Energy Dashboard (Build in)
gizmocuz
Re: Energy Dashboard (Build in)
Post by gizmocuz »
imautohuttraeger wrote: Sunday 01 November 2026 13:31 Just saw the house consumption popup - great! You should consider to implement that to the respective tile of the the dynamic dashboard energy widget, too.
Done
imautohuttraeger wrote: Sunday 01 November 2026 23:23 Click on batterie bubble shows log page of battery instantaneous power. In my opinion, battery state of charge (SOC) would be more relevant.
Done
gizmocuz
Post by gizmocuz »
No, you should use a kWh sensor for your Solar measurements. Domoticz for sure did not create a P1 type for this.
You can convert it... ask mistral/claude/chargpt to assist you with it, create a python script that does it for you in a database backup you made
BartSr
Domoticz version: V2024.7
Post by BartSr »
@seby901
What avout a dummy device which will get data by a dzVents script?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
In the settings (latest beta), there is a new (appreciated) selection:
Heat Pump / Airco (kWh)
When I select a respective device, I can't see anything, neither on the energy dashboard nor on the energy widget.
Is it just kind of a "sneak preview" of what is yet to come or am I missing something?
Stop, look and listen.
gizmocuz
Post by gizmocuz »
Under Setup->Energy Dashboard, there is a new 'Energy vs Weather' page you can open
imautohuttraeger
OMG - how cool ist this? Great!
gizmocuz wrote: Sunday 29 November 2026 8:06 Under Setup->Energy Dashboard, there is a new 'Energy vs Weather' page you can open
I was searching a few minutes until I recognized the typo 😉. Correct klickpath is:
Setup->Energy vs Weather
