I have a Dzvents script that will update a user variable every minute and makes a note of the variable update in the log:
2026-02-11 13:51:00.735 Status: Set UserVariable nomotionCounter = 380
Is it possible not to update the log with (this) User variable updates? As this is information that I don't really need in the log.
No logging of variable updates
- Domoticz version: 2025.1
Re: No logging of variable updates
What version of Domoticz are you on?
Do you have a log statement in your script?
What is the log settings in your script?
What are the log settings of dzvents in menu setup settings - other?
To play with logging check the logging dzvents template in the eventeditor
-- This example shows you how to work with various log levels
-- The script is triggered by a dummy switch called 'test'
-- when no log level is specified, the level is taken from the default application settings (dzVents)
-- when you specify LOG_STATUS as minimum log level, no logs will be displayed when using LOG_INFO or LOG_DEBUG
-- Order is: LOG_DEBUG, LOG_INFO, LOG_STATUS, LOG_ERROR
-- LOG_DEBUG will also cause Execution Info to be displayed (start/finished)
devices = {
'test'
logging = {
marker = 'log_script',
level = domoticz.LOG_DEBUG
domoticz.log('INFO log line!', domoticz.LOG_INFO)
domoticz.log('STATUS log line!', domoticz.LOG_STATUS)
domoticz.log('ERROR log line!', domoticz.LOG_ERROR)
domoticz.log('DEBUG log line!', domoticz.LOG_DEBUG)
}Domoticz running on Udoo X86 (on Ubuntu)
I by the way just check in dzvents on myPIRdevice.lastUpdate.minutesAgo attribute. If that is longer then x minutes there is no movement for x minutes. No need to put it in a user variable.
jberinga
- Domoticz version: 2024.7
My Domotizc version: v2025.2 (build 17076) and no log statements in this script.
In the settings the log settings of dzvents is enabled.
I was hoping that you could disable the log level of variables, like you can for devices on the hardware page.
This is the script:
This is the script:
- Spoiler: show
Indeed that seems to be a system log and not a scripting log. As far as I know there is no possibility to switch off logging for user variables as it is not a hardware gateway.
jberinga
Okay, thanks for replying!
Maybe I will look for another way and your suggestion for myPIRdevice.lastUpdate.minutesAgo might work for me as well
