Version 2026.1 Error Log now shows device idx name, but not for every entry
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- imautohuttraeger
- Domoticz version: lat.beta
I am happy that the new error logs are also showing device information which helped me already with another issue. However, I have one error log, where it is still not shown:
Error: Invalid Number sValue: '%' for device idx: '%'
Is there any possibility to get the IDX that causes this problem?
Last edited by imautohuttraeger on Saturday 28 March 2026 14:17, edited 1 time in total.
Stop, look and listen.
- Domoticz version: 2026.3
Re: Version 2026.1 Error Log now shows device idx name, but not for every entry
You perhaps can add extra debugging options in menu Setup - Settings, tab Logs to identify the IDX?
- imautohuttraeger
I have activated all the options of the lock levels and now the system is hanging . Is there any possibility for me to start the system in a minor environment, so I can deactivate these lock levels?
- imautohuttraeger
All clear: Fortunately, after restarting domoticz, the log level check boxes are automatically deactivated again.
However, even if I activate one log level option after the other, there is no hint on idx in the lock errors
- gizmocuz
I have found the lines with these errors, they are in WebServer.cpp line 2827/2832
This should give you a hint. Have you been poking in the database with a script?
result2 = m_sql.safe_query("SELECT Value FROM Meter WHERE (DeviceRowID='%q' AND Date>='%q') ORDER BY Date LIMIT 1", sd[0].c_str(), szDate);
if (!result2.empty())
std::vector<std::string> sd2 = result2[0];
if (sd2[0].empty())
_log.Log(LOG_ERROR, "Empty Value in Meter table for device idx: '%q'", sd[0].c_str());
continue;
if (!is_number(sValue))
_log.Log(LOG_ERROR, "Invalid Number sValue: '%q' for device idx: '%q'", sValue.c_str(), sd[0].c_str());
continue;
if (!is_number(sd2[0]))
_log.Log(LOG_ERROR, "Invalid Number value: '%q' for device idx: '%q'", sd2[0].c_str(), sd[0].c_str());
continue;
- imautohuttraeger
Thx for this research. I don't even now how to "poke the database with a script". For scripting, I am more / less only able to copy code and amend it for my needs by trial and error.But without really knowing what I do ... so maybe unintentionally ...
Your hint brings me to the idea, to deactivate each script ceteris paribus and see, if the error disappears.
- imautohuttraeger
I came a little step foreward. Deactivating scripts had no effect.
But meanwhile I detected, that the error occurs every time, the log of any utility device is opened forces this error exactly at the time when you click on "back". (The log of other devices like switches etc. has no effect on this.)
However, the error also seems to appear, when no user interaction is made. But with the "method" described above it can be forced. See video capture with the link below.
https://photos.app.goo.gl/osi34Z3ysKi4ssyaA
- imautohuttraeger
Fortunately, meanwhile the IDX is shown in the log (it was not at the time of this topic here)
Finally, @jdvzs gave me the decisive clou about how to fix my problem: A manual udevice json api call to update the svalue to a proper number.
I did this for several spoiled devices, then the devices appeared again in the device list and I could delete it. So there won't be any svalue error again.
Here is the other topic, where I have got that help:
viewtopic.php?p=336804#p336804
http://uid:psw@ipaddress:8080/json.htm?type=command¶m=udevice&idx=<DEVICE-ID>&nvalue=0&svalue=0Here is the other topic, where I have got that help:
