Python script for Netatmo weather station
krazny
Re: Python script for Netatmo weather station
Post by krazny »
Since last wednesday the Air Quality measuments aren't updated to Domoticz anymore.
As far as I can see the data IS being downloaded from my Netatmo device but just isn't updated to Domoticz.
All the other measurements (temp, pressure, etc) are just OK and are being updated in Domoticz but not the Co2 (Air Quality) graph.
It looks like the sensor type ID (should be 249, Virtual Sensor Types) isn't correct anymore?
Am I the only one having this problem?
Raspberry Pi, Aeon Z-Stick, Fibaro Motion Sensor, 4x Fibaro Wall Plug, 2x Fibaro Dimmer, Netatmo Weatherstation
fwehrle
Post by fwehrle »
I just see that I have the same problem.
stef62376
Post by stef62376 »
Came back from holidays (so I am sure I did't change anything in my setup;-) and found that I have the same issue. Perhaps the issue is caused in changes in the netatmo api?
krazny
Post by krazny »
For u all who have the same problem..thanks to another forum I (he) found the solution;
If you open the netatmo_settings.xml file in the 'script' folder you'll probably see there's an extra line added with the same CO2 sensor.
The difference with the current CO2 sensor is the CAPITAL LETTERS;
[OLD]
<device data_type="Co2" domoticz_dev_id="%Your_ID%" domoticz_dev_subtype="0" domoticz_dev_type="249" id="" module_id="" />
[NEW]
<device data_type="CO2" domoticz_dev_id="%Your_ID%" domoticz_dev_subtype="0" domoticz_dev_type="249" id="" module_id="" />
Notice the difference in 'Co2' and 'CO2'.
This also has to has to be changed in the netatmo.py script on line 54:
DATATYPE_CO2 = 'Co2'
DATATYPE_CO2 = 'CO2'
After that..no more problems!
fwehrle
Post by fwehrle »
Thnk you to you. :)
It solved the problem.
stef62376
Post by stef62376 »
Yep, that worked, many thanks!
Mediacj
Post by Mediacj »
box18 wrote:All the steps
0. Download the netatmo.py and the netatmo_settings.xml from http://www.domoticz.com/forum/download/file.php?id=785
Thanks box18 for your instructions, it helped me a lot :D
Has anyone got the noise information visible in Domoticz and if yes by which device type en subtype?
stef62376
Post by stef62376 »
Since yesterday I get errors when running netatmo.py:
pi@domoticzpi:~/domoticz/scripts$ python netatmo.py
File "netatmo.py", line 530, in <module>
main()
File "netatmo.py", line 524, in main
token = GetToken()
File "netatmo.py", line 228, in GetToken
token = LoadToken()
File "netatmo.py", line 224, in LoadToken
return RequestToken()
File "netatmo.py", line 199, in RequestToken
return CreateToken(json_data)
File "netatmo.py", line 162, in CreateToken
newtoken.set(TOKEN_ATTR_ACCESS_TOKEN, json_decoded[TOKEN_ATTR_ACCESS_TOKEN])
KeyError: 'access_token'
I did update my domoticz from 21nn to 2276 at the time.. But that could be a coincidence..
But anyone else seen these errors since yesterday? Perhaps netatmo changed their api again?
stef62376
Post by stef62376 »
Hmm my netatmo_settings.xml seems to be messed up, the netatmo credentials (client secret etc) are reset. After I corrected then again the errors disappeared but the values in domoticz are not updating.
To be continued...
petergab
Post by petergab »
Netatmo just mofifier its API.
Domoticz no longer receives data
there are mods on script do?
box18
Post by box18 »
No, it is only Co2 in CO2 at line 57
stef62376
Post by stef62376 »
Petergap, do you receive data for anything other than co2 (or do you have issues only with co2)? I don;t receive any data at all at the moment, but haven't looked into it thoroughly yet..
petergab
Post by petergab »
error token ... API modified by netatmo ... no data !
  File "netatmo.py", line 531, in <module>
    main()
  File "netatmo.py", line 525, in main
    token = GetToken()
    token = LoadToken()
petergab
Post by petergab »
oh sorry its my nettamo setting breakout !!
it s ok !! thank you for your patience
Fredspace
Post by Fredspace »
Hello petergab
Since 2 days i ve got the same error like yours.
You said " its my netatmo setting breakout", could you explain me ?
Thanks a lot
Philos31
Post by Philos31 »
http://www.domoticz.com/forum/viewtopic ... 325#p36325
The DB meter has been added to the last beta, is there someone that can change the script to use it maybe?
RasPi2/KaKu/HUE/Xiaomi/Z-Wave/Nuki/Daikin 3,5kw Ururu Sarara/IR Heating Panels all working together with domoticz
cyberbob
Post by cyberbob »
Basically everything from this : http://www.domoticz.com/forum/viewtopic ... =20#p26776
and this post : http://www.domoticz.com/forum/viewtopic ... =40#p33976
is correct.
However from version 2300< up it now also shows the decibel meter;
new netatmo_settings.xml
<devices>
	<device data_type="Temperature" domoticz_dev_id="90001" domoticz_dev_subtype="10" domoticz_dev_type="80" ...
        <device data_type="CO2" domoticz_dev_id="90002" domoticz_dev_subtype="0" domoticz_dev_type="249" ...
        <device data_type="Humidity" domoticz_dev_id="90003" domoticz_dev_subtype="0" domoticz_dev_type="81" ...
        <device data_type="Noise" domoticz_dev_id="90008" domoticz_dev_subtype="24" domoticz_dev_type="243" ...
        <device data_type="Pressure" domoticz_dev_id="90004" domoticz_dev_subtype="9" domoticz_dev_type="243" ...
        <device data_type="Temperature" domoticz_dev_id="90005" domoticz_dev_subtype="10" domoticz_dev_type="80" ...
        <device data_type="Humidity" domoticz_dev_id="90006" domoticz_dev_subtype="0" domoticz_dev_type="81"...
        <device data_type="Rain" domoticz_dev_id="90007" domoticz_dev_subtype="0" domoticz_dev_type="85" ...
        </devices>
Next edit :
netatmo.py line 439 from
values[PARM_NValue] = value
to
values[PARM_SValue] = value
if your co2 is still nill, read this post :) http://www.domoticz.com/forum/viewtopic ... =40#p33976
cyberbob
Post by cyberbob »
Before i forgot,
I believe that when you use the rain meter, (not 100% sure do)
you need to insert this line in netatmo.py at row 57:
DATATYPE_Rain = 'Rain'
and at row 411
insert:
elif data_type == DATATYPE_Rain:
Mediacj
Post by Mediacj »
cyberbob wrote:Basically everything from this : http://www.domoticz.com/forum/viewtopic ... =20#p26776
is correct.
Thanks it works!
In the version of netatmo.py I use "values[PARM_NValue] = value" is on line 449 but you can't mis it because Datatype_Noise is just before it.
Mediacj
Post by Mediacj »
Has one of you succeeded in adding the Netatmo sensors to the rooms and Floorplan of Domoticz?
When I add devices to a room the Netamo sensors of the python script are not in the list of devices to add.
When I look in the devices list within configuration the Netatmo sensors have a 'Unknown?' label in the hardware column but they work perfect on the dashboard etc.
Users browsing this forum: assp22 and 1 guest
