get value from json table containing spaces  [Solved]
DomoFlits
Domoticz version: Bld16583
Post by DomoFlits »
I can get status values from my fan by calling http://192.168.1.220/api.html?get=ithostatus
This returns:
{"temp":26.5,"hum":49.3,"ppmw":10853,"Speed status":44,"Internal fault":0,"Frost cycle":0,"Filter dirty":0,"AirQuality (%)":"not available","AirQbased on":0,"CO2level (ppm)":"not available","Indoorhumidity (%)":49,"Outdoorhumidity (%)":"not available","Exhausttemp (°C)":"not available","SupplyTemp (°C)":"not available","IndoorTemp (°C)":"not available","OutdoorTemp (°C)":"not available","SpeedCap":63488,"BypassPos (%)":"not available","FanInfo":"auto","ExhFanSpeed (%)":44,"InFanSpeed (%)":0,"RemainingTime (min)":0,"PostHeat (%)":"not available","PreHeat (%)":"not available","InFlow (l sec)":"not available","ExhFlow (l sec)":"not available","Ventilation setpoint (%)":44,"Fan setpoint (rpm)":1113,"Fan speed (rpm)":1116,"Error":0,"Selection":7,"Startup counter":16,"Total operation (hours)":184,"Absence (min)":0,"Highest CO2 concentration (ppm)":"not available","Highest RH concentration (%)":49,"RelativeHumidity":49.29,"Temperature":26.52}
I want to use fields 1 (temp), 2 (hum) and 4 (Speed status) in domoticz. (in below script I write them only to the log first, so I can see what is happening)
The temperature and humidity is not a problem, but the speed status is, since I don't know how to deal with spaces.
domoticz.log(item.json.Speed status) doesn't work
replacing "speed status" by "speed" using a local variable doesn't work also
does anyone has the :idea: for me how to use it?
I wrote this script:
        timer = {
        'every 2 minutes',
        httpResponses = { 'trigger' }
	logging = {
--		level = domoticz.LOG_STATUS,
		level = domoticz.LOG_DEBUG,
		marker = 'itho-status',
    if (item.isTimer) then
        domoticz.openURL({
            url = 'http://192.168.1.220/api.html?get=ithostatus',
            callback = 'trigger'
    if (item.isHTTPResponse) then
        if (item.ok) then
            if (item.isJSON) then
		local speed = "Speed status"
            	domoticz.log(item.json.temp)
            	domoticz.log(item.json.hum)
            	domoticz.log(item.json.speed)
jvdz
Domoticz version: 4.107
Re: get value from json table containing spaces  [Solved]
Post by jvdz »
Try:
item.json["Speed status"]
DomoFlits
Post by DomoFlits »
Thanks. this works.
I tried
item.json.["Speed status"]
before but that didn't work :oops: . It had one dot ( . ) too many.
full working script for the next reader, including writing the values into (virtual) sensors in Domoticz:
        timer = {
        'every 2 minutes',
	logging = {
		-- Level can be domoticz.LOG_INFO, domoticz.LOG_STATUS, domoticz.LOG_ERROR or domoticz.LOG_DEBUG
		level = domoticz.LOG_ERROR,
--		level = domoticz.LOG_DEBUG,
        domoticz.openURL({
        if (item.ok) then
--              domoticz.log(item.json.temp)            -- write value to log for debugging
--              domoticz.log(item.json.hum)             -- write value to log for debugging
--              domoticz.log(item.json["Speed status"]) -- write value to log for debugging
                domoticz.devices(342).updateTemperature(item.json.temp)             -- write value to Domoticz-sensor
                domoticz.devices(343).update(item.json.hum)                         -- write value to Domoticz-sensor
                domoticz.devices(341).updatePercentage(item.json["Speed status"])   -- write value to Domoticz-sensor
