(Solved) How restore a "Automatic Backup" ?? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
costo
Domoticz version: 2025.1
Post by costo »
In Setup-Settings-System there is the "Automatic Backup" option.
I activated it and found out that in the protected folder /domoticz/backups there are Monthly, Daily and Hourly backups.
I can't find out how to restore from a automatic generated backup file.
Is there a simple way ??
Domoticz 2026.4
Hardware: HP-T530 thin client 128/4Gb
linux Mint 22.1 Cinnamon
RNEE
Domoticz version: 2026.4
Re: How restore a "Automatic Backup" ??
Post by RNEE »
Via setup->settings->backup/restore.
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
Domoticz version: 2026.3
RNEE wrote: Thursday 19 November 2026 7:08 Via setup->settings->backup/restore.
That only works if you start the browser on the domoticz server itself as it expects the file on the local host (your laptop, PC, smartphone etc).
Or copy the to be restored backup file from the domoticz server to the local host.
Another way is to stop domoticz through command line
sudo service domoticz stop
Go the the domoticz install folder
Make a backup of the domoticz.db file (the current in use domoticz database file)
Copy the to be restored backup file as domoticz.db in the domoticz install folder (overwriting the existing domoticz.db file)
Start domoticz again
sudo service domoticz start
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
Or - if your Domoticz is not running anymore, via the terminal. Save the backup on a save place, Install Domoticz new, restore the database by the backup file:
https://wiki.domoticz.com/Going_back_to ... us_version
Stop, look and listen.
imautohuttraeger
Or this way, that once worked for me: (copied and automatically translated from my German AI helper notes, when I once ran into trouble):
1. Start a root shell
sudo -i
2. Stop Domoticz
systemctl stop domoticz
3. Navigate to the backup directory and list available backups
cd /home/pi/domoticz/backups
ls -la
Review the list and identify the backup from before today's update (check the date/time in the filename).
4. Back up the current (faulty) Domoticz binary (as a precaution)
cp /home/pi/domoticz/domoticz /home/pi/domoticz/domoticz_broken_$(date +%Y%m%d)
EDIT: Drop or amend step 5, like @waltervl mentioned (see his comment below). As he correctly stated:
Step 5 is not correct, no need for tar. See my earlier (modified) answer. Do not trust AI on this.
5. Restore the backup[/quote]
The exact command depends on the name of the backup file. Typically:
tar -xzvf <BACKUP-FILENAME> -C /home/pi/domoticz/
(Please use the exact filename as shown in the output from the `ls -la` command in step 3.)
6. Correct permissions (if necessary)
chown -R pi:pi /home/pi/domoticz
chmod +x /home/pi/domoticz/domoticz
7. Restart Domoticz
systemctl start domoticz
systemctl status domoticz
8. Exit the root shell
exit
Last edited by imautohuttraeger on Thursday 19 November 2026 10:11, edited 6 times in total.
imautohuttraeger wrote: Thursday 19 November 2026 9:22 Or without installing Domoticz brand new: (copied and automatically translated from my German AI helper notes, when I once ran into trouble):
bash
sudo -i
2. Stop Domoticz
bash
bash
ls -la
bash
bash
bash
7. Restart Domoticz
bash
bash
exit
RNEE
Post by RNEE »
I think the OP asked for an easy way.. :D
But @costo is your database beyond repair?
There are possibilies to Repair ? Did you try them?
imautohuttraeger
waltervl wrote: Thursday 19 November 2026 9:25
Good point - thank you for taking care. I have edited my comment accordingly.
imautohuttraeger
RNEE wrote: Thursday 19 November 2026 9:33 I think the OP asked for an easy way.. :D
That's certainly right, but for me as a non-coding-guy, this is the easy way:
- copy
- paste
- hoping it works
RNEE
Post by RNEE »
imautohuttraeger wrote: Thursday 19 November 2026 10:27
- copy
- paste
- hoping it works
OP knew where the files are and as a Linux user understands what to do.
In my opinion we are in 2026 now.
If Domoticz wants a larger audience it should be easy to use.
Off topic :
@imautohuttraeger are you family of Laureline ? :D
About Laureline : https://youtu.be/9pKYkhABb4w?si=LVo5nhvuIRkWrvKm
imautohuttraeger
RNEE wrote: Thursday 19 November 2026 10:48 Off topic :
No, she is not a relative of mine. But the aliens are looking a little bit like me 😄
costo
Post by costo »
Thanks for all the usefull answers. So (for the moment) there is no easy way to restore a 'automatic backup'.
My problem was that I accidently deleted hardware with a persistentUSB.
I understand now how I could have used a Hourly backup from a little before, but it's not very easy.
So instead I followed the 'hard way' and reinstalled a USBDevice-by-ID as described in the wiki.
Domoticz is running fine
