Get data from Homewizard
Hello all,
I have a Homewizard running with several kaku devices. Because its hard to script against the homewizard I started to play arround with Domoticz.
I can get information or change a switch on the homewizard by sending a http url http://<homewizard-ip>/<password>/sensor.
Is it possible to send an http url from a (dummy) Domoticz switch or something else?
Regards,
Rob
Regards,
Rob
Re: Get data from Homewizard
Yep, click on the 'Edit' button below a switch, and you see two fields, the 'on action' and the 'off action'. There you can fill in a HTTP-url.
Oh and welcome to Domoticz
That works very nice, thanks for your quick responce.
Is there a way to parse json return data from the Homewizard?
- gizmocuz
You could write a python script, and use the domoticz json api to upload the results into domoticz (see wiki)
You could also use https://json-csv.com to turn the JSON data into a spreadsheet.
Does someone already create a script?
Sounds very Interesting. Its my first day with Domoticz. I already have HomeWizard since 2 years now and would be great to compare them.
- Egregius
- Domoticz version: v2024.7
Maybe http://www.domoticz.com/forum/viewtopic.php?f=17&t=6117 is womething you can start with?
It pulls data fromo thermometers, rain and wind from Homewizard and stores it in Domoticz.
- sincze
- Domoticz version: 2024.4
Egregius wrote:Maybe http://www.domoticz.com/forum/viewtopic.php?f=17&t=6117 is womething you can start with?
I still use Domoticz because I think it can do more for less compared to Home Wizard.
However if I have to install the system at a non programmers house I would suggest Home Wizard.
For people that want flexibility I'll pick Domoticz. Have several systems running stable Domoticz for over a year monitoring the P1.
People never complained.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
6 months ago I was quit entertained by homewizard, now I think it's a complete waste of my money. Domoticz is evenly simple starters, but way more flexible for advanced users.
- sincze
Egregius wrote:6 months ago I was quit entertained by homewizard, now I think it's a complete waste of my money. Domoticz is evenly simple starters, but way more flexible for advanced users.
at least the starter has to know what a raspberry is
I can assure you not everybody I talk to knows.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Great! Thank you! Helped me a lot.Egregius wrote:Maybe http://www.domoticz.com/forum/viewtopic.php?f=17&t=6117 is womething you can start with?
Now the last step is to push the data into Domoticz. For this i open the URL with the specific variables. I already found a list of the types of the sensors (http://www.domoticz.com/wiki/Domoticz_A ... ual_Sensor) but what kind of Sensor is the 'Contact'-Sensor in Domoticz?
The reason/idea is: Check the state of the magnetic contact in HomeWizard and write the state into Domitcz (Switch->Contact).
- Egregius
Can you do anything with the Udevice function from this script?
http://www.domoticz.com/forum/viewtopic ... 344#p41353
It's done! Thank you all for help!
I attach the final script. It search for Sensors and Switches in Domoticz and synchronize the state of them with HomeWizard. For that the name of the Switches and Sensors in Homewizard and Domoticz must be the same.
It was my first script so excuse me
Maybe some one can improve the script.
<?php
while(true){ //opend with rc.local and sync all 5 seconds
$json = file_get_contents('http://192.168.178.25/PASSWORD/get-sensors'); //get Homewizard status
$datahw = null;
$datahw = json_decode($json,true);
$json2 = file_get_contents('http://192.168.178.46:8080/json.htm?type=devices'); //get devices from Domoticz
$datadm = null;
$datadm = json_decode($json2,true);
if($datahw) {
foreach($datahw['response']['kakusensors'] as $tmp) { //for every Sensor; write new Array
$namehw = null;
$statushw = null;
$idhw = null;
$namehw=($tmp['name']);
$statushw=($tmp['status']);
$idhw=($tmp['id']);
if("$statushw"=="no") $statushw=0; //to compare the state with Domoticz
if("$statushw"=="yes") $statushw=1;
if("$namehw"=="HelligkeitSenso"){
if("$statushw"=="0") $statushw="Off";
if("$statushw"=="1") $statushw="On";
foreach ($datadm['result'] as $domotic) { //for every Domoticz Sensor
$namedm = null;
$idxdm = null; //idx for the idx number; dm stand for Domoticz
$hwiddm = null;
$statusdm = null;
$namedm=($domotic['Name']);
if($namedm=="Garage rechts") $namedm="GTorRechts"; //example if the Domoticz Name is different then
if($namedm=="Garage linkss") $namedm="GTorLinks"; //the name in Homewizard
$idxdm=($domotic['idx']);
$hwiddm=($domotic['HardwareID']);
$statusdm=($domotic['Status']);
if("$statusdm"=="Closed")$statusdm=0; //to set status for the URL
if("$statusdm"=="Open")$statusdm=1;
if("$namehw"=="$namedm" && "$hwiddm"=="6"){ //select Hardware ID of Virtual HomeWizard Switch
$URL="http://192.168.178.46:8080/json.htm?type=command¶m=udevice&idx=$idxdm&nvalue=$statushw";
if("$statushw"!="$statusdm")file_get_contents($URL); //send the URL to change the state
foreach($datahw['response']['switches'] as $tmp) { //for every Switch
$namehw = null;
$statushw = null;
$idhw = null;
$idhw=($tmp['id']);
if("$statushw"=="on") $statushw="1";
if("$statushw"=="off") $statushw="0";
$namedm = null;
$idxdm = null;
$hwiddm = null;
$statusdm = null;
if($namedm=="Küche Decke") $namedm="Kueche Decke"; //different Names in HW and DM
if("$statusdm"=="On")$statusdm=1;
if("$statusdm"=="Off")$statusdm=0;
if("$statushw"!="$statusdm")file_get_contents($URL) ;
sleep (5); //Sync every 5 Seconds
- Egregius
Looks nice
Just watch out with to many connections to homewizard, I had many timeouts when requesting more than every 20 seconds.
I changed the time now to 10 seconds. Since yesterday evening it checks every 5 seconds and i had no problem. I watched at same time with the HomeWizard App at the iPhone and it doesn't had a disconnection.
Do you have any other hint or good idea to improve it? As i already told, i haven't much experience so far.
- Egregius
You could consider to only repeat the while loop for one minute (like 5 times or so) and start the script every minute by cron.
That way you avoid that the script would stop in case something went wrong.
There's nothing in your script that warns you in case something went wrong.
Whit a if(!$datahw) mail... you could be warned about that. (That's how I saw all the connection errors from HW)
- Domoticz version: 2023.2
Hi there,
i'm trying to use this script (swtiches), but i keep getting an error on line 65: $statusdm=($domotic['Status']);
I changed line in my onw specifications:
3: $json
6: $json2
62: "if($namedm==
69: $URL
Can somebody tell me what 'm doing wrong?
Thx
3: $json
6: $json2
62: "if($namedm==
69: $URL
Thx
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
