This one is mainly a WebUI release: almost every screen was reworked. The highlights:
Dashboard
Key figures at the top, and a Needs attention list you can export as JSON
Bars instead of donuts, and an (i) behind each figure that explains it
Traffic chart in messages per minute
Plugin version (or branch and commit) and coordinator channel at a glance
Device list usable on a phone
Device Management
Compact table with quick filters, search and sort
Click a name to rename it, Enter saves that device
Parameter editor in a side panel, as fields or as JSON
Click a row for the details window: notes from the device configuration, Blakadder link, Rolling LQI and RSSI charts, messages received since the plugin start (ZDO / ZCL, per minute)
Admin → Firmware (OTA)
Four columns: brands → firmware → matching devices → transfers
Several devices in one go: 3 transfers at a time plus 1 battery device, the others wait in a queue
Live progress per device: bytes, speed, time left, and the result of the last updates
Cancel an update. A stalled transfer stays listed and resumes when the device comes back
Devices with two images (e.g. NodOn SIN-4-FP-21) are shown per image. A file not meant for a device's model is not offered (Schneider Wiser Heat EH-ZB-*)
A file copied into OTAFirmware/<brand>/ shows up without a restart
Admin, Settings, Tools
Admin: one page with a status bar and tabs: Plugin, Provisioning, Groups, Coordinator
Settings: search, theme list, and a review of your changes before saving
Tools: tabs everywhere. New Data tab with a support bundle, Command and Binding / Reporting start from the device, Debug with presets, categories and a device filter, Errors as a list with details
Network and Management
Network: one page with key figures and tabs. Interference is now a heatmap of the stored scans
Management: Devices and Groups as tabs. Group list, one-group editor, members picked from a list
Also in 9.1.009
Security: the /plugin REST call no longer returns the Domoticz username and password, and device-param no longer evaluates its input
EZSP: TX power applied in dBm, and a change from the WebUI applies without a restart
Health: a device is "not seen" after 6 h of silence
Warning — device Param OnOffOnTimeDelay: when it is set, every On is now sent as On With Timed Off, so the device switches itself off after that delay (zigpy coordinators). If you set this Param before, check that this is what you want. Thanks to badzz (GitHub) for this contribution!
Upgrade — from the WebUI, as usual
Admin › Plugin → Start upgrade (can take several minutes)
When it says you can restart the plugin, click Restart
Reload the WebUI page to get the new screens
On Domoticz 2026.1, restart Domoticz itself instead: a 2026.1 bug keeps the old code when only the plugin restarts.
Details and troubleshooting: Plugin update
Upgraded using the WebUI. No problems
The new WebUI is so different! Looks more organized and modern. Needs some getting used to, though. To be honest: I hope I don’t need to change any of the settings on a regular basis. It’s good that the opportunity is there to fiddle with the (many) settings.
Thanks, pipiche.
Thanks for this update, updated thru the web-ui no problems. Just a question, there are some firmware available, see attachments. How can i do these firmware updates?
Edit: found how to do it, but can't find the firmware for the Sonoff...
Thanks for the update! Nice WebUI updates!
Regarding the firmware updates would it be nice if you can update the device from the list of devices with firmware updates (second screenshot of Rik60). Now you have to go to the firmware update list and remember what devices were updatable....
[quote=waltervl post_id=336369 time=1793865498 user_id=23529]
[/quote]
Yep, I'll take that idea, I do agree this is not convenient for now. However, I also want to make sure this is a conscious decision of the user to do such upgrade
