[dzVents] EDF Tempo (France): today/tomorrow colour, red-day risk at D+2, red days left – free JSON API, no key
JeanPierreTempo
Post by JeanPierreTempo »
For those of you in France on the EDF Tempo tariff, here is a dzVents script that keeps the Tempo colour in Domoticz and warns you when a red day is coming. In full transparency: calendrier-tempo.fr is an independent project I run, a free site (not affiliated with EDF or RTE), and the script uses its API. No account, no token, no API key.
What it does:
  • 2 Alert sensors: today's and tomorrow's official colour (green = BLEU, yellow = BLANC, red = ROUGE, grey while tomorrow is not published yet)
  • 1 Percentage sensor: probability of a red day at D+2 (forecast)
  • 1 Custom sensor: red days left in the season
  • A Domoticz notification (once per date) when the D+2 red risk reaches 50 % (adjustable)
Endpoints used (all JSON, GET):
  • /api/today and /api/tomorrow: {"status":"ok","date":"2026-10-17","couleur":"BLEU","code":1}; status is "unavailable" until tomorrow's colour is published
  • /api/predictions: day-by-day forecast up to D+15, with probabilite_bleu / probabilite_blanc / probabilite_rouge
  • /api/remaining: days left per colour in the season
Today's and tomorrow's colours are the official ones, as soon as EDF/RTE confirm them. What the API adds is the D+2 to D+15 forecast, and it is only a forecast: the published colour is what counts.
-- EDF Tempo (France): today's and tomorrow's colour, red-day risk at D+2,
-- red days left. Source: free JSON API of calendrier-tempo.fr (no key)
-- Put the name (or idx) of your devices, or nil to skip one.
local DEVICES = {
	today    = 'Tempo today',             -- Alert sensor
	tomorrow = 'Tempo tomorrow',           -- Alert sensor
	redRiskD2 = 'Tempo red risk D+2', -- Percentage sensor
	redLeft  = 'Tempo red days left',  -- Custom sensor
local NOTIFY_THRESHOLD = 50 -- notify if red risk at D+2 >= 50 % (nil = never)
local API = 'https://www.calendrier-tempo.fr/api/'
local LEVEL = { BLEU = 'ALERTLEVEL_GREEN', BLANC = 'ALERTLEVEL_YELLOW', ROUGE = 'ALERTLEVEL_RED' }
		timer = { 'every 30 minutes' },
		httpResponses = { 'tempo_today', 'tempo_tomorrow', 'tempo_remaining', 'tempo_predictions' },
	data = { lastNotified = { initial = '' } },
	logging = { marker = 'Tempo' },
		local function device(key)
			if DEVICES[key] then return domoticz.devices(DEVICES[key]) end
		-- Update an Alert sensor only when the value changes
		local function setAlert(d, level, text)
			if d and (d.text ~= text or d.color ~= level) then
				d.updateAlertSensor(level, text)
		if item.isTimer then
			for _, route in ipairs({ 'today', 'tomorrow', 'remaining', 'predictions' }) do
				domoticz.openURL({ url = API .. route, callback = 'tempo_' .. route })
			return
		if not (item.ok and item.isJSON and item.json and item.json.status) then
			domoticz.log('No usable response for ' .. item.trigger ..
				' (HTTP ' .. tostring(item.statusCode) .. ')', domoticz.LOG_ERROR)
			return
		local j = item.json
		if item.trigger == 'tempo_today' or item.trigger == 'tempo_tomorrow' then
			local isTomorrow = (item.trigger == 'tempo_tomorrow')
			local d = device(isTomorrow and 'tomorrow' or 'today')
			if j.status == 'ok' and LEVEL[j.couleur] then
				setAlert(d, domoticz[LEVEL[j.couleur]], j.couleur)
				-- /api/tomorrow returns "unavailable" until the colour is published
				setAlert(d, domoticz.ALERTLEVEL_GREY, isTomorrow and 'Not published yet' or 'Unknown')
		elseif item.trigger == 'tempo_remaining' then
			local d = device('redLeft')
			if d and j.status == 'ok' and j.remaining then
				d.updateCustomSensor(j.remaining.ROUGE)
		elseif item.trigger == 'tempo_predictions' and j.status == 'ok' then
			-- The list starts today; look for the D+2 date
			local t = os.date('*t')
			local dateD2 = os.date('%Y-%m-%d', os.time({ year = t.year, month = t.month, day = t.day + 2, hour = 12 }))
			for _, p in ipairs(j.predictions or {}) do
				if p.date == dateD2 and tonumber(p.probabilite_rouge) then
					local risk = math.floor(100 * p.probabilite_rouge + 0.5)
					local d = device('redRiskD2')
					if d then d.updatePercentage(risk) end
					if NOTIFY_THRESHOLD and risk >= NOTIFY_THRESHOLD and domoticz.data.lastNotified ~= dateD2 then
						domoticz.notify('Tempo', 'Red day likely on ' .. dateD2 ..
							' (risk ' .. risk .. ' %, forecast)', domoticz.PRIORITY_HIGH)
						domoticz.data.lastNotified = dateD2
Setup:
  1. Setup > Hardware: add a "Dummy (Does nothing, use for virtual switches only)" hardware, e.g. named Tempo.
  2. Click "Create Virtual Sensors" on it: two Alert sensors ("Tempo today", "Tempo tomorrow"), one Percentage ("Tempo red risk D+2") and one Custom sensor ("Tempo red days left", axis label: days).
  3. Setup > More Options > Events: new dzVents script, paste the code, check the device names at the top (idx works too, or nil to skip one), tick "Event active" and save.
The Alert sensor text stays BLEU, BLANC or ROUGE, so other scripts can simply test domoticz.devices('Tempo tomorrow').text == 'ROUGE' (e.g. to lower the heating set point). The notification uses whatever notification systems you already configured in Domoticz. One request every 30 minutes is plenty: responses are cached for 2 minutes on our side.
All fields are documented here: https://calendrier-tempo.fr/api-tempo
Data is CC BY 4.0, and every past forecast is published next to the real colour, errors included: https://calendrier-tempo.fr/historique-previsions
Feedback, bug reports or ideas for other fields are very welcome.
Jean-Pierre
Last edited by JeanPierreTempo on Monday 26 October 2026 9:06, edited 1 time in total.
JeanBonnot
Domoticz version: 2025.2
Re: [dzVents] EDF Tempo (France): today/tomorrow colour, red-day risk at D+2, red days left – free JSON API, no key
Post by JeanBonnot »
Bonjour Jean-Pierre et merci pour ton travail. Tu écris utiliser les données météo, utilises-tu l'historique tempo (données depuis sa création) croisé avec les archives météo pour déterminer ton d+x ?
jvdz
Domoticz version: 4.107
Post by jvdz »
@JeanBonnot, could you please post in English?
Tnx.
JeanPierreTempo
Hi JeanBonnot,
Yes. The forecasts combine three things:
1. Weather: Open-Meteo forecast temperatures (plus their trend and atmospheric pressure) for 9 French cities, weighted into a national average.
2. RTE's national consumption forecasts, since the colour decision depends on expected demand.
3. The Tempo calendar itself: how many red and white days are still left in the season, weekdays and public holidays, and the official rules (red only from November to March, never on weekends or holidays, at most 5 in a row).
On top of a weighted risk score, two machine learning models were trained on the seasons since 2019, matching the official Tempo colours with the weather and consumption of those same days. So yes, the Tempo history and the weather archives are crossed.
Every forecast is frozen when it is issued and published, misses included: https://www.calendrier-tempo.fr/historique-previsions
Method in detail (in French): https://www.calendrier-tempo.fr/methodologie
Forecasts 2 to 5 days ahead are the useful ones; beyond that it is a trend. Only the colour published the day before is official.
Jean-Pierre
TiXav
Post by TiXav »
Thank you, this is a usefull script and it is working well. As it happens, I was just in the middle of modifying an old python script that uses the RTE API, which is no longer working (they must have changed something again—the authentication, it seems). Are you the owner of https://www.calendrier-tempo.fr/api/ ? if yes, thank you also !
JeanPierreTempo
Yes, it's mine, glad the script works for you. For your Python script, it's a plain GET with no account or token, so there's no authentication to deal with.
If you need a field that isn't there, let me know.
Jean-Pierre
TiXav
Post by TiXav »
Perhaps, I explain bad. Your script and calendrier-tempo.fr replace now my old python script that was working with rte api that does not work because authentication change
JeanPierreTempo
Ah sorry, perfect, thanks!
Jean-Pierre
