Dynamic dashboard seems to cause repeating login
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
wim57
Post by wim57 »
I have been using the dynamic dashboard for some weeks without problem but this morning I was not able to login to Domoticz from remote ip anymore. After loading the dynamic dashboard Domoticz immediately got back to the login page again.
I tried different devices, different browsers, deleting cookies and even restarting Domoticz but nothing helped.
In the end I could access the UI from a trusted local network and was able to set the dashboard back to 'Favorites' again. After that the remote login problem was gone.
Any idea what could be the cause of this problem?
My Domoticz is version 2026.2, build hash f3afb08ad.
HansieNL
Re: Dynamic dashboard seems to cause repeating login
Post by HansieNL »
I have the same problem when I try to use the dashboard dynamic view of showing a login screen. I have made local network settings and don't have this problem with dashboard favorites view.
Using beta v2026.3 (build 18324)
Blah blah blah
gerardvs
Domoticz version: latest-1
Post by gerardvs »
wim57 wrote: Sunday 30 August 2026 14:54 I have been using the dynamic dashboard for some weeks without problem but this morning I was not able to login to Domoticz from remote ip anymore. After loading the dynamic dashboard Domoticz immediately got back to the login page again.
If you use the Google Calendar or RSS widget then this is caused by the cors proxy. The ones hardcoded in the code are not working anymore. I created a small proxy on node-red to solve this problem but ideally it should not be dependent on that.
See also at: viewtopic.php?t=45175
wim57
Post by wim57 »
Thank you, now I just have to find out how to remove the calender πŸ˜‰
gerardvs
Post by gerardvs »
wim57 wrote: Sunday 30 August 2026 18:09 Thank you, now I just have to find out how to remove the calender πŸ˜‰
in you domoticz directory goto www/app/dashboardDynamic/widgets and edit the file ddGoogleCalendar.widget.js
In this file there is the following section:
               // ── Fetch with proxy fallback ─────────────────────────────
                var ICS_PROXIES = [
                    null,           // try direct first (works for same-origin or CORS-enabled sources)
                    '__domoticz__', // server-side proxy via Domoticz backend
                    'https://corsproxy.io/?url=',
                    'https://api.codetabs.com/v1/proxy?quest='
Change this to:
                var ICS_PROXIES = [
                    '__domoticz__' // server-side proxy via Domoticz backend
Then goto the Domoticz dashboard and hard reload the main page (ctrl+f5). Then you see the widget (with an error) and are able to remove it or change the url like I did to point to my own proxy.
gizmocuz
Post by gizmocuz »
Thanks for the report, and to those who confirmed it. I found the cause and it is fixed in the next beta (build 18327 or later).
What was happening
The Google Calendar widget (and the RSS widget) could fall back to a public CORS proxy (corsproxy.io) to load the feed. That service now demands an API key and answers every request with HTTP 401. The Domoticz web interface treated any 401 as "your session has expired" and sent you back to the login page. Because the dashboard was your start page, it loaded the widget again straight after logging in, hence the loop. On top of that, the calendar widget had a bug that made it skip Domoticz's own server-side fetch and go to the public proxy even when the server could fetch the calendar fine.
The fix
  • A 401 from any host other than your Domoticz server no longer logs you out.
  • The public CORS proxies are gone. Feeds and calendars are now fetched by the Domoticz server itself, so your (private) calendar URL never leaves your network. This does mean the Domoticz server needs internet access to load them.
  • The calendar widget's server-side fetch actually works now.
Until you are on the new beta (which is available in some minutes), removing the Google Calendar / RSS widgets (or changing your start page) is the workaround, as already noted above. Once updated you can add the calendar widget back.
