(Python 3.13+ compatible).
We’ve added a responsive web interface right inside the Domoticz Custom menu.
* 1-Click Management: Install, update, or remove plugins effortlessly—no more SSH or manual folder dropping!
* Search & Filter: Snappy type-ahead search and an "Installed" toggle make finding what you need a breeze.
* Direct Repo Links: Check out a plugin’s source code instantly right from its card.
* Bulletproof Dependencies: Safely isolates dependencies in a .shared_deps folder without requiring sudo or global pip. Uses uv for blazing-fast installs (if possible).
* Smarter Security: The built-in AST scanner has been overhauled to better catch malicious code while vastly reducing false positives (like ignoring private IPs).
* Auto-Updating: Let the store automatically update your plugins, or just notify you when updates are ready.
* Decoupled Registry: The plugin list syncs dynamically from GitHub every month, meaning you get new plugins in your store without needing to update the manager itself!
Simply clone it into your plugins folder as 00-PyPluginStore. (Note: Existing users using 00-PP-MANAGER don't need to rename their folder, the code is fully backwards compatible!)
1 cd domoticz/plugins
2 git clone https://github.com/adrighem/PyPluginStore.git 00-PyPluginStore
3 sudo systemctl restart domoticz.service
Check out the full details and screenshots on the GitHub Repository (https://github.com/adrighem/PyPluginStore).
I'd love to hear your feedback on the new interface. Happy automating!
