Devices disappeared
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pierrotori
Domoticz version: 2024.4
Devices disappeared
Post by pierrotori »
Version: 2026.4 (docker)
Platform: rpi2 armv7
the device is disappeared in the measure menu, i don't see the device in the device menu but i see the device in the Roomplan and i see also the device in the database for the same menu energy
625 is the device disappeared
626 is ok
the devicestatus table in production
625|29|82625|1|compteur eau|1|113|0|2|0|12|255|0|null|2026-11-27 14:00:58|610|0.0|1.0|1000.0|1.0|||0|0|11|4 personnes 148  m3 /an, 400 litres d'eau par jour
5 personnes 168  m3 /an, 460 litres d'eau par jour
https://services.eaufrance.fr/carte-interactive|||0|
626|29|00082626|1|utilisation / 1h|1|243|6|0|0|12|255|0|0.0|2026-11-27 16:30:03|611|0.0|1.0|0.0|1.0|||0|0|11||||0|
i have a test landscape same version and i see the device
what is the action to retrieve the device ?
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2026.3
Re: Devices disappeared
Some possibilities:
You did not put it in the hidden room?
It is active (Green Arrow) in the setup devices menu?
The user that is logged in is allowed to see the device (see menu setup users when logged in as an administrator)?
The hardware getaway where the device belongs to is still active?
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
pierrotori wrote: Saturday 28 November 2026 10:48 ... but i see the device in the Roomplan ...
I also have two disappeared utility devices since a long time already. And your hint with the roomplan encouraged me to have a look there. Indeed it is shown there (in "ad" a device), but not in the device list under settings or the utility tab. In the log, there is this error. It can be adde to a roomplan, but if you choose that room from the utilities tab or dashboard, it it empty.
2026-11-29 12:46:40.335 Error: Invalid Number sValue: '375;3.1' for device idx: '818'
It is most likely a device, which once received several numbers via MQTT, but expecting ony one.
I would like to delete it, but have no chance because it disappeared, although the log show it with an error. Now I have learned from your post, that roomplans also "know" it. So there seems to be something in parallel here which might finally help me to fix it. Hope someone can give a good clou here.
Stop, look and listen.
jvdz
Domoticz version: 4.107
Post by jvdz »
Can't you try to do a manual udevice json api call to update the svalue to a proper number?
imautohuttraeger
Good idea, I just have to figure out how to do that 😉
jvdz
Post by jvdz »
Just a url like this should do it:
http://uid:psw@ipaddress:8080/json.htm?type=command&param=udevice&idx=818&nvalue=0&svalue=0
uid:psw is required when you have authentication for the local LAN.
imautohuttraeger
jvdz wrote: Sunday 29 November 2026 15:40 Just a url like this should do it:
OMG! I did this for several devices, then the devices appeared again in the device list and I could delete it. So there won't be any svalue error again. You finally gave me the deceive clou for getting a clean system again - after years. A real game changer for me - thank you!
