Solaredge trouble.
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
Solaredge trouble.
Post by BartSr »
After updating to dz 2026.4 lots of problems with solaredge were solved.
Out of the blue since a few days again Solaredge pops up errors
2026-10-23 11:38:39.102 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 11:38:39.172 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 11:38:39.255 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 11:43:39.661 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 11:43:39.743 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 11:43:39.828 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 11:48:40.412 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 11:48:40.488 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 11:48:40.561 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 11:53:40.960 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 11:53:41.033 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 11:53:41.118 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 11:58:41.697 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 11:58:41.795 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 11:58:41.864 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:03:42.276 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:03:42.362 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:03:42.448 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:08:43.091 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:08:43.161 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:08:43.238 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:13:43.662 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:13:43.744 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:13:43.816 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:18:44.395 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:18:44.465 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:18:44.541 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:23:44.953 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:23:45.023 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:23:45.088 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:28:45.736 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:28:45.804 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:28:45.876 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:33:46.306 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:33:46.381 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:33:46.455 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:38:47.000 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:38:47.079 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:38:47.157 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:43:47.586 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:43:47.653 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:43:47.718 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:48:48.347 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:48:48.426 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:48:48.492 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:53:48.927 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:53:49.001 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:53:49.061 Error: Solaredge: Error getting http data (EnergyDetails)!
2026-10-23 12:58:49.647 Error: Solaredge: Error getting http data (Equipment details)!
2026-10-23 12:58:49.718 Error: Solaredge: Error getting http data (Overview)!
2026-10-23 12:58:49.806 Error: Solaredge: Error getting http data (EnergyDetails)!
Any advice what may cause these errors?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
imautohuttraeger
Domoticz version: latest
Re: Solaredge trouble.
Post by imautohuttraeger »
I guess you are talking about the web API to the SolarEdge cloud an not about modbus data directly from the inverter locally - right?
Stop, look and listen.
BartSr
Post by BartSr »
Correct. I don't have modbus available on inverter.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jannl
Domoticz version: 2026.1.x
Post by jannl »
I have the same errors. I will cancel the api use.api v2 had only 2000 calls a month for free. Starting november 1st api v1 will be discontinued. Most of my modbus integration works.
janvdberg
Post by janvdberg »
I had the same problem and enabled Modbus, here is how I did it:
https://j11g.com/enabling-modbus-on-the ... e-inverter
BartSr
Post by BartSr »
Thanks for your information but it appears that not all inverters have modbus available. Also not, as you mention, hidden.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Post by gizmocuz »
@BartSr, I assume you run the latest beta
BartSr
Post by BartSr »
@Gizmocus
You trigered me!
I used pulled latest container and it appears that communication seems to be correct again.
Is there a way to automatic pull new container?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jvdz
Domoticz version: 4.107
Post by jvdz »
BartSr wrote: Monday 02 November 2026 12:47 Is there a way to automatic pull new container?
You mean automattically always in the background like WatchTower does?
Or do you want to have an option to select whether or not to p ull the latest image before recreating the domoticz container?
I use Portainer and when deploying the domoticz stack, there is an option to Pull the latest version first from the Docker Repository.
