Marstek OpenAPI
eddieb
Re: Marstek OpenAPI
Meanwhile I updated my plugin to 1.0.4
I tried to power down my Venus E v2 but after holding the powerbutton for about 10sec it powersdown and immediatly powers up again ...
Still no luck
Still no luck
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
willemd
- Domoticz version: 2026.3
Re: Marstek OpenAPI
And after that, re-enabled the API I assume?eddieb wrote: Sunday 15 February 2026 9:54 Meanwhile I updated my plugin to 1.0.4
Still no luck
I am sorry, I cannot help any further. If it is not a network issue, then maybe it is model related. I would ask Marstek for assistance. There is also a tweakers forum about communciation with the Marstek Venus E, maybe you can find more info there.
On the tweakers forum someone mentions that the default port in his system was 28416. Maybe that is the clue? Check the APP and/or try that port (is configurable in the plugin).
esflint
Re: Marstek OpenAPI
Yes, I enabled the open API in the Marstek app. and rebooted the battery just in case.
Now this message shows that it probably gets no data from the Venus:
2026-02-15 11:14:03.200 Marstek Venus C: get mode data received: None
2026-02-15 11:14:03.200 Error: Marstek Venus C: No data received during complete cycle. Cycle nr 1
2026-02-15 11:14:03.200 Error: Marstek Venus C: Timeout on getting Marstek Venus data. Check connection and/or Open API setting in App.
2026-02-15 11:14:03.301 Marstek Venus C: onHeartbeat called
I requested a firmware update by Marstek since V153 is one of the first with the open API enabled.
willemd
Re: Marstek OpenAPI
You can try to run
sudo nmap -sUV IPaddress -p 30000
or, to scan a range of ports:
sudo nmap -sUV IPaddress -p 28000-30000
(filling in your IPaddress of course)
and see whether it report the port open/filtered or closed.
On my system it comes back with the port open and reports the MAC address.
esflint
Re: Marstek OpenAPI
Port is open:willemd wrote: Sunday 15 February 2026 12:00 You can try to run
28416/udp open|filtered unknown
MAC Address: 24:19:72:87:5E:CC (Quectel Wireless Solutions)
I changed it to 28416.
willemd
Re: Marstek OpenAPI
And does the plugin and API work on that port?
esflint
Re: Marstek OpenAPI
They both work on that port. I also checked the connection with Postman but get no response from the battery.
- jvdz
- Domoticz version: 4.107
Re: Marstek OpenAPI
Shouldn't this be tcp instead of udp?28416/udp open|filtered unknown
willemd
Re: Marstek OpenAPI
No, these battery systems use UDP for the local API (unfortunately)
willemd
Re: Marstek OpenAPI
As an alternative, you could also try thisesflint wrote: Tuesday 17 February 2026 21:31 They both work on that port. I also checked the connection with Postman but get no response from the battery.
https://github.com/tomquist/hame-relay
This basically communicates with the cloud (so not using local API) in the same way the Marstek App does, via MQTT.
You can use the docker installation, without the home assistant part.
If that works, an intergration to Domoticz should be easy as a next step.
eddieb
Re: Marstek OpenAPI
I finally had time to fully reboot my Venus v2 battery ... (need to disconnect RS485 connection because that one keeps the battery ON ...)
1 disconnected rs485
2 tested on udp/30000, still timeouts, no luck
3 tried to disable API thru the ap, no luck, gives a configuration error.
4 power down the battery and waited 15 minutes
5 power on without rs485 connection
6 tested on udp/30000, still timeouts, no luck
7 tried to disable API thru the ap, no luck, gives a configuration error.
8 power down and reconnect rs485
everything works as before test ...
So, for some reason, there is something on UDP/30000 (tested with nmap) but not working on my Venus E v2
If someone has other findings, I would like to know the differences
willemd
Re: Marstek OpenAPI
Did you run the scan for other ports than 30000?
eddieb
Re: Marstek OpenAPI
yes, I did a full scan
willemd
Re: Marstek OpenAPI
I trust you know what you are doing, but just to be sure..... when you state tested on UDP/30000 I assume you mean IP/3000, so you tested on your Marstek IP address and port 30000 ?
Especially the fact that you get configuration errors when using the App I find strange. Are the other app function working O.K..? I am asking because the alternative mqtt integration I mentioned has the possibility to disconnect from cloud MQTT and connect to local MQTT (for certain models, not Venus A). You did not switch off cloud MQTT in the past?
I would raise it with Marstek (not sure where ) as an issue that you get a configuration error and are unable to activate local Open API. Seems to be a model/device related issue.
eddieb
Re: Marstek OpenAPI
Sure,
I ran nmap against the IP of the battery and checked port 30000 ... As network person I call this UDP/30000 ...
the app functions normal, It shows what it has to show. The only thing not working is disabling local api, that gives an error.
I did ENABLE it a couple of weeks ago and did not get an error ...
I can even change the port from 30000 to 30001
and no, I did not disable MQTT, all stats and graphs are working normally in the app
nmap -sU-sV 192.168.0.155 -p 30000
Starting Nmap 7.98 ( https://nmap.org ) at 2026-02-18 22:10 +0100
Nmap scan report for marstek-bat (192.168.0.155)
Host is up (0.024s latency).
PORT STATE SERVICE VERSION
30000/udp open|filtered unknown
MAC Address: 00:00:FF:06:A1:C3 (Camtec Electronics)
Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 99.49 secondsI did ENABLE it a couple of weeks ago and did not get an error ...
willemd
Re: Marstek OpenAPI
I just tried on my Venus A.
Disabling Open API also in my app results in a device config error, after about 5 seconds (I tried a few times). Enabling is no problem though.
eddieb
Re: Marstek OpenAPI
Ok, so this seems not related to my Venus E v2 setup ...
investigating goes on
willemd
Re: Marstek OpenAPI
I also managed to get this hame-relay working which exchanges MQTT message with the Marstek/Hame cloud, so not via local API. I got some support from Tomquist on it, have a look at issue 129 for details. Sending the cd=01 message will give back your Marstek config, which might help in testing the local API further. Or alternatively, the MQTT responses could be processed onto Domoticz devices. I can even see in the response whether local API is enabled. All I need now is the command to re-enable it if it was disabled due to a reset.willemd wrote: Wednesday 18 February 2026 8:01As an alternative, you could also try thisesflint wrote: Tuesday 17 February 2026 21:31 They both work on that port. I also checked the connection with Postman but get no response from the battery.
willemd
Re: Marstek OpenAPI
I just discovered a new undocumented feature in the Marstek Open API: if you define a manual mode period with power set to -1 it means it will activate self consumption mode in that period. (like you can choose self consumption in the App)
So to use this with the plugin:
1) set the manual mode power device to -1 and set the periodnr, start/end time and selected weekdays, for example with a dzvents script.
2) press the manual mode option on the selector switch
3) the plugin will then send that configuration to the Marstek battery and it will also become visible in the app.
Note there is also a permanent self consumption mode available on the switch, not limited to a defined period.
eddieb
Re: Marstek OpenAPI
I also have this hame-relay working in docker. Following the instructions and sending the cd=01 gave me the type of battery (HMG-50 for my Venus E2) and the 12 digit bluetooth macaddres ...willemd wrote: Wednesday 18 February 2026 8:01As an alternative, you could also try thisesflint wrote: Tuesday 17 February 2026 21:31 They both work on that port. I also checked the connection with Postman but get no response from the battery.
after that I installed https://github.com/tomquist/hm2mqtt in an other docker .
Because I was allready running MQTTAD 94 devices from hm2mqtt where automagically created in my domoticz ...
Some things to consider ...
hm2mqtt polls the cloud values thru hme-relay every minute. There are a lot of timeouts, the cloud seems not to stable, not stable enough for me ...
the values on the devices produced sometimes are not the right values, for example the temerature is wrong and so are some other values ..
Needs more work
