As i add more and more devices my " Switches" , "Temperature" , "Weather" , "Utility" tabs run full and data of one device are spread over different pages.
I know there is a selector possibility on the devices tab but this doesn't help because information from the aforementioned tabs is not available there.
Also it is now possible to setup a dynamic dashboard.
Is there a possibility to reorganize the menu structure ie :
- put " Switches" , "Temperature" , "Weather" , "Utility" under one flyout tab ?
- create more device specific dashboards
- possibility where devices are presented.
- maybe add more options to the devices page ?
etc
Although i am a long time Domoticz user and a fan because of its simplicity to use (but i hate my 433 Mhz stuff.), i only recently dived deeper into Domoticz, and expanding and updating my devices.
Maybe i missed something ?
Domoticz menu layout
RNEE
- Domoticz version: 2026.4
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee|deCONZ Conbee II|Marstek 5,12Kwh|Pusr-dr134/dr164|Xemex Csmb|MQTTMapper|Quatt v2|DTGbot|QwatD|
- RonkA
- Domoticz version: 2025.1
Re: Domoticz menu layout
Correct me if i am wrong but you want to combine various device values in one place? Why not make a textdevice with the combined values?
this saves me a lot of real-estate on screen..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20 - Sonos
Work in progress = Life in general..
RNEE
Very nice work, i like it, but that is not what i mean.
But i don't have a clue how to make it. Do you have a github page somewhere or is there a plugin for it ?
When i started in or before 2016 with Domoticz i had 4 switches/lights, 3 thermometer, 4 weather.
The menu structure was very self explanatory and clear, each group of devices had its own page.
Some things where added, but in years i never changed a thing.
Now i have, including new development, in no time 350-400 Domoticz devices.
Most households , the intended public for Domoticz, nowadays have a P1, heating, airco, solar, battery, car, lights, weather station, etc you name it.
Each device comes with their own switches, temperature, other sensors, utilty etc, often 10 or more
But this is all shattered around the menustructure.
I know you can select the favourites and group them in a dynamic dashboard.
But moving all in the Dashboard clogs the dashboard.
But that is not what i mean.
I mean it would be more elegant to create your own 4-5 menu items instead of the current and group the things you like together, then select a layout per page.
Also maintenance things like edit/timer/notifications could also be available on the Devices page where can group per hardware.
Even the nice Energy Dasboard can have its own menu ! I never understood why @Gizmocuz put it under Setup.
I mean : make Domoticz even more easy to use out of the box , and adapt to your daily usage, not more complicated.
- imautohuttraeger
- Domoticz version: lat.beta
I recommend to use the new, super fantastic nightglass theme. For your purpose, you have multiple ways of filtering a tab: Room, device type, hardware, status on/active OR off/inactive, or even a string.
And there ar countless more every-day-helpers included.
Documentation: https://galadril.github.io/Domoticz-Nightglass-Theme/
Forum: viewtopic.php?t=44563
GitHub: https://github.com/galadril/Domoticz-Nightglass-Theme
Stop, look and listen.
- Domoticz version: 2026.3
You can also assign your devices to rooms. Then you can easily filter between tabs based on rooms.
Rooms can be real rooms (living room, outside, garage) but also be more functional like weather, solar panels, etc.
And off course use dynamic dashboard and make multiple pages based on your plan.
