I have the same problem, also with an outdated P-counter. In the error log of the new 2026.1 version I can now see the idx, so the beta is nod needed anymore. Can you give me a recommendation about an SQLite database editor (preferred for windows) and how I can find the device's entries and what must be modified in order to see the device again in the device list so it can be deleted? Thank you in advance.Filnet wrote: Thursday 19 March 2026 23:06 Success!
I was able to retrieve the device's ID and name. However, this device no longer existed in the Domoticz device table. Using an SQLite database editor, I found the missing device with an incorrect sValue. I modified the sValue to the correct value (it was a P-counter). It then reappeared in the Domoticz device list, and I was able to delete it.
The 'stoull' error message no longer appears.
Thank you for your help and quick response.
Error: GetJSonDevices: exception occurred : 'stoull'
- imautohuttraeger
- Domoticz version: latest
Re: Error: GetJSonDevices: exception occurred : 'stoull'
Stop, look and listen.
- Domoticz version: 2026.3
- imautohuttraeger
Thanks for the hint(s). Finally I could manage to detect the IDX with the "stoull" error with DB Browser SQLite, erased the svalue, then could see it in the device list in Domoticz again and was able to delete it. The error is gone now. So I am one step further to get a clean system!
