I have been using Domoticz on Linux for quite some time, in combination with a tablet running Fully Kiosk Browser and a Dashticz dashboard. This setup has always worked flawlessly. Today, I upgraded Domoticz to the latest version (2026.1). After the upgrade, several devices are no longer visible in Dashticz. Instead, an empty tile appears with the text "Getting device 1329," where 1329 is obviously the index number of the device in question. Strangely enough, some devices are still visible and functional.
After extensive troubleshooting in the CONFIG.js file, I noticed one odd pattern: the devices that are still visible all have an index number below 1000, while the devices that are no longer visible have an index number above 1000.
Could this be a bug? Or has anyone a suggestion how to troubleshoot this issue?
Thanks for your help in advance.
Kind regards,
Frank
Some devices not visible in Dashticz dashboard after upgrade to 2026.1
- gizmocuz
Re: Some devices not visible in Dashticz dashboard after upgrade to 2026.1
@Frank,
I have no idea about Dashticz, and Domoticz now supports dynamic dashboards (you can enable this in the user profile), be sure to be on the beta version.
solarboy
- Domoticz version: 2026.4
You have no idea about dashticz ? It's a dashboard implementation that has been used within the Domoticz eco-system for many years.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
- gizmocuz
Nope, never used it.
