I am using the Google Calendar widget (ddGoogleCalendar.widget.js) on the new dasboardDynamic. Since corsproxy.io has changed their policy and codetabs.com is offline the widget does not work anymore and even blocks the entire dashboard function.
Is this problem already known and if so what is the future of this widget. As a workaround I have locally setup a cors proxy and modified the widget to use this proxy and skip the encodeURIComponent part. Also I have changed the code to show a 24 hour clock instead of 'banana time'. This works but any update will kill the changes of course.
--Gerard
Cors issue with some dashboardDynamic widgets
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
