Beginner (to Domoticz) trying to set up a BME280 I2C sensor
chrisisbd
Post by chrisisbd »
I am new to Domoticz and I'm trying to set up my first device, a BME280 I2C sensor without much success.
I have Domoticz 2026.04 installed OK on my Raspberry Pi and can see the Dashboard etc.
The BME280 is connected to the Pi and I can 'see' it and read values using standalone Python scripts without problems. It's at the standard address of 0x77 on /dev/i2c-1.
I have added the BME280 to Settings->Hardware with Device type "I2C Sensors" and have the sub-type set to "I2C Sensor BME280 Temp+Hum+Baro". It shows up in the hardware list, so far so good.
However I can't get it to appear in Settings->Devices. Is there some vital step I have forgotten? How do I get to actually see values from the BME280?
chrisisbd
Re: Beginner (to Domoticz) trying to set up a BME280 I2C sensor
Post by chrisisbd »
I have just noticed the following error repeating in the Log:-
2026-11-25 12:41:54.313 Error: UPS BME280: I2C_BME280: Error Writing to I2C register
RNEE
Domoticz version: 2026.4
Post by RNEE »
Did you try to ask an AI ?
I did and it gave :
That error (I2C_BME280: Error Writing to I2C register) means Domoticz successfully opened the /dev/i2c-1 bus, but failed to communicate with the sensor at the expected I2C address (0x76 or 0x77).
etc. etc
I advise you to use an AI to help you on the way.
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee|deCONZ Conbee II|Marstek 5,12Kwh|Pusr-dr134/dr164|Xemex Csmb|MQTTMapper|Quatt v2|DTGbot|
