual sensor then....
How can i do the adjustment in the Bash script i am using?
#!/bin/bash
# This script retrieves the temperature and humidity from the webpage
# generated by the code running on ESP8266 that is posted here
# http://harizanov.com/2014/11/esp8266-powered-web-server-led-control-dht22-temperaturehumidity-sensor-reading/
# Fill in variables
ESP_IP="192.168.4.248"
DOMO_IP="192.168.4.4"
DOMO_PORT="8084"
DOMO_IDX="121"
# Retrieve webpage and strip out relevant information and put information (position 13 & 16) into two variables (temp, hum)
curl -s http://$ESP_IP/dht22.tpl | grep "reading is" | awk '{print $13, $16;}' | sed 's/*C,//g' | while read temp hum
do
if awk "BEGIN {exit $hum <= 25 ? 0 : 1}"
then
   #echo "Dry"
    hum_status="2"
elif awk "BEGIN {exit $hum > 60 ? 0 : 1}"
then
    #echo "Wet"
    hum_status="3"
elif awk "BEGIN {exit (($hum >= 25)&&($hum <= 60)) ? 0 : 1}"
then
      #echo "Comfortable"
    hum_status="1"
    #echo "Normal"
    hum_status='0'
fi
# Send data to virtual sensor in Domoticz ("Temp + Humidity").
OUTPUT=`curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$DOMO_IDX&nvalue=0&svalue=$temp;$hum;$hum_status"`
done
I tried something like:
$tempcorrected = $temp-1.2
But that won't work...
oopee
Domoticz version: 3.x
Post by oopee »
The adjustment setting kicks in when the sensor value is updated next time.
ThinkPad
Post by ThinkPad »
gizmocuz told me at the (Dutch) Domoticz forum on Tweakers.net that the adjustment option only works for real, physical sensors. When you update a virtual sensor through JSON, the value is passed 1:1 to the database of Domoticz. And thus, ignoring the adjustment option.
So i have to fix it in my script. Will mark the topic as solved.
D'rMorris
Post by D'rMorris »
ThinkPad wrote:gizmocuz told me at the (Dutch) Domoticz forum on Tweakers.net that the adjustment option only works for real, physical sensors. When you update a virtual sensor through JSON, the value is passed 1:1 to the database of Domoticz. And thus, ignoring the adjustment option.
@ Thinkpad: one remark on the correction in the script. I would do the correction in a uservariable and use that in the script. This to avoid changing numerous scripts later. If you later want to change the correction, just change the uservariable and everything is updated automatically. Just my 2 cents ;)
janegils
Post by janegils »
I'm wondering why you can only adjust temperature values, and not humidity values.
Should be easy to add...
Running Domoticz on Ubuntu Linux server
RFXCOM_Transceiver
Aeon Labs Z-Stick S2
