Small issue.
If I define a counter device , type custom, unit Euro and then update it with for example 0.30, the displayed amount top right remains 0, while the amount shown under the title bar is shown correctly as 0.3 Euro. Also when I add more small amounts the top right amount remains 0.
If I add a divider of 100 and multiply the amount by 100, then it works correctly. So if I add 30 with a divider of 100, then both amounts on the icon shown 0.3 Euro
Is this a bug?
strange behavior: euro amount on counter
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: strange behavior: euro amount on counter
Counters normally want integers as input. If you want to report on digits you indeed need a divider.
It is the same for water and electricity (they use default divider of 1000).
So it is not a bug, it is a feature..
willemd
Maybe it could become a documented feature ?
It is already documented in the API wiki https://wiki.domoticz.com/Domoticz_API/ ... 7s#Counter
Edit: In the Dummy virtual devices it was also already explained in more detail.
https://wiki.domoticz.com/Dummy_for_vir ... es#Counter
But I will make it more clear in the divider description.COUNTER = Integer of the overall total counter (Energy, Volume, Custom).
willemd
thanks for your effortwaltervl wrote: Friday 26 June 2026 8:41 It is already documented in the API wiki https://wiki.domoticz.com/Domoticz_API/ ... 7s#CounterBut I will make it more clear in the divider description.COUNTER = Integer of the overall total counter (Energy, Volume, Custom).
