I have domoticz running in a docker container. Besides that a standalone RPI with hardware type P1 USB smartmeter. The standalone RPI is a slave from domoticz in the dockercontainer via port 6144. Everything according the books. Both Pi's have the same version 2026.4 and build cc668a12b.
The standalone pi is connected via a Devolo Lan with the network. The docker-container connects via wifi to the same network. Of course a can connect the slave via wifi to the network
On a regeluar base errors about not connecting to the slave.
the last log advices to update the domoticz instance, but a far as i can see both pi's have the same software.
Of course a can connect the slave via wifi to the network but that does not to solve the problem.
What to do?
2026-11-15 13:31:37.433 Error: Restarting: DOMO Server
2026-11-15 13:32:59.468 Error: DOMO Server: No data received from xxx.xxx.xxx.213:6144 after 12 seconds. The remote Domoticz may be running an older version that does not support the SIGNv3 protocol. Please update the remote Domoticz instance.
domo Server
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
lost
Re: domo Server
If same Dz versions, that's not your issue. Most probably powerline networking or/and wifi or any network stuff in between unreliable.
Powerline can be quite tricky when starting to fail: 1 device can get down the whole powerline network, even one external to the link that fails. Can be intermittent as well.
Had this kind of issue affecting IP cams the day before going to holidays and this took me almost half a day to spot which of my 5 powerline devices was sometimes at fault to remove it. Back from holidays I wired everything properly.
IMO, 1st try to use wifi only if possible... or wire and get rid of powerline for anything that needs reliability. Still have one for an internet radio now.
