solaredge api
tiga
solaredge api
Post by tiga »
i used the solaredge web api for years with succes.but now it stops working.
after some investigation it seems that you have to use your "site id".
i see on the wiki that you can fill it in in domoticz https://wiki.domoticz.com/SolarEdge.
but in my version i can only fill in the api.
i am running Version: 2025.2
how to fix?
Doler
Re: solaredge api
Post by Doler »
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
gizmocuz
Re: solaredge api
Post by gizmocuz »
Try the new beta version of Domoticz tomorrow during sunny hours... (After the update enter additional settings in the hardware setup)
BartSr
Domoticz version: V2024.7
Re: solaredge api
Post by BartSr »
Solaredge working again using docker beta
All panels are on device list but on utility page no data in devices whereas it is in devicelist
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
gizmocuz
Re: solaredge api
Post by gizmocuz »
BartSr wrote: Saturday 14 March 2026 9:52 Solaredge working again using docker beta
Do you have a SolarEdge inverter? Yes, you might get many new devices, you need to add them from the devices overview, use the 'Add' button
BartSr
Re: solaredge api
Post by BartSr »
Thanks Gizmocus.
Probably I did not mention correctly. I'd expected to have power visible in Lifetime Energy
Furthermore Solaredge : before Solaredge temp and other devices where visible (see picture)
This is no longer supported?
BTW great data off all panels is visible now.
Schermafbeelding 2026-03-14 130356.png (73.83 KiB) Viewed 3779 times
Schermafbeelding 2026-03-14 125641.png (11.88 KiB) Viewed 3783 times
Schermafbeelding 2026-03-14 125604.png (10.55 KiB) Viewed 3783 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Re: solaredge api
Post by gizmocuz »
Should be added in beta 17374, available in 10 minutes
BartSr
Re: solaredge api
Post by BartSr »
17374 not yet showing the 'old' solaredge devices
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
