Hello!
I have a morning wakeup schedule in Domoticz that opens my blinds, turns on a few lights, starts my radio etc that I use every morning. Some days however I, like everyone else, has to wake up earlier than usual and then I often change the time of my original schedule. When I do this there is a 99% chance that I will forget to change it back and will wake up earlier than I wanted the next day. A lot of difference apps like Sonos and Xiaomi have the option to set a schedule/alarm to only run once and when it has run it will be disabled. This is something I miss a lot in Domoticz. It would be so nice if when I made a schedule I could set something like "only run X times" and also the inverse "disable for x runs"
[Request] Run schedule once and then disable
- imautohuttraeger
- Domoticz version: lat.beta
Re: [Request] Run schedule once and then disable
May this procedure could solve this without a built-in function in Domoticz:
Make a virtual switch "Morning routine standard"
Create script that triggers the standard morning routine only, when the switch in "on". Else trigger the exceptional routine.
Set this switch to "off" when the exceptional routine is wanted.
Include a step in the script, that automatically sets the switch "on" every day e.g. at 11:00 AM
Stop, look and listen.
Didn't think about that! Sounds absolutely doable but it would be nice if it was a feature when modifying a schedule :)
lost
Do you know you can setup as many timer plans as you need? So instead of changing some timers inside a plan, an alternative would be to have several alternate plans and switch them as you need.
To ease switching, just create a virtual with this kind of action (for N=0 to you max plans nb):
http://127.0.0.1:8080/json.htm?type=command¶m=setactivetimerplan&ActiveTimerPlan=NI myself had a use-case for this (for now disabled as no more using such contract) when I had variable electric prices: Tempo contract in France, with day kWh prices according to a 'day color" that can be blue (most of the year, cheap), white (average prices), red (heavy prices).
According to the next-day (J1) pricing color, If needed was switching timer plans in the evening to tune heating. Here is the code snippet in pure Lua (timerPlanSw is the variable that hosts the name for the virtual selector used to switch plans) from the time script doing this:
-- Need to switch to 'red' timerplan (if feature active)?
if ((time.hour == redHourSwTime['to'][1]) and (time.min == redHourSwTime['to'][2])) then
if (uservariables[tempoVarJ1] == "ROUGE") and (timerPlanSw ~= nil) and (toTimPlans[otherdevices[timerPlanSw]][1]) then
-- Switch current timer-plan to "TempoR"
print('Switch current timer-plan '..otherdevices[timerPlanSw]..' -> TempoR.')
commandArray[#commandArray+1]={[timerPlanSw]='Set Level: '..toTimPlans.TempoR[2]}
commandArray[#commandArray+1]={['SendEmail']='TEMPO Planning!#'..uservariables[tempoVarJ1]..' => TempoR!!!#'..emailNotifyAlarm}
-- Need to switch from 'red' timerplan (if feature active)?
if ((time.hour == redHourSwTime['from'][1]) and (time.min == redHourSwTime['from'][2])) then
tempoJ1 = uservariables[tempoVarJ1]
if (tempoJ1 ~= "ROUGE") and (timerPlanSw ~= nil) and (otherdevices[timerPlanSw] == "TempoR") then
-- Switch (back) "TempoR" timer-plan (always) to "Norm"
print('Switch current timer-plan '..otherdevices[timerPlanSw]..' -> Norm.')
commandArray[#commandArray+1]={[timerPlanSw]='Set Level: '..toTimPlans.Norm[2]}
commandArray[#commandArray+1]={['SendEmail']='TEMPO Planning!#'..uservariables[tempoVarJ1]..' => Norm!!!#'..emailNotifyAlarm}
-- Change tempoVarJ1 that is now tempoVarJ & may be used by tempoWarn companion device script before daily refresh.
commandArray[#commandArray+1]={['Variable:'..tempoVarJ] = tempoJ1}
