Docker: PluginSystem: Failed dynamic library load
Varazir
Post by Varazir »
Hello
I'm running Domoticz in docker and I see this in the startup log
Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
About Domoticz
v2025.2 (build 17204)
System Information
Build Hash
71a61ff22
Compile Date
2026-02-20 11:33:19
dzVents Version
3.1.8
Python Version
None
I enter the command prompt for the docker and it said it's installed.
root@a78701199ed2:/opt/domoticz# apt install libpython3-stdlib
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
libpython3-stdlib is already the newest version (3.11.2-1+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
BarryT
Domoticz version: 2024.3
Re: PluginSystem: Failed dynamic library load
Post by BarryT »
U need to install the lib and dev version of python, then it should work again.
Use customstart.sh (in the root directory of your domoticz container volume):
#!/bin/bash
if [ -f /opt/domoticz/FIRSTRUN ];
then
	true
	echo "Already installed everything... Normal startup of Domoticz."
touch /opt/domoticz/FIRSTRUN
echo 'creating FIRSTRUN file so script can check on next run'
apt update -y && apt upgrade -y
echo "cache en system updated & upgraded "
apt-get install -y libpython3.11 python3.11-dev
echo "installed python 3.11-dev & libpython3.11"
## rest of code if need to install more ##
Domoticz version: 2025.1
Installing extra Python libs to get the Python plugin system working on the Docker image should not be needed.
This seems to be an issue on the docker build.
Edit: Github issue created https://github.com/domoticz/domoticz-docker/issues/33
BarryT
Re: Docker: PluginSystem: Failed dynamic library load
Post by BarryT »
Thats true, but that should at least fix the python error in latest version.
Varazir
Post by Varazir »
waltervl wrote: Friday 20 February 2026 23:37 Installing extra Python libs to get the Python plugin system working on the Docker image should not be needed.
Works now :)
