Embedded Energy dashboard is not loaded anymore since I updated to beta 17502
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hansvanlin
Post by hansvanlin »
For a long time I used the Energy dashboard embedded on a node-red UI this was not a problem. (viewtopic.php?t=44289 )
before upgrade:
after upgrade to 17502:
It looks that the stricter Content-Security-Policy (CSP) send with the energy dashboard or X-Frame-Options is preventing loading the dashboard in an embedded way. It is possible to load the energy dashboard in a separate window but that doesn't look so nice.
Does anybody now a workaround for loading the energy dashboard embedded?
hansvanlin
Re: Embedded Energy dashboard is not loaded anymore since I updated to beta 17502
I found that something is changed in the latest beta https://github.com/domoticz/domoticz/pull/6676
possible cause new security headers:
iamserver/IamService.cpp: pass TLS flag to add_security_headers() to align with the libwebem update (security headers now sent over plain HTTP; HSTS only over TLS per RFC 6797)
or DOMPurifyis is not configured anymore for iframe:
Used AI to find out what DOMPurifyis doing and it looks it can be configured to safely load iframe:
gizmocuz
Post by gizmocuz »
Should be solved now in beta 17508
Question, why are you using Node-Red dashboard and not make yourself a good looking template that you can place in Domoticz www/templates folder?
(Possibly send some MQTT values with MQTT-AD to Domoticz)
I think Node-Red is great, but I have this one running in the background and almost never touch it. All values that I need are going to Domoticz
hansvanlin
I use Node-red dashboard because it is fast and easy to make and I can connect every platform/brands without editing templates. For al lot of things you want to display in a dashboard there are nodes available. Just drag and configure and it is ready to display on the dashboard.
Unfortunately upgrading to latest version didn't solve this issue.
But I see a lot of new features ...thanks!
hansvanlin
Found a fix:
installed an extension in fire-fox which disables the CSP protection.
To solve this properly Domoticz Energy Dashboard should be allowed to display in an iframe especially if iframe is running on the same device (rpi).
eg:
