Since I recently included a battery I checked the required input data. Most is clear to me but I wonder why battery energy in / out is required. Is there some docu about that?
Meanwhile I stepped into the financial matters. I used the endever hardware and set to Zonneplan.
User vars and widgets are populated whith relevant data. I wonder how all these data are related to each other.
Any info about that? Maybe it's me but I couldnot find data about this topic.
I appreciate any info on this topic.
-Bartt
dynamic dashboard <> battery
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Re: dynamic dashboard <> battery
Nobody who has same question?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- imautohuttraeger
- Domoticz version: lat.beta
I don't know a docu for this special question. But energy in and out of course is needed to display the daily (day to date) charge and discharge amount of kWh. See screenshot (both zero, because it is close after midnight and my minimum load of 10% is already reached due to the heat pump. Yesterday it was 14 kWh charge from solar power and 12 kWh discharge to the house consumption).
If your battery or your solar inverter is not providing these energy figures in kWh, you can create two dummy devices in domoticz which are filled by a script that uses the instantaneous battery power in Watt
I'm not sure if this is what you like to know. Does it answer your question?
- Screenshot_20261125-003604.png (40.77 KiB) Viewed 39 times
Stop, look and listen.
