When using the "Notification" feature of a temperature sensor, how do I include the device's temperature value in the message?
This doesn't work : "Temp : {{temperaturedevice[34287]}} "
Thanx
Device values in notification
- JeanBonnot
- Domoticz version: 2025.2
- Domoticz version: 2026.3
Re: Device values in notification
There is no way to program this from the default Edit Notifications dialog.
You cannot set a custom notification message with parameters. It can be done with for example dzvents scripting.
But the standard message contains already the temperature!
For example: If you set send notification when temperature is above 30 you will get the following notification message when temp is 32:
<Your tempdevicename> is 32.0 degrees > 30.0 degrees
gerardvs
- Domoticz version: latest-1
You could use: Temp: $valueJeanBonnot wrote: Friday 26 June 2026 9:25 Hi all,
Thanx
Thanks I did not know this and added it to the wiki.
You can use paramerers $name and $value to create your own custom message.
