I'am/was om 2025.2 and wanted to update to the last version
I get this error and can't find the solution on the internet
error while loading shared libraries: libmosquitto.so.1: cannot open shared object file: No such file or directo>
Does someone has the solution?
Update goes wrong Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
niki_lauda
Update goes wrong
Last edited by niki_lauda on Monday 24 August 2026 19:48, edited 2 times in total.
- jvdz
- Domoticz version: 4.107
Re: Update goes wrong
Guess you first need to give way more details about your problem before we can make suggestions for a fix.
niki_lauda
sorryjvdz wrote: Monday 24 August 2026 19:44 Guess you first need to give way more details about your problem before we can make suggestions for a fix.![]()
- jvdz
So you seem to have this issue?:
https://www.ncartron.org/fixing-domotic ... grade.html
niki_lauda
Mijn dank is grootjvdz wrote: Monday 24 August 2026 19:44 Guess you first need to give way more details about your problem before we can make suggestions for a fix.![]()
