Support for Somfy Connexoon and Tahoma
madpatrick
Domoticz version: 2026.1
Re: Support for Somfy Connexoon and Tahoma
Post by madpatrick »
I've pushed a new version with the temp refresh polling is in the setup page of the hardware and not in the config.txt anymore
For this i\ve sacrificed the flexibility of the logging path. This is now always the domoticz root folder
Please be aware that if you do an update you need to fill in this field with 2 number ; seperated and restart the plugin
Rik60
Domoticz version: 2026.3
Post by Rik60 »
Switched to 5.2.0. Remark: password is visible in settingsscreen, caused by a capital T in last "true".
        <param field="Password" label="Password" width="200px" required="True" default="" password="True"/>
should be:
        <param field="Password" label="Password" width="200px" required="True" default="" password="true"/>
madpatrick
didn't know this was case sensative.
Changed it for all now.
Thanks for testing and the feedback
Jujutasvu
Domoticz version: 2025.2
Post by Jujutasvu »
Hello, I can't no longer use the plugin since the domoticz update
Here the log.
2026-02-03 17:45:47.022 Error: somfy: Call to function 'onStart' failed, exception details:
2026-02-03 17:45:47.119 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.119 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 198, in _new_conn
2026-02-03 17:45:47.119 Error: somfy: sock = connection.create_connection(
2026-02-03 17:45:47.120 Error: somfy: (self._dns_host, self.port),
2026-02-03 17:45:47.120 Error: somfy: ...<2 lines>...
2026-02-03 17:45:47.120 Error: somfy: socket_options=self.socket_options,
2026-02-03 17:45:47.120 Error: somfy: )
2026-02-03 17:45:47.120 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 60, in create_connection
2026-02-03 17:45:47.120 Error: somfy: for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
2026-02-03 17:45:47.120 Error: somfy: ~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.121 Error: somfy: File "/usr/lib/python3.13/socket.py", line 977, in getaddrinfo
2026-02-03 17:45:47.121 Error: somfy: for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
2026-02-03 17:45:47.121 Error: somfy: ~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.121 Error: somfy: socket.gaierror: [Errno -2] Name or service not known
2026-02-03 17:45:47.121 Error: somfy: The above exception was the direct cause of the following exception:
2026-02-03 17:45:47.122 Error: somfy:
2026-02-03 17:45:47.122 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.122 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
2026-02-03 17:45:47.122 Error: somfy: response = self._make_request(
2026-02-03 17:45:47.122 Error: somfy: conn,
2026-02-03 17:45:47.122 Error: somfy: ...<10 lines>...
2026-02-03 17:45:47.122 Error: somfy: **response_kw,
2026-02-03 17:45:47.123 Error: somfy: )
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 488, in _make_request
2026-02-03 17:45:47.123 Error: somfy: raise new_e
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 464, in _make_request
2026-02-03 17:45:47.123 Error: somfy: self._validate_conn(conn)
2026-02-03 17:45:47.123 Error: somfy: ~~~~~~~~~~~~~~~~~~~^^^^^^
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 1093, in _validate_conn
2026-02-03 17:45:47.124 Error: somfy: conn.connect()
2026-02-03 17:45:47.124 Error: somfy: ~~~~~~~~~~~~^^
2026-02-03 17:45:47.124 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 704, in connect
2026-02-03 17:45:47.124 Error: somfy: self.sock = sock = self._new_conn()
2026-02-03 17:45:47.124 Error: somfy: ~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.124 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 205, in _new_conn
2026-02-03 17:45:47.124 Error: somfy: raise NameResolutionError(self.host, self, e) from e
2026-02-03 17:45:47.125 Error: somfy: urllib3.exceptions.NameResolutionError: <urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)
2026-02-03 17:45:47.125 Error: somfy: The above exception was the direct cause of the following exception:
2026-02-03 17:45:47.125 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.125 Error: somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 667, in send
2026-02-03 17:45:47.126 Error: somfy: resp = conn.urlopen(
2026-02-03 17:45:47.126 Error: somfy: method=request.method,
2026-02-03 17:45:47.126 Error: somfy: ...<9 lines>...
2026-02-03 17:45:47.126 Error: somfy: chunked=chunked,
2026-02-03 17:45:47.126 Error: somfy: )
2026-02-03 17:45:47.126 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in urlopen
2026-02-03 17:45:47.126 Error: somfy: retries = retries.increment(
2026-02-03 17:45:47.127 Error: somfy: method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
2026-02-03 17:45:47.127 Error: somfy: )
2026-02-03 17:45:47.127 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 519, in increment
2026-02-03 17:45:47.127 Error: somfy: raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
2026-02-03 17:45:47.127 Error: somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.127 Error: somfy: urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='0811-6250-3860.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)"))
2026-02-03 17:45:47.128 Error: somfy: During handling of the above exception, another exception occurred:
2026-02-03 17:45:47.128 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.128 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 764, in onStart
2026-02-03 17:45:47.128 Error: somfy: _plugin.onStart()
2026-02-03 17:45:47.128 Error: somfy: ~~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.128 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 253, in onStart
2026-02-03 17:45:47.129 Error: somfy: self.setup_and_sync_devices(pin)
2026-02-03 17:45:47.129 Error: somfy: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^
2026-02-03 17:45:47.129 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 276, in setup_and_sync_devices
2026-02-03 17:45:47.129 Error: somfy: self.tahoma.register_listener()
2026-02-03 17:45:47.129 Error: somfy: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.129 Error: somfy: File "/home/julien/domoticz/plugins/somfy/tahoma_local.py", line 252, in register_listener
2026-02-03 17:45:47.129 Error: somfy: response = self.listener.register_listener(self.base_url_local + "/events/register", headers=self.headers_with_token, verify=False)
2026-02-03 17:45:47.130 Error: somfy: File "/home/julien/domoticz/plugins/somfy/listener.py", line 42, in register_listener
2026-02-03 17:45:47.130 Error: somfy: response = requests.post(url, headers=headers, verify=verify, timeout=timeout)
2026-02-03 17:45:47.130 Error: somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 115, in post
2026-02-03 17:45:47.130 Error: somfy: return request("post", url, data=data, json=json, **kwargs)
2026-02-03 17:45:47.130 Error: somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
2026-02-03 17:45:47.130 Error: somfy: return session.request(method=method, url=url, **kwargs)
2026-02-03 17:45:47.131 Error: somfy: ~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 589, in request
2026-02-03 17:45:47.131 Error: somfy: resp = self.send(prep, **send_kwargs)
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 703, in send
2026-02-03 17:45:47.131 Error: somfy: r = adapter.send(request, **kwargs)
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 700, in send
2026-02-03 17:45:47.131 Error: somfy: raise ConnectionError(e, request=request)
2026-02-03 17:45:47.131 Error: somfy: requests.exceptions.ConnectionError: HTTPSConnectionPool(host='0811-6250-3860.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)"))
Thank you for the support
madpatrick
Looks like the Somfy box can not be found
Check your DNS settings, IP and PIN number is correct
Jujutasvu
Post by Jujutasvu »
Everything seems correct in the etc/host and the DNS server
Jujutasvu
Post by Jujutasvu »
Jujutasvu wrote: Tuesday 03 February 2026 21:28 Everything seems correct in the etc/host and the DNS server
My Bad the host wasn't good !! :oops:
Jujutasvu
Post by Jujutasvu »
Sorry but i now have this issue
2026-02-04 21:42:34.474 Error: somfy: Connection error: failed request during get devices, check credentials: 401
I check my credentials and it's good but i can't log to tahoma.
Jujutasvu
Post by Jujutasvu »
Hi there, I use a Conexoon box and for information i had to execute the plugin with the WEB connection therefore i had to change this in the tahoma.py
class Tahoma:
    """class to interface with tahoma web API"""
    def __init__(self):
        self.srvaddr = "ha101-1.overkiz.com"
        self.base_url = "https://ha101-1.overkiz.com:443"
        self.login_url = "/enduser-mobile-web/enduserAPI/login"
Have nice day
madpatrick
Did you send the setting to local in the plugin?
Because it should use tahoma_local.py and tahoma.py
In tahoma_local.py you will find the "base_url_web = "https://ha101-1.overkiz.com"
2026-02-05 16_49_15-OpenVPN Connect.png (2.9 KiB) Viewed 33792 times
Jujutasvu
Post by Jujutasvu »
Indeed the base Url is find by the tahoma_local.py but i still got this message.
2026-02-05 16:57:55.453 Error: somfy: Connection error: failed request during get devices, check credentials: 401
whereas i put web it works.
madpatrick
I can not reproduced it.
Can you maybe try the update
I've added an extra log line to see which file it will load
2026-02-05 19:32:08.516 Somfy: TaHoma LOCAL client loaded
madpatrick
I've released a new version and added an extra info device
It show the connectivity, type of box, Firmware version and status
Under the hood a lot of fixed and cleanup
Rik60
Post by Rik60 »
Nice, thanks.
madpatrick
I've made some adjustments to enable the connection by IP.
This means that you do not need to have de PIN added to the DNS any more.
I need to people to have this tested before i will release this version to ensure it is working properly
Please share if it is working as it should be.
Some field are changed in the settings to free up some field (current limitation in Domoticz)
Choose Local IP to thest with IP and remove the DNS setting in you DHCP server/ Router
Then try to reset the token and see if you will receive a new token
Old methode will remain in the plugin available
Check out this test branch
https://github.com/MadPatrick/domoticz_ ... ion-via-ip
Filnet
Domoticz version: 2026.1 ß
Post by Filnet »
Hello MadPatrick,
My version is 5.3.0. I don't see the new parameter Local IP (Only Local vs WEB).
Where is the link to load this version test?
madpatrick
Filnet wrote: Thursday 09 April 2026 7:33 Hello MadPatrick,
Did you check the branch "make-connection-via-ip" ?
Rik60
Post by Rik60 »
If i do:
git checkout make-connection-via-ip
i receive an error: pathspec 'make-connection-via-ip' did not match any file(s) known to git. If i go to github i can see the branche.
Tip: you can combine 'Refresh interval' and 'Temp polling interval' in one mode. This mode has then 4 variables. I have tried this, that is working. Saving one mode
madpatrick
if you click on the link you can also download a zip file
2026-04-09 15_01_25-Instellingen.png (27.79 KiB) Viewed 32985 times
or go to the master branche and click on the pull downmenu
2026-04-09 14_59_58-Instellingen.png (47.42 KiB) Viewed 32985 times
Rik60
Post by Rik60 »
Tested the plugin.
Gave the Tahomabox a new ip adres and resetted the box. Have put this new adres in the hardware settings, and switched to local ip. Restarted the plugin. The Somfy devices where working. After this resetted the token.
In the Domoticz logging i see no messages about a new token. The devices are working.
