Energy Dashboard (Build in)
imautohuttraeger
Domoticz version: latest
Re: Energy Dashboard (Build in)
Post by imautohuttraeger »
waltervl wrote: Wednesday 08 July 2026 16:32 I mean the report page (button top right in the log page)
Ah, I understand. No, calculation there is also wrong
Last edited by imautohuttraeger on Wednesday 08 July 2026 17:05, edited 1 time in total.
Stop, look and listen.
imautohuttraeger
waltervl wrote: Wednesday 08 July 2026 16:36 What you can do is to get the json of the P1 device as the flow is:
- GetInitialDevices() calls: json.htm?type=command&param=getdevices&rid=...
- For the P1 device (idx == idP1), RefreshItem() calls handlePower(item).
- handlePower() reads item.price and stores it in $scope.p1Price
So what gives field price in the json from API call (change DomoIP, Port and IDXP1 to real values)
http://DomoIP:Port/json.htm?type=command&param=getdevices&rid=IDXP1
Field "price" is also the wrong one (return kWh X 2 instead of X 1)
	"ActTime" : 1783522317,
	"AstrTwilightEnd" : "00:00",
	"AstrTwilightStart" : "00:00",
	"CivTwilightEnd" : "22:33",
	"CivTwilightStart" : "04:29",
	"DayLength" : "16:30",
	"NautTwilightEnd" : "23:45",
	"NautTwilightStart" : "03:16",
	"ServerTime" : "2026-07-08 16:51:57",
	"SunAtSouth" : "13:31",
	"Sunrise" : "05:16",
	"Sunset" : "21:46",
	"app_version" : "2026.2 (build 18094)",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Color" : "[{\"from\":-10600,\"to\":0,\"color\":\"#66bb6a\"},{\"from\":0,\"to\":10600,\"color\":\"#ff0000\"}]",
			"Counter" : "0.213",
			"CounterDeliv" : "43.503",
			"CounterDelivToday" : "43.503 kWh",
			"CounterToday" : "0.212 kWh",
			"CustomImage" : 0,
			"Data" : "213.0;0;43503.0;0;0;7719.0",
			"Description" : "P1 Dummy mit den Hichi Werten.",
			"Favorite" : 1,
			"HardwareDisabled" : false,
			"HardwareID" : 2,
			"HardwareName" : "Dummy Hardware",
			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
			"HardwareTypeVal" : 15,
			"HaveTimeout" : false,
			"ID" : "14262",
			"LastUpdate" : "2026-07-08 16:51:51",
			"Name" : "Stromz\u00e4hler P1",
			"Notifications" : "false",
			"PlanID" : "28",
			"PlanIDs" :
				28
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Energy",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "P1 Smart Meter",
			"TypeImg" : "counter",
			"Unit" : 1,
			"Usage" : "0 Watt",
			"UsageDeliv" : "7719 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "530",
			"price" : "-86.1140"
	"status" : "OK",
	"title" : "Devices"
Domoticz version: 2026.3
Looking at this screenshot you posted earlier you could try to change the P1Electricity report display to something else then Simple (Dynamic contract) as you do not have a dynamic contract.
imautohuttraeger
waltervl wrote: Wednesday 08 July 2026 17:21 Looking at this screenshot you posted earlier you could try to change the P1Electricity report display to something else then Simple (Dynamic contract) as you do not have a dynamic contract.
I did that before without any result
Then it seems to be a deeper issue on energy cost calculation of P1 devices than just the energy dashboard ...
Perhaps start a new topic on this. Or make a GitHub issue.
Edit: seems to be a known issue viewtopic.php?t=42871
imautohuttraeger
I have made a separate posting for P1 as you suggested.
https://forum.domoticz.com/viewtopic.p ... 0#p334680
imautohuttraeger
In the first posting two years ago, announcing this new energy dashboard, the screenshot includes 5 custom widget bubbles (instead of 3 like it is implemented now).
More custom widget bubbles would be quite useful for me and maybe other users, too.
Probably there is a reason for the reduction to only three, but I am not aware of it. However, according to design and space it seems to be feasible even for up to 7. Could it be re-established?
gizmocuz
Post by gizmocuz »
imautohuttraeger wrote: Wednesday 29 July 2026 17:12 In the first posting two years ago, announcing this new energy dashboard, the screenshot includes 5 custom widget bubbles (instead of 3 like it is implemented now).
It's still 5... and working
@imautohuttraeger, there are 5: Gas, water and 3 free widgets.
imautohuttraeger
Ah - now I understand 🥴. Sorry.
As I don't have gas and water meters in Domoticz, I never used it thus have never realized this correlation.
Would be great to have 4 or 5 custom widgets, if gas and/or water are not used. Idea: "Simply" deactivate (grey out) custom widget 4 and/or 5 if gas and/or water are used.
If you also think it is a good idea, I could make a GitHub feature request. But if not: Do you have any idea for a workaround so I could use it for electric meters?
gizmocuz
Post by gizmocuz »
This dashboard is meant for a overview of your consumption. (Grid Meter, Gas, Water, Battery), and you can have 3 additional meters.
That should be more than sufficient.
You can use it to display 3 additional kWh sensors already
imautohuttraeger
gizmocuz wrote: Thursday 30 July 2026 10:51 [...]
Got you, but that seems to be not valid for me 😉. I already have occupied it by three high consumers:
. heat pump 1 for heating
. car charger 1
. washing machine
Would like to see also e.g.
. heat pump 2 for hot water
. car charger 2
. cloths dryer
However, please interpret my wish just as a humble suggestion. I do highly appreciate all of your work and I am fully aware of the fact that the effords must be prioritized to feed most important things and broader needs.
::::smart-arse mode ON::::
BTW: I am taking the term "Energy Dashboard" obviously too literally. The volumes of gas and water don't show energy. And electric current beats gas as the future for heating both in terms of costs and environmental impact. 😜
::::smart-arse mode OFF::::
imautohuttraeger
I would love to have the log pages of the devices on click, similar to the behaviour of the energy widget of dynamic dashboard.
Click on ...
... the grid bubble leads to P1 log page
... the solar bubble leads to solar log page
... the house bubble leads to nothing (as it is just calculated)
... the batterie icon or % value leads to the log page of the batterie charge status
... the voltage value leads to the batterie voltage log page
... the gas bubble leads to the gas volume counter log page
... the water bubble leads to the water volume counter log page
... any custom widget bubble leads to the corresponding log page
... the outside temperature leads to the temperature log page
Is there any reason against it?
gizmocuz
Post by gizmocuz »
Good idea, done for the next beta: clicking a circle on the Energy Dashboard now opens the log of its device (grid, solar, battery, gas, water and the custom ones). The house has no device of its own, so clicking it shows today's house consumption per 5 minutes, split into solar, battery and grid, together with the self-sufficiency.
imautohuttraeger
Once again I have to express my highest appreciation for the super fast implementation!
imautohuttraeger
Just saw the house consumption popup - great! You should consider to implement that to the respective tile of the the dynamic dashboard energy widget, too.
imautohuttraeger
Click on batterie bubble shows log page of battery instantaneous power. In my opinion, battery state of charge (SOC) would be more relevant.
seby901
Domoticz version: 2026.4
Post by seby901 »
**Energy Dashboard: support P1 Smart Meter devices as solar production sources**
I am using Domoticz 2026.4.
In Settings → Energy Dashboard, my grid meter, configured as “P1 Smart Meter”, can be selected under “P1/Grid”.
However, my separate solar production meter is also configured as “P1 Smart Meter”, and I cannot select it under “Solar”.
I understand that the documentation recommends using P1 devices for grid monitoring only. Would it be possible to support an existing P1 device as a solar production source, with an option to select which power field represents production?
This would allow me to use my existing device without creating an additional virtual meter.
Thank you.
gizmocuz
Post by gizmocuz »
Your Solar meter should be a kWh sensor
seby901
Post by seby901 »
gizmocuz wrote: Monday 02 November 2026 7:42 Your Solar meter should be a kWh sensor
Thank you. My solar production meter is already configured as a P1 Smart Meter, with several years of recorded data. Preserving this history is important to me.
My request is whether support for P1 devices could be added to the Solar dropdown, allowing me to use my existing meter and its history without creating an additional kWh sensor.
Could this be considered as a feature request?
