In the image below you can see an overview of those sensors.gizmocuz wrote:If possible could you keep talking in mySensors terms ?rtenklooster wrote:Update: another small issue:
The only unit reporting battery states, is unit 4.
The battery percentage of unit 1 is also updated with unit 4's percentage.
It would be nice to be able to set notifications when a bettery level drops below xx, and show a graph of the battery level.
Unit = Node_ID ? or Unit = Child_ID ?
What (i tried) todo, when you receive a battery status on for example Node_ID=2, then all sensors of this Node with ID=2 will get the battery status
The enly sensor reporting a battery level is slaapkamer R en M
MYSB = 1 mini pro, with 2 sensors, a lux and barometer
