Dashticz 4.0.10 release
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Hi All
Dashticz v4.0.10 - what's new since v4.0.5
Since v4.0.5 (6 Sep 2026) a lot has happened. Here is a summary of the most important additions and changes.
New widgets
  • HP iLO - a new widget that shows clustered HPE server info, read from the iLO Redfish API (based on my Domoticz HP iLO plugin). Every row has a small icon, and you choose which rows are shown and in which order (add with +, remove with -, reorder by dragging). Available rows: server name, model, power state, health, uptime (shown as days/hours/minutes), fan speed, CPU and inlet temperature, power usage, storage health, SSD lifetime, iLO firmware, network, serial number, minimum fan speed, thermal configuration and power regulator. Settings: iLO host, port, username/password, poll interval (sec) and font size. The iLO is queried server-side, so it does not have to be reachable from your browser.
  • PostNL - shows your incoming and sent PostNL shipments in one list, soonest first, each line with an icon. Own login and settings, poll interval and font size option. Based on my Domoticz PostNL plugin.
Widget menu
  • The widget cards are now sorted alphabetically.
  • Four cards per row instead of three (slightly smaller cards, same menu width).
  • Widgets now use explicit grid sizing, with a default 6x6 grid for widgets and blocks.
  • Fixed newly added widgets silently disappearing when you did not press Save, plus better save confirmation and error handling.
Cluster block
  • Dimmer devices can now be added in Switch mode (shown as a plain on/off toggle).
  • The row type is locked once the cluster has been saved.
  • Every row can have its own custom name.
  • The switch has been restyled.
Devices
  • Custom Device: the IDX field now also accepts v<idx> to use a Domoticz user variable (next to a device idx and s<idx> for scenes/groups). The config (cog) icon and the Device Config popup work for these too, and the "Last update" checkbox now works when unchecked.
  • Selector Switch dropdown: removed the generic "Select..." placeholder option.
  • Fixed the Thermostat/Setpoint plus/minus buttons not doing anything (issue #1292).
Look & feel
  • Blinds/Dimmer slider: new drag handle and bigger up/down/stop buttons and percentage labels, easier to use on touch screens.
  • Better contrast for the graph buttons, and a fixed graph canvas width.
  • Modern Dark: block backgrounds are flat again (the experimental gradient was reverted). Liquid Glass Blue and Grey are unchanged.
  • A styled offline screen is now shown when Dashticz cannot load its scripts, and there is better error handling when Domoticz is unreachable (or blocked by CORS).
Update
As always, take a backup of your custom folder before updating. If you find a problem, please report it on GitHub (https://github.com/Dashticz/dashticz) or reply here.
Full release notes: https://dashticz.readthedocs.io/en/late ... notes.html
HansieNL
Re: Dashticz 4.0.10 release
Post by HansieNL »
I'm rebuilding my old dashboard to the new version and still have a problem that my local calendars don't load. I have for example a link http://192.168.2.14/kalenders/bandsintown.ics
The calendar is still working in 3.14.
Loading the calendar from an external server https://... does work.
Is it even possible to load local calendar files or what am I doing wrong?
Blah blah blah
madpatrick
Can you check new version on Master
HansieNL
Post by HansieNL »
Great!... With this version I can use my local ics files.
Blah blah blah
HansieNL
Post by HansieNL »
@madpatrick Is it possible to have more than 1 calendar in a calendar block and what code to use if possible. I can't find the new instructions anymore :?
Thanks for the help.
Blah blah blah
madpatrick
You can place multiple agenda from the wizard menu
Not sure how it was in the older versions, but i think
blocks['my_calendar'] = { type: 'calendar', layout: 0, maxitems: 10, icalurl: {
Personal: { ics: 'https://your-calendar-url-1/basic.ics', color: 'blue' },
Business: { ics: 'https://your-calendar-url-2/basic.ics', color: 'orange' },
Family: { ics: 'https://your-calendar-url-3/basic.ics', color: 'green' }
}, weeks: 5,
width: 12 }
HansieNL
Post by HansieNL »
:roll: I tried the wizard to create
a multiple calendar block, but to use two icalurl fields is not allowed. Can you explain how I can do that in the wizard?
Thanks in advance.
Blah blah blah
madpatrick
Check the new version 4.0.12
i've added the possibility for multiple calendars.
Please test
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
I have a problem with Dashticz 4.x on Chromium.
After clicking a normal Domoticz device/switch tile, a thick white focus outline remains around the tile.
This happens on Chromium (Raspberry Pi kiosk), but not in Firefox.
On the same Raspberry Pi / Chromium setup, my old Dashticz 3.14 does not show this outline.
Example affected block:
div.mh.transbg.dt_block.block_58.col-xs-12.off
In Chromium, after clicking the tile, computed style shows:
outline: rgb(255, 255, 255) 3px
outline-width: 3px
box-shadow: none
I also tried adding:
.mh,
.mh * {
outline: none !important;
-webkit-tap-highlight-color: transparent !important;
but the white outline still remains on some tiles.
I checked creative.css and I cannot find a rule that would normally add a white 3px outline to regular .mh device tiles.
Is this a known change related to Bootstrap 5 / focus handling in Dashticz 4.x?
Has this perhaps already been fixed in 4.0.12?
Zrzut ekranu 2026-09-22 212842.png (115.96 KiB) Viewed 1429 times
Thanks.
madpatrick
I've created an issue on git
Please use git for issues
Daro1003
Post by Daro1003 »
Thanks. Could you please send me the link to the GitHub issue? I’ll continue there.
madpatrick
jake
Post by jake »
I updated from 3.14 to 4.12
Many GUI flaws, I need to work them out, I guess. Anyway, the background was constantly the dashticz logo, while per screen my default bg4.jpg was defined. I now added the config background en now that works.
With the console in the browser, I see that it can't save PHP? All and all, I thought that I should better start over fresh, so I try to go down the Docker route.
Problem 1: can't find actual documentation. The described 'automatic' installation, doesn't work with this command (as per documentation):
https://dashticz.readthedocs.io/en/mast ... stall.html#
. <(wget -qO - https://raw.githubusercontent.com/Dasht ... install.sh )
madpatrick
jake wrote: Wednesday 23 September 2026 23:28 I updated from 3.14 to 4.12
Hi Jake,
I just checked, but the install is working normally
bash -c "$(curl -fsSL https://raw.githubusercontent.com/dashticz/dashticz/master/install.sh)"
You can also use the script for setting the rights correctly
/tools/install-dashticz-write-access.sh
Docuemnetaion is not (yet) updated to v4
If there are any volunteers that would be great ;)
jake
Post by jake »
Where do I need to start this command?
bash -c "$(curl -fsSL https://raw.githubusercontent.com/dasht ... install.sh)"
for my docker containers, I store all related data in a sub folder of my created: /home/pi/docker-container/ keeping all docker info nicely together. Dashticz now runs in /var/www/html/dashticz
You need an insider to generate the documentation. How can people help, documenting, if we don't know about the functionality? For instance, I don't get the backgrounds to work properly per page, maybe something has changed, but I can't find out about the change without a rudimentary documentation about the changes between 4.x and 3.x
madpatrick
Yes, you can still run it as a container.
The installer only clones the repo, but the repo itself includes a Dockerfile, a Makefile and a docker-compose.yaml.
By default the installer clones into ./dashticz relative to where you are, but you can pass the target folder directly:
So:
bash
bash -c "$(curl -fsSL https://raw.githubusercontent.com/dashticz/dashticz/master/install.sh)" -- --directory /home/pi/docker-container/dashticz
cd /home/pi/docker-container/dashticz
Then either use the Makefile (same as in v3):
bash
make start            # port 8082
make start PORT=8090  # other port
or docker compose:
bash
docker compose up -d
Both bind-mount the Dashticz folder into the container, so your config stays in /home/pi/docker-container/dashticz/custom. Copy your existing custom/ files from /var/www/html/dashticz before starting. make help shows the other options (stop, rebuild, update).
If you a problem or something is not working, please open an issue on git
Give a description off the issue and post your config or give extra information
General statements as ...... is not working is difficult to solve,
