Unable to Install Topic is solved
Duzeper
Unable to Install
Post by Duzeper »
System: RPi 3B+
Operating System: Debian GNU/Linux 13 (trixie)
Kernel: Linux 6.12.75+rpt-rpi-v8
I am trying to install Domoticz 'The "easy" way', ie
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
and I get as far as the first dialog - Domoticz automated installer - but the <Ok> button is not active. All I see is a text cursor and nothing happens if I click it so I can get no further. In fact, I can only close the teminal by performing a reboot.
You will have probably gathered by now, that I am pretty much a 'noob' as far as this is concerned, so any help would be much appreciated.
Domoticz version: 2026.3
Re: Unable to Install
Did you try [tab] to select and [space] to confirm?
Duzeper
Post by Duzeper »
That's fixed it. Many thanks.
