Zwave issue after restart...
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
lost
Post by lost »
After updating from 2025.1 to 2026.4 3 weeks ago, as everything looked stable, I did some saving job (domoticz file tree and even the full SD card) in case some restore would be needed someday.
This was ~2h with domoticz not running.
This evening, I saw 1 door sensor did not report since this morning: It's IDs are zeroed. As well, all my heating control devices are in same situation (even if some I tested looks to handle commands) and a PIR.
Tried to disable then re-enable Openzwave USB device but same situation after all nodes queried.
=> So the question is: Did others notices some regression on recent Domoticz versions concerning OZW (deprecated, but I do not add zwave devices since years & don't want to deal with the added burden of zwaveJS)?
Did not noticed anything in OZW restart logs, only some timeouts that are quite common at startup phase but no error.
globetrotter
Re: Zwave issue after restart...
Post by globetrotter »
Did you try to refresh the node information in:
Settings > Hardware > Z-wave Settings > Select a not working NodeID and click: Refresh Note Info...can take a while.
