WIP - E-moticz - Mobile site / app
ldb2000
Post by ldb2000 »
I have 2 issues with the code attached:
1/ cordova.js is missing (but maybe it is not needed)
2/ a CORS issue "No 'Access-Control-Allow-Origin' header is present on the requested resource." (installing the chrome extension https://chrome.google.com/webstore/deta ... ihlkkiljbi makes it work)
possible solution: http://blog.novanet.no/angularjs-with-j ... k-on-time/
But really nice work. Thanks
schmm
Re: WIP - E-moticz - Mobile site / app
Post by schmm »
Tnx for this theme. This is a very nice one!
But i have the following issue. I have six temperature sensors and on my iphone. Only four are shown and on my iphone (5s) they are to small.
Also the last T from Watt is not shown correctly on my phone.
See the attached screenshots from my iphone
WatT and Temp Sensor
EDIT:
The first problem i already solved.
The two temp sensors that did not display where the sensors with only temperature values and no humidity values.
So i edited the file tab-dash.html and added the following part after the normal temperature module:
The big change is: Line 5. "light.Type=== 'Temp'
  <div class="row">
         <div
            class="card col temp"
            ng-repeat="light in devices"
            ng-if="light.Type === 'Temp' && light.Favorite == 1"
            ng-model="light.checked">
            <div class="item item-text-wrap">
               <i class="icon ion-thermometer"></i>
               <div class="info">
                  <h3>{{ light.Temp }}&deg;</h3>
               </div>
            </div>
            <div class="item item-divider">
               <h2>{{ light.Name }}</h2>
            </div>
         </div>
      </div>
edit 2:
To add app lights (philips HUE and mi-light) to switch by the theme, i edited the 2 tab files tab-dash.html and tab-lights.html.
and added on both files:
<ion-toggle ng-repeat="light in devices" ng-if="( light.Type === 'Lighting 1' || light.Type === 'Lighting 2')
with
<ion-toggle ng-repeat="light in devices" ng-if="(light.Type === 'Lighting Limitless/Applamp' || light.Type === 'Lighting 1' || light.Type === 'Lighting 2')
owkay, you can only switch these light's but it's a start :)
emke
Post by emke »
Thanks, i will add that to my code. Maybe it's useful to add it to Github if someone is interested?
Thanks to ldb2000 i finally got the JSONP not working so you can also use it from an external address.
I'm still busy with the redesign of the Energy tab and apply some small fixes.
schmm
Post by schmm »
Please put it on Github. So you can refer to one place for the download and i'm intrested to assist with the development of this theme!
rachmat
Post by rachmat »
I downloaded the theme, but unfortunately there is no auto refresh. when I update switch from another place, ex: from hardware, the themes need to refresh manually to update status
osiris
Post by osiris »
How did you manage to allow cross domain calls to Domoticz? When I run the mobile site I get:
XMLHttpRequest cannot load http://192.168.178.47:8080/json.htm?typ ... order=Name. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://192.168.178.47' is therefore not allowed access.
I could not find any setting in Domoticz to enable cross domain requests (CORS).
m.kram
Domoticz version: 2846
Post by m.kram »
I have taken your source and am working on the app version. (If that is ok with you)
I was working on almost the same base version and then found this post. I have my source (very very first version) on github https://github.com/markmastop/appoticz
If it is fine with you I want to merge the two projects (take your version as the base version) and store the source on github so more people can add extra features to the app if they want to. For me I want to control my heating (summer project needs to be ready for the winter).
I do have an apple and google account so I can put the app in the appstores.
Mark
m.kram
Post by m.kram »
Oh the app is running on ios. Forgot to add the image in the previous post.
Mark
G3rard
Domoticz version: No
Post by G3rard »
m.kram wrote:Oh the app is running on ios. Forgot to add the image in the previous post.
Would indeed be nice if you make this available as an app in the Apple app store :)
Looking forward to that.
Not using Domoticz anymore
emke
Post by emke »
I just posted it on Github so people can add other functionality: https://github.com/emkedouwe/e-moticz
I added the changes from schmm.
spudgunman
Post by spudgunman »
I don't own a mac to assist with code but would love a iOS app with ability to operate the security panel more natively
remb0
Post by remb0 »
My compliments to both! I hope no it's on github more members will support.
kraades
Domoticz version: Stable
Post by kraades »
Is this project abandoned/dead?
Egregius
Domoticz version: v2024.7
Post by Egregius »
So it seems, last change 3 months ago.
Just tested it for fun.
Some points that need attention:
Size of website is 2.2MB, quit big for people with small mobile data subscriptions.
Switch state doesn't update after page load.
spudgunman wrote:I don't own a mac to assist with code but would love a iOS app with ability to operate the security panel more natively
You don't need a Mac to develop a web page. It's not a real iOS app, it's a 'apple-mobile-web-app-capable' site.
